Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 12-31-2018, 10:37   #1 (permalink)
Member: 2765424
Thanks Meter: 305
Lg g4 h810 dead boot repier done selected ls991 only click smart repair
LG G4 H810 DEAD BOOT REPIER DONE SELECTED LS991 only click smart repair
Welcome to Medusa Pro Software version 1.7.1.
Started.
Reader #0: Alcor Micro USB Smart Card Reader 0
Reader #1: Alcor Micro USB Smart Card Reader 1
Reader #2: Alcor Micro USB Smart Card Reader 4
Reader #3: Dell Dell Smart Card Reader Keyboard 0
Reader #4: FT SCR2000 0
Reader #5: FT SCR2000 1
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Brand : LG
Model : LS991
SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Toshiba eMMC 032G74
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 11010030333247373400D2CED2F73297
Manufacturer ID : 0X11
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : 032G74
Product revision : 0.0
Product serial number : (hex) D2CED2F7
Manufacturing date : 03/2015
CSD Info
CSD : D02700320F5903FFFFFFFFE78640009B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 4096 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 15269888 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : 47c00000 bytes
Device sector size : 512 bytes
Partition offset : 1048576
Number of sectors : 9273344
Device Manufacturer :lge
Device Platform :msm8992
Build ID :LMY47D
Display Build ID :LMY47D
Release ID :5.1
Device Model :LG-H810
Device Name 1_att_us
Architecture ABI :arm64-v8a
Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi
Build Description 1_att_us-user 5.1 LMY47D 1525314544ad4 release-keys
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_24_12_2018_11_03_44.bin.
Connect successful.
SW: 1.7.1; FW: 1.24.
P00: GPT (00000000, 00008000) 16 MB
P01: modem (00008000, 0002B000) 86 MB
P02: pmic (00038000, 00000400) 512 KB
P03: sbl1 (00038400, 00000800) 1024 KB
P04: tz (00038C00, 00000800) 1024 KB
P05: sdi (00039400, 00000400) 512 KB
P06: hyp (00039800, 00000400) 512 KB
P07: rpm (00039C00, 00000400) 512 KB
P08: aboot (0003A000, 00001000) 2048 KB
P09: sbl1bak (0003B000, 00000800) 1024 KB
P10: pmicbak (0003B800, 00000400) 512 KB
P11: tzbak (0003BC00, 00000800) 1024 KB
P12: hypbak (0003C400, 00000400) 512 KB
P13: rpmbak (0003C800, 00000400) 512 KB
P14: abootbak (0003CC00, 00001000) 2048 KB
P15: sdibak (0003DC00, 00000400) 512 KB
P16: limits (0003E000, 00000400) 512 KB
P17: devinfo (0003E400, 00000400) 512 KB
P18: apdp (0003E800, 00000400) 512 KB
P19: msadp (0003EC00, 00000400) 512 KB
P20: dpo (0003F000, 00000400) 512 KB
P21: spare1 (0003F400, 00000C00) 1536 KB
P22: misc (00040000, 00008000) 16 MB
P23: persist (00048000, 00010000) 32 MB
P24: modemst1 (00058000, 00000C00) 1536 KB
P25: modemst2 (00058C00, 00000C00) 1536 KB
P26: fsg (00059800, 00000C00) 1536 KB
P27: fsc (0005A400, 00000400) 512 KB
P28: ssd (0005A800, 00000400) 512 KB
P29: keystore (0005AC00, 00000400) 512 KB
P30: DDR (0005B000, 00001000) 2048 KB
P31: sec (0005C000, 00000400) 512 KB
P32: encrypt (0005C400, 00000400) 512 KB
P33: eksst (0005C800, 00000400) 512 KB
P34: rct (0005CC00, 00000400) 512 KB
P35: persistent (0005D000, 00001000) 2048 KB
P36: spare2 (0005E000, 00002000) 4 MB
P37: laf (00060000, 00018000) 48 MB
P38: boot (00078000, 00014000) 40 MB
P39: recovery (0008C000, 00014000) 40 MB
P40: drm (000A0000, 00004000) 8 MB
P41: sns (000A4000, 00004000) 8 MB
P42: mpt (000A8000, 00010000) 32 MB
P43: eri (000B8000, 00004000) 8 MB
P44: raw_resources (000BC000, 00002000) 4 MB
P45: raw_resourcesbak (000BE000, 00002000) 4 MB
P46: operatorlogging (000C0000, 00008000) 16 MB
P47: carrier (000C8000, 00014000) 40 MB
P48: felica (000DC000, 00004000) 8 MB
P49: factory (000E0000, 00017000) 46 MB
P50: spare3 (000F7000, 00001000) 2048 KB
P51: fota (000F8000, 00005000) 10 MB
P52: spare4 (000FD000, 00003000) 6 MB
P53: system (00100000, 008D8000) 4.422 GB
P54: cache (009D8000, 00268000) 1232 MB
P55: userdata (00C40000, 02DF8000) 22.98 GB
P56: grow (03A38000, 00005FDF) 11.98 MB
Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_LS991_EMMC_032G74.srf".
Write data verification is enabled.
Writing GPT partition... Done.
Writing pmic partition... Done.
Writing sbl1 partition... Done.
Writing tz partition... Done.
Writing sdi partition... Done.
Writing hyp partition... Done.
Writing rpm partition... Done.
Writing aboot partition... Done.
Writing limits partition... Done.
Writing devinfo partition... Done.
Writing apdp partition... Done.
Writing msadp partition... Done.
Writing dpo partition... Done.
Writing spare1 partition... Done.
Writing misc partition... Done.
Writing persist partition... Done.
Writing modemst1 partition... Done.
Writing modemst2 partition... Done.
Writing fsg partition... Done.
Writing fsc partition... Done.
Writing ssd partition... Done.
Writing keystore partition... Done.
Writing DDR partition... Done.
Writing sec partition... Done.
Writing encrypt partition... Done.
Writing eksst partition... Done.
Writing rct partition... Done.
Writing persistent partition... Done.
Writing laf partition... Done.
Writing boot partition... Done.
Writing recovery partition... Done.
Writing raw_resources partition... Done.
Smart Repair is successfully complete.
Disconnected.
after dead booot repier done mobile hong on logo flash ls991
Welcome to Octoplus/Octopus Box LG Software version 2.9.0
Connecting to server support2.octoplusbox.com:82...OK
Authorizing...OK
Checking data...OK
Platform: LG Qualcomm
Selected port: COM137
Selected model: H810
Reading info...
Model ID: LGLS991
Incompatible model ID!
Canceled!
Performed by 2.9.0 Software version.
Checking data...OK
Selected model: LS991
Reading info...
IMEI: 357355-06-232631-6
Android version: 5.1
Battery level: 99%
SW Version: LS991ZV5
Mode: Emergency
Initializing flash...OK
Platform: msm8992
SW version: LS991ZVB_02
Android version: 6.0
LAF Version: 1.1
Product ID: PT03S150518006747
IMEI: 350305-26-000000-4
Target operator: SPR
Hardware: rev_10
Writing phone firmware without real necessity is at your own risk.
Downgrade may lead to phone damage!
Please, make sure the phone's battery is fully charged.
Disconnect all other devices from the computer (including phones,
modems, etc.) and close all other running programs.
To avoid errors in the flashing process, use a clean PC (without any
installed drivers for other Qualcomm-based devices).
You should not run any other programs or attach new devices to your
computer during the flashing!
Opening "ls991zvb_02_arb03_2.oct"...OK
Setting options...OK
Reading partitions...OK
Formating USERDATA...OK
Formating ENCRYPT...OK
Writing PrimaryGPT...OK
Writing modem...OK
Writing pmic...OK
Writing sbl1...OK
Writing tz...OK
Writing sdi...OK
Writing hyp...OK
Writing rpm...OK
Writing aboot...OK
Writing sbl1bak...OK
Writing pmicbak...OK
Writing tzbak...OK
Writing hypbak...OK
Writing rpmbak...OK
Writing abootbak...OK
Writing sdibak...OK
Writing persist...OK
Writing sec...OK
Writing laf...OK
Writing boot...OK
Writing recovery...OK
Writing raw_resources...OK
Writing raw_resourcesbak...OK
Writing factory...OK
Writing system...OK
Writing userdata...OK
Writing BackupGPT...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
Writing firmware done!
Authorizing...OK
Checking data...OK
Reading info...
Model ID: LGLS991
Canceled!
Checking data...OK
Reading info...
Battery level: 99%
Mode: Emergency
Platform: msm8992
LAF Version: 1.1
Hardware: rev_10
Writing modem...OK
Writing pmic...OK
Writing sbl1...OK
Writing tz...OK
Writing sdi...OK
Writing hyp...OK
Writing rpm...OK
Writing aboot...OK
Writing tzbak...OK
Writing hypbak...OK
Writing rpmbak...OK
Writing sdibak...OK
Writing sec...OK
Writing laf...OK
Writing boot...OK
Writing system...OK
Formating RCT...OK
Formating MPT...OK
Finalizing...OK
The Following User Says Thank You to taimur-ahmad For This Useful Post:
Old 01-02-2019, 00:11   #2 (permalink)
Member: 1283129
Thanks Meter: 83
Why use EMMC? Can't you just open phone, put in Qualcomm 9008 mode with test point and do?
Page generated in 0.20997 seconds with 7 queries
