LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
05-23-2018, 12:25 | #91 (permalink) |
Crazy Poster Join Date: Apr 2018
Member: 2828454 Status: Offline Thanks Meter: 14 | |
05-23-2018, 12:47 | #92 (permalink) | |
Freak Poster Join Date: Oct 2017 Location: Portugal Age: 41
Member: 2771305 Status: Offline Thanks Meter: 59 | Quote:
06-02-2018, 03:48 | #96 (permalink) |
Junior Member Join Date: Jun 2006
Member: 288400 Status: Offline Thanks Meter: 4 | medusa pro LG H873 - Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files LG H870 - Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files h872 tested please |
The Following User Says Thank You to chester_chato For This Useful Post: |
06-04-2018, 20:51 | #98 (permalink) |
Member: 288400 Status: Offline Thanks Meter: 4 | I mean, fix by jtag no in qualcomm 9008 mode LG H873 - Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files LG H870 - Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files h872 no found In medusa pro, with another model will it be possible? try to fix |
06-05-2018, 10:39 | #99 (permalink) | |
Member: 2771305 Status: Offline Thanks Meter: 59 | Quote: | |
06-07-2018, 05:27 | #100 (permalink) |
Member: 2828454 Status: Offline Thanks Meter: 14 | finaly i fix my h871 with octoplus pro jtag, succesfully unbrick it support repair with usb qualcomm 9008, i flashed with oreo h873 it support the h871 too..the problem now is the smartphone is switch on i can lissen music boot lg , vibration button when i click volume up and down but now the problem is that my lcd no display nothing and before hard brick show the display..i do know if this issue is because the motherboard lcd connector have a issue or is the lcd broken..or maybe is a problem made by unbrick device...for the h872 no work repair i try h870 and h873 and failed... Last edited by LGCLOTHY; 06-07-2018 at 05:33. |
06-13-2018, 21:37 | #103 (permalink) |
No Life Poster Join Date: Feb 2012 Location: Galway Ireland
Member: 1723443 Status: Offline Thanks Meter: 10 | Hi Guys I created dump files of each partition from a working h910pr with patched lgup as explained here https://forum.xda-developers.com/v20...-v10m-t3664500 and then i flashed it with h918 firmware and now im stuck in qdloader mode so would you know if there is a way of getting it fixed with some of those files that i saved with lgup before messing it up? Thanks |
