LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
06-22-2017, 17:46 | #16 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: PAKISTAN Age: 38
Member: 689829 Status: Offline Sonork: 100.1651716 Thanks Meter: 102 | Quote:
06-22-2017, 18:44 | #17 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Search on google H810 dump file and follow that above process.
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim Last edited by ...:::SHAMIM:::...; 06-23-2017 at 10:45. |
06-23-2017, 21:35 | #18 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | In case anyone needs it, here is a clean system.img from the 10e firmware, courtesy of phineous. https://forum.gsmhosting.com/vbb/****************************/?0g4mkg2b2mcifzb Write the system image on sd card and post result here.
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
06-24-2017, 11:30 | #20 (permalink) | |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
That case are maximum people didn't do Sd card format Correctly. Take a Sandisk 64gb Memory card and Format it by windows formatter exfat without tick quick format. Remember low format Take More than couple hours. Write the System.img to memory card by Win32diskimager When finished put into the memory card off phone. Connect Phone with hold on Vol up Button Cheers
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
06-28-2017, 13:37 | #23 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Though it's Hardware Faulty!
06-29-2017, 07:25 | #26 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Try to Rehot or Replace EMMC chip!
06-29-2017, 07:27 | #27 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Please use Search Button get Your Result!
07-08-2017, 11:36 | #29 (permalink) |
No Life Poster Join Date: May 2005 Age: 61
Member: 147694 Status: Offline Thanks Meter: 69 | Hello I flashed h811 with h811_20v firmware and phone became dead. I repaired boot without testpoint with this method http://forum.gsmhosting.com/vbb/f779...t-box-2211744/ I managed to repair boot and turn on the phone but now phone has unknown baseband and imei null and has no service. Any idea how to be fixed network. Best Arimob |
07-09-2017, 06:59 | #30 (permalink) | |
After Repair Boot did you flash phone with H811_20v? If no then flash this version or Higher by Lg Bridge. If also Same then Try to Fix Imei and baseband with a professional Tools!
