Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 04-12-2017, 07:01   #1 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,416
Thumbs up LG G4 H811 Complete Unbrick Guide - 100% Working
Hello Everyone,
I have H811 with v20o. I mistakenly flashed the Modem+Boot+Bootloader+Rom of V20i on my device and hard bricked it. My device was totally dead. No Charging/Notification light, No Download Mode, No Boot & No Recovery.
I spent more than 2 days in finding the solution and finally i found it.
Thread by By leptdre, was very helpful for me. But to make it simple the steps to complete unbricking are as follows:
Tools Required:
1. Card Reader+Data Cable
2. A SD Card - 32 GB or 64 GB. I used 64 GB
3. SD Card Formatter - Download Here
4. Win32DiskImager - Download Here
5. Original KDZ - Download Here
6. SystemImage Bin File - Download Here
7. LGUP Tool - Download Here
Steps to Unbrick:
1. Insert your memory card in Card Reader and Format it using Windows Format. While formatting "uncheck Quick Format" and Change Type to "exFat". You can alternatively use SD Card Formatter but make sure that the card is in exFat format.
2. Once format is completed, install Win32DiskImager and open it. Add SystemImage.bin file. If it does not show the bin file just rename SystemImage.bin to SystemImage.img and then select it. Select your memory card and Click Write.
(You can alternatively change the file types on the win32diskimage from .img to all types)
3. One the Write Completes. Eject Card and insert in your LG G4 H811. Press Volume Up Button while connecting the USB Cable.
4. There you go, it will open the download mode. Now Open LGUP Tool as admin. It will show the device as connected. Select the Original KDZ Firmware and Click Start. it will complete and your Mobile will reboot.
5. Now its Done. Enjoy!
Note: I tried it on my H811 and cannot confirm whether it will work on your device or other variant. I am just sharing to help others
Credits: jam1445
The Following 20 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 04-13-2017, 12:29   #2 (permalink)
jamohaki's Avatar
Member: 83397
Thanks Meter: 139
thanks but can you check the mega links i seems cannot download from any of them
Old 04-13-2017, 15:46   #3 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,416
Link Stabled!
Try to Uninstall and Install Your Browser.
Old 04-13-2017, 17:14   #4 (permalink)
Member: 242222
Thanks Meter: 43
i cant donwload SystemImage Bin File
Old 04-16-2017, 18:20   #5 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,416
SystemImage Bin Link is also Stabled!
Try to download different browser and Downloader.
Old 04-18-2017, 18:29   #6 (permalink)
Member: 1283129
Thanks Meter: 127
None of your mega links are working friend.
Old 04-18-2017, 20:34   #7 (permalink)
Member: 2105719
Thanks Meter: 19
I never saw an LG 811 unit working, Everytime a client bring to me LG G4 I say, sorry this **** is defected and it will never work again.
The Following User Says Thank You to cranknet For This Useful Post:
Old 04-22-2017, 20:38   #8 (permalink)
Member: 1932577
Thanks Meter: 11
Links works I had to use firefox to download it.
Old 04-29-2017, 15:07   #9 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 426
https://mega.nz/#!5IoBkS6S!kxFixzRrg...wn_hYvDGgJYWxQ
working link
The Following 3 Users Say Thank You to Mubashir999 For This Useful Post:
Old 05-17-2017, 11:13   #10 (permalink)
Member: 2570477
Thanks Meter: 426
Sir My H811 Powerd on with this use full methode But how can I Fix Download Mode ..
Download mode error
Old 05-18-2017, 15:27   #11 (permalink)
Member: 2707321
Thanks Meter: 6
Where I can find system image for k520dy
Old 05-21-2017, 19:40   #12 (permalink)
Member: 2707321
Thanks Meter: 6
Old 05-27-2017, 15:45   #13 (permalink)
Member: 2508405
Sonork: 100.1671124
Thanks Meter: 48
after totaly power on phone and work fine
when turn it off return to the same problem
and the same method cercle
any help
Old 05-27-2017, 20:40   #14 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,416
any help
Though Phone EMMC fault.
Rehot or Replace EMMC phone will be work properly.
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 05-28-2017, 15:13   #15 (permalink)
Member: 2508405
Sonork: 100.1671124
Thanks Meter: 48
also after rehot the same problem
about "replace EMMC" it's to far from me ( no hardware no machine)
Page generated in 0.35434 seconds with 7 queries
