LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
11-27-2015, 20:10 | #31 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | |
11-27-2015, 20:48 | #32 (permalink) |
Freak Poster Join Date: Nov 2013
Member: 2058197 Status: Offline Thanks Meter: 32 | Thanks a lot bro, this was gonna get out sooner or later.. either you or the big boxes will be including it androidhero made his money, i paid him for the tool made my money back in the same day not complaining... time to move on to the next thing, this how this things works |
11-28-2015, 03:55 | #35 (permalink) |
Freak Poster Join Date: Nov 2012 Age: 38
Member: 1836541 Status: Offline Thanks Meter: 92 | Lol copy code android hero then made build by jusmejose If you want i teach you build Lol why copy paste edit then create tool by of jusmejose? |
The Following 3 Users Say Thank You to tungkick For This Useful Post: |
11-28-2015, 15:28 | #37 (permalink) |
Junior Member Join Date: Nov 2015
Member: 2492908 Status: Offline Thanks Meter: 4 | I'm going to copy Jose's copied program and call it "LG Google Verify Account Tool by 0oGhosto0" Last edited by 0oGhosto0; 11-28-2015 at 15:34. Reason: added "" |
The Following 4 Users Say Thank You to 0oGhosto0 For This Useful Post: |
11-29-2015, 14:38 | #41 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205304 Status: Offline Thanks Meter: 52 | BAT will be BAT.. exe maker wannabe Code: @echo off set cmdline= SHIFT /0 @echo off @echo off :inicio color 0b cls set maintile1= ============================================================ set maintile2= = LG Goolge Account Removal = set maintile3= = Created By JusMeJose = set maintile4= ============================================================ :Start cls echo. echo %maintile1% echo %maintile2% echo %maintile3% echo %maintile4% echo. echo 1. LG G4 - All Variants echo --------------------------------------------------------------------------- echo 2. LG G Flex/2 - All variants echo --------------------------------------------------------------------------- echo 3. LG G Stylo - Leon - Risio - All Variants echo --------------------------------------------------------------------------- echo 4. LG G4s Beat echo --------------------------------------------------------------------------- echo 5. EXIT echo *************************************************************************** echo. set /p var=Select your model: [1-5]: if "%var%"=="1" goto op1 if "%var%"=="2" goto op2 if "%var%"=="3" goto op3 if "%var%"=="4" goto op4 if "%var%"=="5" goto exit echo. "%var%" Wrong Model, Please select correct model!. echo. pause echo. goto inicio :op1 cls @echo off echo. echo ****Device detected**** for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" ( echo Serial port not found, please insert the phone manually into Download mode. echo. echo Disconnect the USB cable and turn off the phone. echo Then press and hold the Volume Up button, and while you're doing that connect the USB cable again. echo. echo. ) else ( echo. echo This might take a few minute....please wait... ) set comPath= :wait-for-download for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" goto wait-for-download echo. ping 127.0.0.1 -n 15 | echo off echo. bin\a.exe \\.\%comPath% < bin\vb echo. echo Google account Removed! echo Thank you for using my tool! echo Enter reboot now pause bin\a.exe \\.\%comPath% < bin\leave pause > nul | echo Press any key to exit... exit :op2 cls @echo off echo. echo ****Device detected**** for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" ( echo Serial port not found, please insert the phone manually into Download mode. echo. echo Disconnect the USB cable and turn off the phone. echo Then press and hold the Volume Up button, and while you're doing that connect the USB cable again. echo. echo. ) else ( echo. echo This might take a few minute....please wait... ) set comPath= :wait-for-download for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" goto wait-for-download echo. ping 127.0.0.1 -n 15 | echo off echo. bin\a.exe \\.\%comPath% < bin\te echo. echo Google account Removed! echo Thank you for using my tool! echo Enter reboot now pause bin\a.exe \\.\%comPath% < bin\leave pause > nul | echo Press any key to exit... exit :op3 cls @echo off echo. echo ****Device detected**** for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" ( echo Serial port not found, please insert the phone manually into Download mode. echo. echo Disconnect the USB cable and turn off the phone. echo Then press and hold the Volume Up button, and while you're doing that connect the USB cable again. echo. echo. ) else ( echo. echo This might take a few minute....please wait... ) set comPath= :wait-for-download for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" goto wait-for-download echo. ping 127.0.0.1 -n 15 | echo off echo. bin\a.exe \\.\%comPath% < bin\ne echo. echo Google account Removed! echo Thank you for using my tool! echo Enter reboot now pause bin\a.exe \\.\%comPath% < bin\leave pause > nul | echo Press any key to exit... exit :op4 cls @echo off echo. echo ****Device detected**** for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" ( echo Serial port not found, please insert the phone manually into Download mode. echo. echo Disconnect the USB cable and turn off the phone. echo Then press and hold the Volume Up button, and while you're doing that connect the USB cable again. echo. echo. ) else ( echo. echo This might take a few minute....please wait... ) set comPath= :wait-for-download for /f "tokens=2*" %%a in ('reg query HKLM\hardware\devicemap\SERIALCOMM /v \Device\LG*ANDNETDIAG* 2^>nul ^| find "REG_SZ" 2^>nul') do set "comPath=%%~b" if "%comPath%" == "" goto wait-for-download echo. ping 127.0.0.1 -n 15 | echo off echo. bin\a.exe \\.\%comPath% < bin\nz echo. echo Google account Removed! echo Thank you for using my tool! echo Enter reboot now pause bin\a.exe \\.\%comPath% < bin\leave pause > nul | echo Press any key to exit... exit :op5 :exit @cls&exit |
11-30-2015, 06:23 | #42 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | May someone will ask an LG for copyrights? He, he, he ... |
The Following User Says Thank You to debeliamark For This Useful Post: |
12-15-2015, 07:48 | #45 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2501194 Status: Offline Thanks Meter: 1 | Lg Risio from cricket how do you bypass google verification . my daughter don't remember her password. she got locked out so I factory reset her phone now im stuck on this screen . I just bought this phone a month and a half ago for her birthday. I took it to cricket they clueless. was there for a hour and didn't accomplish nothing |
The Following User Says Thank You to Fixxsation For This Useful Post: |
