Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 05-23-2018, 12:25   #91 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
https://github.com/96boards/document...rd-recovery.md look this maybe can help :/
Old 05-23-2018, 12:47   #92 (permalink)
Member: 2771305
Thanks Meter: 59
Originally Posted by LGCLOTHY View Post
hahahaha... witch hunt!
Old 05-23-2018, 16:27   #93 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
there is the firehose msm8996 ufc inside the pack,this ufc is used also with xiaomi so i think there is no different firehose for this motherboad
Old 05-27-2018, 07:20   #94 (permalink)
Member: 2594814
Thanks Meter: 5
https://mega.nz/#!UJk1HYRQ!SMufYIICH...V-Bf8Xp8T6oD-M
The Following User Says Thank You to aaya6096 For This Useful Post:
Old 05-27-2018, 15:29   #95 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
can you do the same for the lg g6 h872-h871?
Old 06-02-2018, 03:48   #96 (permalink)
Member: 288400
Thanks Meter: 4
medusa pro
LG H873 - Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files
LG H870 - Read/Write/Full Erase, Easy Repair, Partition Manager, Constructor for Repair Files
h872 tested please
The Following User Says Thank You to chester_chato For This Useful Post:
Old 06-02-2018, 13:44   #97 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
medusa pro cannot repair smartphone in qualcomm 9008 mode...
Old 06-04-2018, 20:51   #98 (permalink)
Member: 288400
Thanks Meter: 4
I mean, fix by jtag no in qualcomm 9008 mode
h872 no found In medusa pro, with another model will it be possible? try to fix
Old 06-05-2018, 10:39   #99 (permalink)
Member: 2771305
Thanks Meter: 59
Originally Posted by aaya6096 View Post
Do you even read it? Here, on second post https://forum.xda-developers.com/v20...usb-t3740897#2
Old 06-07-2018, 05:27   #100 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
finaly i fix my h871 with octoplus pro jtag, succesfully unbrick it support repair with usb qualcomm 9008, i flashed with oreo h873 it support the h871 too..the problem now is the smartphone is switch on i can lissen music boot lg , vibration button when i click volume up and down but now the problem is that my lcd no display nothing and before hard brick show the display..i do know if this issue is because the motherboard lcd connector have a issue or is the lcd broken..or maybe is a problem made by unbrick device...for the h872 no work repair i try h870 and h873 and failed...
Old 06-07-2018, 10:30   #101 (permalink)
Member: 2771305
Thanks Meter: 59
Maybe...
And what about pin solder direct to the MMC, doesn't support as well?
Old 06-08-2018, 00:44   #102 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
no need it! support simple usb mode just click usb download svf for your model i use the h870 and then the phone repair...
Old 06-13-2018, 21:37   #103 (permalink)
Member: 1723443
Thanks Meter: 10
Hi Guys
I created dump files of each partition from a working h910pr with patched lgup as explained here https://forum.xda-developers.com/v20...-v10m-t3664500 and then i flashed it with h918 firmware and now im stuck in qdloader mode so would you know if there is a way of getting it fixed with some of those files that i saved with lgup before messing it up?
Thanks
Old 06-14-2018, 06:44   #104 (permalink)
Member: 169896
Thanks Meter: 323
When i tried it says sending loader and it failed . Can u make a simple youtube video to guide
Sent from my SM-G950W using Tapatalk
Old 06-18-2018, 01:14   #105 (permalink)
Crazy Poster
Member: 2828454
Thanks Meter: 14
you have to try different loader to me work only for the lg h871, with both loader..h873,h870 for my lg tmobile h872 i try but no working...it failed..
Page generated in 0.30754 seconds with 8 queries
