LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
05-17-2018, 11:47 | #77 (permalink) |
Junior Member Join Date: May 2018
Member: 2837565 Status: Offline Thanks Meter: 0 | I downloaded the xml but which tool should I use to test the files on my h872? I've tried a couple but they're requiring firehose and patch xml. Much appreciated for the help on this. |
05-17-2018, 18:07 | #79 (permalink) |
Freak Poster Join Date: Oct 2017 Location: Portugal Age: 41
Member: 2771305 Status: Offline Thanks Meter: 59 | Try ToolStudio > DOWNLOAD < I DO NOT KNOW IF THIS IS A VIRUS OR A FALSE POSITIVE | > LINK WITH IMAGES OF THE TOOL |
05-18-2018, 13:08 | #81 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2594814 Status: Offline Thanks Meter: 5 | kdz extract linux sd card write done command link https://mega.nz/#!cJ9WUAiA!TSt9L5G3C...n8vx0pQ9ToxCFw https://forum.xda-developers.com/g4/...-qfil-t3748946 sorry bad english aaya@aaya-Aspire-E1-531:~/Downloads$ sudo dmesg -c >> /dev/null [sudo] password for aaya: aaya@aaya-Aspire-E1-531:~/Downloads$ dmesg aaya@aaya-Aspire-E1-531:~/Downloads$ sudo fdisk -l /dev/sdb Disk /dev/sdb: 58,4 GiB, 62730010624 bytes, 122519552 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00000000 Device Boot Start End Sectors Size Id Type /dev/sdb1 * 2048 122519551 122517504 58,4G c W95 FAT32 (LBA) aaya@aaya-Aspire-E1-531:~/Downloads$ cd kdz aaya@aaya-Aspire-E1-531:~/Downloads/kdz$ sudo -s root@aaya-Aspire-E1-531:~/Downloads/kdz# dd if=PrimaryGPT.bin of=/dev/sdb 48+0 records in 48+0 records out 24576 bytes (25 kB, 24 KiB) copied, 0,0441583 s, 557 kB/s root@aaya-Aspire-E1-531:~/Downloads/kdz# sync root@aaya-Aspire-E1-531:~/Downloads/kdz# ls -la /dev/disk/by-partlabel total 0 drwxr-xr-x 2 root root 60 Луу 18 19:32 . drwxr-xr-x 7 root root 140 Луу 18 19:32 .. lrwxrwxrwx 1 root root 10 Луу 18 18:35 EFI\x20System\x20Partition -> ../../sda1 root@aaya-Aspire-E1-531:~/Downloads/kdz# cd kdz bash: cd: kdz: No such file or directory root@aaya-Aspire-E1-531:~/Downloads/kdz# for i in $(ls *.bin |egrep -v "(GPT|userdata)");do echo dd if=$i of=/dev/disk/by-partlabel/${i/\.bin};done dd if=abootbak.bin of=/dev/disk/by-partlabel/abootbak dd if=aboot.bin of=/dev/disk/by-partlabel/aboot dd if=apdp.bin of=/dev/disk/by-partlabel/apdp dd if=boot.bin of=/dev/disk/by-partlabel/boot dd if=cache.bin of=/dev/disk/by-partlabel/cache dd if=cdt.bin of=/dev/disk/by-partlabel/cdt dd if=cmnlib64bak.bin of=/dev/disk/by-partlabel/cmnlib64bak dd if=cmnlib64.bin of=/dev/disk/by-partlabel/cmnlib64 dd if=cmnlibbak.bin of=/dev/disk/by-partlabel/cmnlibbak dd if=cmnlib.bin of=/dev/disk/by-partlabel/cmnlib dd if=ddr.bin of=/dev/disk/by-partlabel/ddr dd if=devcfgbak.bin of=/dev/disk/by-partlabel/devcfgbak dd if=devcfg.bin of=/dev/disk/by-partlabel/devcfg dd if=devinfo.bin of=/dev/disk/by-partlabel/devinfo dd if=dip.bin of=/dev/disk/by-partlabel/dip dd if=dpo.bin of=/dev/disk/by-partlabel/dpo dd if=drm.bin of=/dev/disk/by-partlabel/drm dd if=eksst.bin of=/dev/disk/by-partlabel/eksst dd if=encrypt.bin of=/dev/disk/by-partlabel/encrypt dd if=factory.bin of=/dev/disk/by-partlabel/factory dd if=fota.bin of=/dev/disk/by-partlabel/fota dd if=fsc.bin of=/dev/disk/by-partlabel/fsc dd if=fsg.bin of=/dev/disk/by-partlabel/fsg dd if=grow2.bin of=/dev/disk/by-partlabel/grow2 dd if=grow3.bin of=/dev/disk/by-partlabel/grow3 dd if=grow4.bin of=/dev/disk/by-partlabel/grow4 dd if=grow5.bin of=/dev/disk/by-partlabel/grow5 dd if=grow6.bin of=/dev/disk/by-partlabel/grow6 dd if=grow.bin of=/dev/disk/by-partlabel/grow dd if=hypbak.bin of=/dev/disk/by-partlabel/hypbak dd if=hyp.bin of=/dev/disk/by-partlabel/hyp dd if=keymasterbak.bin of=/dev/disk/by-partlabel/keymasterbak dd if=keymaster.bin of=/dev/disk/by-partlabel/keymaster dd if=keystore.bin of=/dev/disk/by-partlabel/keystore dd if=lafbak.bin of=/dev/disk/by-partlabel/lafbak dd if=laf.bin of=/dev/disk/by-partlabel/laf dd if=misc.bin of=/dev/disk/by-partlabel/misc dd if=modem.bin of=/dev/disk/by-partlabel/modem dd if=modemst1.bin of=/dev/disk/by-partlabel/modemst1 dd if=modemst2.bin of=/dev/disk/by-partlabel/modemst2 dd if=mpt.bin of=/dev/disk/by-partlabel/mpt dd if=msadp.bin of=/dev/disk/by-partlabel/msadp dd if=persist.bin of=/dev/disk/by-partlabel/persist dd if=pmicbak.bin of=/dev/disk/by-partlabel/pmicbak dd if=pmic.bin of=/dev/disk/by-partlabel/pmic dd if=raw_resourcesbak.bin of=/dev/disk/by-partlabel/raw_resourcesbak dd if=raw_resources.bin of=/dev/disk/by-partlabel/raw_resources dd if=rct.bin of=/dev/disk/by-partlabel/rct dd if=recoverybak.bin of=/dev/disk/by-partlabel/recoverybak dd if=recovery.bin of=/dev/disk/by-partlabel/recovery dd if=reserve.bin of=/dev/disk/by-partlabel/reserve dd if=rpmbak.bin of=/dev/disk/by-partlabel/rpmbak dd if=rpm.bin of=/dev/disk/by-partlabel/rpm dd if=sec.bin of=/dev/disk/by-partlabel/sec dd if=sns.bin of=/dev/disk/by-partlabel/sns dd if=spare1.bin of=/dev/disk/by-partlabel/spare1 dd if=spare2.bin of=/dev/disk/by-partlabel/spare2 dd if=ssd.bin of=/dev/disk/by-partlabel/ssd dd if=system.bin of=/dev/disk/by-partlabel/system dd if=tzbak.bin of=/dev/disk/by-partlabel/tzbak dd if=tz.bin of=/dev/disk/by-partlabel/tz dd if=xbl2bak.bin of=/dev/disk/by-partlabel/xbl2bak dd if=xbl2.bin of=/dev/disk/by-partlabel/xbl2 dd if=xblbak.bin of=/dev/disk/by-partlabel/xblbak dd if=xbl.bin of=/dev/disk/by-partlabel/xbl root@aaya-Aspire-E1-531:~/Downloads/kdz# for i in $(ls *.bin |egrep -v "(GPT|userdata)");do dd if=$i of=/dev/disk/by-partlabel/${i/\.bin};done 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,0645802 s, 32,5 MB/s 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,033826 s, 62,0 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0139195 s, 37,7 MB/s 81920+0 records in 81920+0 records out 41943040 bytes (42 MB, 40 MiB) copied, 0,538989 s, 77,8 MB/s 1048576+0 records in 1048576+0 records out 536870912 bytes (537 MB, 512 MiB) copied, 6,8639 s, 78,2 MB/s 8+0 records in 8+0 records out 4096 bytes (4,1 kB, 4,0 KiB) copied, 0,000314755 s, 13,0 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00478674 s, 110 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00568034 s, 92,3 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00660332 s, 79,4 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00483936 s, 108 MB/s 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,0297275 s, 70,5 MB/s 256+0 records in 256+0 records out 131072 bytes (131 kB, 128 KiB) copied, 0,00236585 s, 55,4 MB/s 256+0 records in 256+0 records out 131072 bytes (131 kB, 128 KiB) copied, 0,00274482 s, 47,8 MB/s 2048+0 records in 2048+0 records out 1048576 bytes (1,0 MB, 1,0 MiB) copied, 0,0135021 s, 77,7 MB/s 2048+0 records in 2048+0 records out 1048576 bytes (1,0 MB, 1,0 MiB) copied, 0,0120692 s, 86,9 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0153506 s, 34,2 MB/s 20480+0 records in 20480+0 records out 10485760 bytes (10 MB, 10 MiB) copied, 0,13946 s, 75,2 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00688644 s, 76,1 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0049967 s, 105 MB/s 135168+0 records in 135168+0 records out 69206016 bytes (69 MB, 66 MiB) copied, 1,01334 s, 68,3 MB/s 8192+0 records in 8192+0 records out 4194304 bytes (4,2 MB, 4,0 MiB) copied, 0,0511182 s, 82,1 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00611613 s, 85,7 MB/s 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,0170799 s, 123 MB/s 8+0 records in 8+0 records out 4096 bytes (4,1 kB, 4,0 KiB) copied, 0,000273026 s, 15,0 MB/s 8+0 records in 8+0 records out 4096 bytes (4,1 kB, 4,0 KiB) copied, 0,000179081 s, 22,9 MB/s 8+0 records in 8+0 records out 4096 bytes (4,1 kB, 4,0 KiB) copied, 0,000323429 s, 12,7 MB/s 8+0 records in 8+0 records out 4096 bytes (4,1 kB, 4,0 KiB) copied, 0,00018018 s, 22,7 MB/s 8+0 records in 8+0 records out 4096 bytes (4,1 kB, 4,0 KiB) copied, 0,000267083 s, 15,3 MB/s 7080+0 records in 7080+0 records out 3624960 bytes (3,6 MB, 3,5 MiB) copied, 0,0571791 s, 63,4 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00556187 s, 94,3 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00537099 s, 97,6 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00457723 s, 115 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0146511 s, 35,8 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00600904 s, 87,2 MB/s 98304+0 records in 98304+0 records out 50331648 bytes (50 MB, 48 MiB) copied, 0,67333 s, 74,8 MB/s 98304+0 records in 98304+0 records out 50331648 bytes (50 MB, 48 MiB) copied, 0,616455 s, 81,6 MB/s 65536+0 records in 65536+0 records out 33554432 bytes (34 MB, 32 MiB) copied, 0,404057 s, 83,0 MB/s 176128+0 records in 176128+0 records out 90177536 bytes (90 MB, 86 MiB) copied, 1,1437 s, 78,8 MB/s 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,0244209 s, 85,9 MB/s 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,0240775 s, 87,1 MB/s 65536+0 records in 65536+0 records out 33554432 bytes (34 MB, 32 MiB) copied, 0,426183 s, 78,7 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00713832 s, 73,4 MB/s 65536+0 records in 65536+0 records out 33554432 bytes (34 MB, 32 MiB) copied, 0,405352 s, 82,8 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0956617 s, 5,5 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00720851 s, 72,7 MB/s 8192+0 records in 8192+0 records out 4194304 bytes (4,2 MB, 4,0 MiB) copied, 0,0700125 s, 59,9 MB/s 8192+0 records in 8192+0 records out 4194304 bytes (4,2 MB, 4,0 MiB) copied, 0,0754277 s, 55,6 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0422099 s, 12,4 MB/s 82944+0 records in 82944+0 records out 42467328 bytes (42 MB, 40 MiB) copied, 0,51604 s, 82,3 MB/s 82944+0 records in 82944+0 records out 42467328 bytes (42 MB, 40 MiB) copied, 0,542084 s, 78,3 MB/s 64+0 records in 64+0 records out 32768 bytes (33 kB, 32 KiB) copied, 0,00882342 s, 3,7 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0230715 s, 22,7 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0240835 s, 21,8 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,00557492 s, 94,0 MB/s 12288+0 records in 12288+0 records out 6291456 bytes (6,3 MB, 6,0 MiB) copied, 0,100289 s, 62,7 MB/s 8192+0 records in 8192+0 records out 4194304 bytes (4,2 MB, 4,0 MiB) copied, 0,0708991 s, 59,2 MB/s 4096+0 records in 4096+0 records out 2097152 bytes (2,1 MB, 2,0 MiB) copied, 0,042133 s, 49,8 MB/s 1024+0 records in 1024+0 records out 524288 bytes (524 kB, 512 KiB) copied, 0,0214201 s, 24,5 MB/s dd: writing to '/dev/disk/by-partlabel/system': No space left on device 1740777+0 records in 1740776+0 records out 891277312 bytes (891 MB, 850 MiB) copied, 11,3213 s, 78,7 MB/s dd: writing to '/dev/disk/by-partlabel/tzbak': No space left on device 1+0 records in 0+0 records out 0 bytes copied, 0,0257604 s, 0,0 kB/s dd: writing to '/dev/disk/by-partlabel/tz': No space left on device 1+0 records in 0+0 records out 0 bytes copied, 0,0130488 s, 0,0 kB/s dd: writing to '/dev/disk/by-partlabel/xbl2bak': No space left on device 1+0 records in 0+0 records out 0 bytes copied, 0,0112316 s, 0,0 kB/s dd: writing to '/dev/disk/by-partlabel/xbl2': No space left on device 1+0 records in 0+0 records out 0 bytes copied, 0,00448855 s, 0,0 kB/s dd: writing to '/dev/disk/by-partlabel/xblbak': No space left on device 1+0 records in 0+0 records out 0 bytes copied, 0,00429619 s, 0,0 kB/s dd: writing to '/dev/disk/by-partlabel/xbl': No space left on device 1+0 records in 0+0 records out 0 bytes copied, 0,00457151 s, 0,0 kB/s root@aaya-Aspire-E1-531:~/Downloads/kdz# |
05-18-2018, 15:08 | #82 (permalink) |
Member: 2771305 Status: Offline Thanks Meter: 59 | The correct link is https://forum.xda-developers.com/g4/...-qfil-t3748946 |
05-18-2018, 16:09 | #83 (permalink) |
Member: 2837565 Status: Offline Thanks Meter: 0 | MultiTool is not recognizing my H872. Is my LG G6 H872 basically scrap now? It's still being seen as Qualcomm in Windows. Wish I could get it back to the default partitions and then load the KDZ via LG UP tool |
05-19-2018, 00:21 | #85 (permalink) |
Crazy Poster Join Date: Apr 2018
Member: 2828454 Status: Offline Thanks Meter: 14 | when i try to make your process i cannot write file in my sdc when i write the Primarygpt.gpt in my sdc the system create a sdc1 partition without nothing..this you want to help with this? |
05-21-2018, 22:50 | #86 (permalink) |
Member: 2828454 Status: Offline Thanks Meter: 14 | https://www.change.org/p/lg-electron...fications_page more we are and more lg will do somethink |
05-22-2018, 16:07 | #88 (permalink) |
Member: 2828454 Status: Offline Thanks Meter: 14 | no true i download from qualcomm site the official firehose for msm8996, the problem is that we cannot unbrick this device if we don't have the correct file as rawprogram.xml and patch.xml withou this file we are not able to unbrick the phone |
