Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 06-22-2017, 17:46   #16 (permalink)
jaan_e_ahsan45's Avatar
Member: 689829
Sonork: 100.1651716
Thanks Meter: 88
Originally Posted by ...:::SHAMIM:::... View Post
Hello Everyone,
I have H811 with v20o. I mistakenly flashed the Modem+Boot+Bootloader+Rom of V20i on my device and hard bricked it. My device was totally dead. No Charging/Notification light, No Download Mode, No Boot & No Recovery.
I spent more than 2 days in finding the solution and finally i found it.
Thread by By leptdre, was very helpful for me. But to make it simple the steps to complete unbricking are as follows:
Tools Required:
1. Card Reader+Data Cable
2. A SD Card - 32 GB or 64 GB. I used 64 GB
3. SD Card Formatter - Download Here
4. Win32DiskImager - Download Here
5. Original KDZ - Download Here
6. SystemImage Bin File - Download Here
7. LGUP Tool - Download Here
Steps to Unbrick:
1. Insert your memory card in Card Reader and Format it using Windows Format. While formatting "uncheck Quick Format" and Change Type to "exFat". You can alternatively use SD Card Formatter but make sure that the card is in exFat format.
2. Once format is completed, install Win32DiskImager and open it. Add SystemImage.bin file. If it does not show the bin file just rename SystemImage.bin to SystemImage.img and then select it. Select your memory card and Click Write.
(You can alternatively change the file types on the win32diskimage from .img to all types)
3. One the Write Completes. Eject Card and insert in your LG G4 H811. Press Volume Up Button while connecting the USB Cable.
4. There you go, it will open the download mode. Now Open LGUP Tool as admin. It will show the device as connected. Select the Original KDZ Firmware and Click Start. it will complete and your Mobile will reboot.
5. Now its Done. Enjoy!
Note: I tried it on my H811 and cannot confirm whether it will work on your device or other variant. I am just sharing to help others
Credits: jam1445
will it work on H810?
Old 06-22-2017, 18:44   #17 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Search on google H810 dump file and follow that above process.
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Old 06-23-2017, 21:35   #18 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
In case anyone needs it,
here is a clean system.img from the 10e firmware, courtesy of phineous.
https://www.mediafire.com/?0g4mkg2b2mcifzb
Write the system image on sd card and post result here.
__________________
__________________
Best Regards,
Shamim
Old 06-24-2017, 06:38   #19 (permalink)
Member: 2425737
Thanks Meter: 6
Bro i am try this method but don't work for me
Envoyé de mon iPhone en utilisant Tapatalk
Old 06-24-2017, 11:30   #20 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
How did you work?
That case are maximum people didn't do Sd card format Correctly.
Take a Sandisk 64gb Memory card and Format it by windows formatter exfat without tick quick format. Remember low format Take More than couple hours.
Write the System.img to memory card by Win32diskimager
When finished put into the memory card off phone.
Connect Phone with hold on Vol up Button
Cheers
__________________
__________________
Best Regards,
Shamim
Old 06-24-2017, 11:33   #21 (permalink)
Member: 2425737
Thanks Meter: 6
I am try but I have Samsung sd card 32 giga IAM try for 64 giga and give you feedback bro thanks
Old 06-28-2017, 11:29   #22 (permalink)
PiratesGSMKing's Avatar
Member: 2684815
Thanks Meter: 49
...:::SHAMIM:::... sir please help me
when i am trying to download mode mobile restarting plz help
Old 06-28-2017, 13:37   #23 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Though it's Hardware Faulty!
__________________
__________________
Best Regards,
Shamim
Old 06-28-2017, 16:05   #24 (permalink)
Member: 2684815
Thanks Meter: 49
Any help for it sir ???????
Old 06-28-2017, 16:19   #25 (permalink)
Member: 1987130
Thanks Meter: 5
SystemImage Bin Link is also Stabled!
Try to download different browser and Downloader.
My LG G5 can not enter the download mode! How do I get the system image file to make SD card
Old 06-29-2017, 07:25   #26 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Smile
Try to Rehot or Replace EMMC chip!
__________________
__________________
Best Regards,
Shamim
Old 06-29-2017, 07:27   #27 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Please use Search Button get Your Result!
__________________
__________________
Best Regards,
Shamim
Old 06-29-2017, 11:16   #28 (permalink)
Member: 2684815
Thanks Meter: 49
...:::SHAMIM:::...
Sir i was wrong my phone model is H810 and i was trying H811 file
Please can u give me H810 SD card file ???????
Old 07-08-2017, 11:36   #29 (permalink)
arimob's Avatar
Member: 147694
Thanks Meter: 65
Hello
I flashed h811 with h811_20v firmware and phone became dead. I repaired boot without testpoint with this method Unbrick LG G4 Brick hs-usb Qdloader 9008 Without Box
I managed to repair boot and turn on the phone but now phone has unknown baseband and imei null and has no service. Any idea how to be fixed network.
Best
Arimob
Old 07-09-2017, 06:59   #30 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,164
Originally Posted by arimob View Post
Hello
Best
Arimob
Now Whats the Version inside on your Phone?
After Repair Boot did you flash phone with H811_20v? If no then flash this version or Higher by Lg Bridge.
If also Same then Try to Fix Imei and baseband with a professional Tools!
__________________
__________________
Best Regards,
Shamim
Page generated in 0.41374 seconds with 7 queries
