LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
04-15-2018, 08:40 | #1 (permalink) |
No Life Poster Join Date: Aug 2011
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | f520s HANG ON KORIAN LANGUAGE i have flashed it with skt and sku firmwares but same what is solution pls help |
04-15-2018, 09:54 | #2 (permalink) |
Insane Poster Join Date: Feb 2010 Location: your mind
Member: 1234585 Status: Offline Sonork: gazi_321 Thanks Meter: 37 | call me lock its mabey many box suppoert remove it bro its lost phone ..... like Samsung call me lock https://s17.postimg.cc/gz004zcf3/Wha...2.48.35_PM.jpg |
The Following User Says Thank You to gazi_321 For This Useful Post: |
04-16-2018, 07:14 | #6 (permalink) |
Member: 1630066 Status: Offline Sonork: 520074 Thanks Meter: 215 | i solved by full erase main user area using EASY JTAG and write by vender log is here 15-Apr-18 8:02:25 PM> 15-Apr-18 8:02:25 PM> eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) 15-Apr-18 8:02:25 PM> Microsoft Windows 7 (32 bit) build 7601 (6.1.7601.18015) 15-Apr-18 8:02:25 PM> 15-Apr-18 8:02:25 PM> Looking for EasyJTAG box... 15-Apr-18 8:02:25 PM> EasyJTAG API ver. 2022 15-Apr-18 8:02:27 PM> OpenUSB returned = 0 15-Apr-18 8:02:28 PM> EasyJTAG Box Serial = 0A0050225B0FD73F 15-Apr-18 8:02:32 PM> Card Serial = AAF8-CE51 15-Apr-18 8:02:32 PM> CardAttr = 3B7F96000080318065B0850201F312FFFE829000 15-Apr-18 8:02:32 PM> EasyJTAG Box Firmware = 1.62 15-Apr-18 8:02:32 PM> 15-Apr-18 8:02:50 PM> Looking for EasyJTAG box... 15-Apr-18 8:02:50 PM> EasyJTAG API ver. 2022 15-Apr-18 8:02:50 PM> Setting IO Levels to 2.8V 15-Apr-18 8:02:50 PM> Setting frequence to 21 Mhz 15-Apr-18 8:02:50 PM> EasyJTAG Box Serial = 0A0050225B0FD73F 15-Apr-18 8:02:50 PM> EasyJTAG Box Firmware = 1.62 15-Apr-18 8:02:51 PM> HiPower mode is ON 15-Apr-18 8:02:51 PM> Setting frequence to 21 Mhz 15-Apr-18 8:02:51 PM> CMD Pullup Level: 165 mV 15-Apr-18 8:02:51 PM> CMD Active Level: 2578 mV 15-Apr-18 8:02:51 PM> eMMC Init returned = 0 15-Apr-18 8:02:51 PM> EMMC Device Information : 15-Apr-18 8:02:51 PM> EMMC CID: 11010030313647453200479D2669B12C 15-Apr-18 8:02:51 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 15-Apr-18 8:02:51 PM> EMMC Manufacture Name: TOSHIBA , EMMC NAME: 016GE2 , EMMC NAME (HEX): 303136474532 , S/N: 479D2669 , rev. 0x00 15-Apr-18 8:02:51 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2014 15-Apr-18 8:02:51 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 15-Apr-18 8:02:51 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 15-Apr-18 8:02:51 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 15-Apr-18 8:02:51 PM> EMMC Permanent Write Protection: No 15-Apr-18 8:02:51 PM> EMMC Temporary Write Protection: No 15-Apr-18 8:02:51 PM> Extended CSD Information : 15-Apr-18 8:02:51 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 15-Apr-18 8:02:51 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 15-Apr-18 8:02:51 PM> Boot Bus Config: 0x00 , width 1bit 15-Apr-18 8:02:51 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 15-Apr-18 8:02:51 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 15-Apr-18 8:02:51 PM> Device supports partitioning features 15-Apr-18 8:02:51 PM> Device can have enhanced technological features in partitions and user data area 15-Apr-18 8:02:51 PM> Device can have extended partitions attribute 15-Apr-18 8:02:51 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 15-Apr-18 8:02:51 PM> Backup saved: 016GE2_479D2669_20180415_200251.extcsd 15-Apr-18 8:02:51 PM> EMMC Init completed. 15-Apr-18 8:02:51 PM> 15-Apr-18 8:02:51 PM> Warning: Health report is very BAD 15-Apr-18 8:02:51 PM> 15-Apr-18 8:02:51 PM> Device Life Time Estimation (MLC) [269]: 0x00 Not defined 15-Apr-18 8:02:51 PM> Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used 15-Apr-18 8:02:51 PM> Pre EOL information [267]: 0x01 Normal 15-Apr-18 8:02:51 PM> 15-Apr-18 8:02:52 PM> Scanning soft partitions 15-Apr-18 8:02:52 PM> GPT header is found and is valid 15-Apr-18 8:02:52 PM> Partition: modem, [000000800000 - 000004800000], size: 000004000000 15-Apr-18 8:02:52 PM> Partition: sbl1, [000004800000 - 000004900000], size: 000000100000 15-Apr-18 8:02:52 PM> Partition: rpm, [000004900000 - 000004980000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: tz, [000004980000 - 000004A00000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: sdi, [000004A00000 - 000004A80000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: aboot, [000004A80000 - 000004C80000], size: 000000200000 15-Apr-18 8:02:52 PM> Partition: rpmb, [000004C80000 - 000004D00000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: tzb, [000004D00000 - 000004D80000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: abootb, [000004D80000 - 000004F80000], size: 000000200000 15-Apr-18 8:02:52 PM> Partition: pad, [000004F80000 - 000005180000], size: 000000200000 15-Apr-18 8:02:52 PM> Partition: modemst1, [000005180000 - 000005480000], size: 000000300000 15-Apr-18 8:02:52 PM> Partition: modemst2, [000005480000 - 000005780000], size: 000000300000 15-Apr-18 8:02:52 PM> Partition: misc, [000005780000 - 000006780000], size: 000001000000 15-Apr-18 8:02:52 PM> Partition: persist, [000006800000 - 000008800000], size: 000002000000 15-Apr-18 8:02:52 PM> Partition: laf, [000008800000 - 000009E00000], size: 000001600000 15-Apr-18 8:02:52 PM> Partition: boot, [00000A000000 - 00000B600000], size: 000001600000 15-Apr-18 8:02:52 PM> Partition: recovery, [00000B600000 - 00000CC00000], size: 000001600000 15-Apr-18 8:02:52 PM> Partition: fsg, [00000CC00000 - 00000CF00000], size: 000000300000 15-Apr-18 8:02:52 PM> Partition: fsc, [00000D000000 - 00000D080000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: ssd, [00000D080000 - 00000D100000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: DDR, [00000D800000 - 00000D880000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: encrypt, [00000E000000 - 00000E080000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: rct, [00000E080000 - 00000E100000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: drm, [00000E800000 - 00000F000000], size: 000000800000 15-Apr-18 8:02:52 PM> Partition: sns, [00000F000000 - 00000F800000], size: 000000800000 15-Apr-18 8:02:52 PM> Partition: factory, [00000F800000 - 000010C00000], size: 000001400000 15-Apr-18 8:02:52 PM> Partition: fota, [000010C00000 - 000012C00000], size: 000002000000 15-Apr-18 8:02:52 PM> Partition: sbl1b, [000013000000 - 000013100000], size: 000000100000 15-Apr-18 8:02:52 PM> Partition: mpt, [000013100000 - 000015100000], size: 000002000000 15-Apr-18 8:02:52 PM> Partition: blus, [000015100000 - 000015300000], size: 000000200000 15-Apr-18 8:02:52 PM> Partition: eksst, [000015300000 - 000015380000], size: 000000080000 15-Apr-18 8:02:52 PM> Partition: system, [000015800000 - 00009BC00000], size: 000086400000 15-Apr-18 8:02:52 PM> Partition: cache, [00009BC00000 - 0000D4000000], size: 000038400000 15-Apr-18 8:02:52 PM> Partition: userdata, [0000D4000000 - 00039A800000], size: 0002C6800000 15-Apr-18 8:02:52 PM> Partition: grow, [00039A800000 - 0003AB3FBE00], size: 000010BFBE00 15-Apr-18 8:02:52 PM> GPT header successfully parsed 15-Apr-18 8:02:52 PM> 15-Apr-18 8:02:52 PM> Get firmware version 15-Apr-18 8:02:52 PM> 15-Apr-18 8:02:53 PM> Brand = lge 15-Apr-18 8:02:54 PM> Manufacturer = LGE 15-Apr-18 8:02:54 PM> Model = LG-F520S 15-Apr-18 8:02:54 PM> Phone platform = msm8226 15-Apr-18 8:02:54 PM> CPU Abi = armeabi-v7a 15-Apr-18 8:02:54 PM> Android release = 5.0.2 15-Apr-18 8:02:54 PM> Firmware version = LRX22G 15-Apr-18 8:02:54 PM> Firmware date = Fri Apr 17 16:35:30 KST 2015 15-Apr-18 8:03:08 PM> 15-Apr-18 8:03:08 PM> Looking for EasyJTAG box... 15-Apr-18 8:03:08 PM> EasyJTAG API ver. 2022 15-Apr-18 8:03:08 PM> Setting IO Levels to 2.8V 15-Apr-18 8:03:08 PM> Setting frequence to 21 Mhz 15-Apr-18 8:03:08 PM> EasyJTAG Box Serial = 0A0050225B0FD73F 15-Apr-18 8:03:08 PM> EasyJTAG Box Firmware = 1.62 15-Apr-18 8:03:10 PM> HiPower mode is ON 15-Apr-18 8:03:10 PM> Setting frequence to 21 Mhz 15-Apr-18 8:03:10 PM> CMD Pullup Level: 165 mV 15-Apr-18 8:03:10 PM> CMD Active Level: 2526 mV 15-Apr-18 8:03:10 PM> eMMC Init returned = 0 15-Apr-18 8:03:10 PM> EMMC Device Information : 15-Apr-18 8:03:10 PM> EMMC CID: 11010030313647453200479D2669B12C 15-Apr-18 8:03:10 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 15-Apr-18 8:03:10 PM> EMMC Manufacture Name: TOSHIBA , EMMC NAME: 016GE2 , EMMC NAME (HEX): 303136474532 , S/N: 479D2669 , rev. 0x00 15-Apr-18 8:03:10 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2014 15-Apr-18 8:03:10 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 15-Apr-18 8:03:10 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 15-Apr-18 8:03:10 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 15-Apr-18 8:03:10 PM> EMMC Permanent Write Protection: No 15-Apr-18 8:03:10 PM> EMMC Temporary Write Protection: No 15-Apr-18 8:03:10 PM> Extended CSD Information : 15-Apr-18 8:03:10 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 15-Apr-18 8:03:10 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 15-Apr-18 8:03:10 PM> Boot Bus Config: 0x00 , width 1bit 15-Apr-18 8:03:10 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 15-Apr-18 8:03:10 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 15-Apr-18 8:03:10 PM> Device supports partitioning features 15-Apr-18 8:03:10 PM> Device can have enhanced technological features in partitions and user data area 15-Apr-18 8:03:10 PM> Device can have extended partitions attribute 15-Apr-18 8:03:10 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 15-Apr-18 8:03:10 PM> Backup saved: 016GE2_479D2669_20180415_200310.extcsd 15-Apr-18 8:03:10 PM> EMMC Init completed. 15-Apr-18 8:03:10 PM> 15-Apr-18 8:03:10 PM> Warning: Health report is very BAD 15-Apr-18 8:03:10 PM> 15-Apr-18 8:03:10 PM> Device Life Time Estimation (MLC) [269]: 0x00 Not defined 15-Apr-18 8:03:10 PM> Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used 15-Apr-18 8:03:10 PM> Pre EOL information [267]: 0x01 Normal 15-Apr-18 8:03:10 PM> 15-Apr-18 8:03:10 PM> Erasing for: ROM1 , start: 0x000000000000 , size: 0x0003AB400000 15-Apr-18 8:03:10 PM> eMMC switching to ROM1 15-Apr-18 8:03:10 PM> Erasing partition... 15-Apr-18 8:13:03 PM> Done erasing partition. 15-Apr-18 8:13:03 PM> 15-Apr-18 8:13:13 PM> Looking for EasyJTAG box... 15-Apr-18 8:13:13 PM> EasyJTAG API ver. 2022 15-Apr-18 8:13:13 PM> Setting IO Levels to 2.8V 15-Apr-18 8:13:13 PM> Setting frequence to 21 Mhz 15-Apr-18 8:13:13 PM> EasyJTAG Box Serial = 0A0050225B0FD73F 15-Apr-18 8:13:13 PM> EasyJTAG Box Firmware = 1.62 15-Apr-18 8:13:14 PM> HiPower mode is ON 15-Apr-18 8:13:14 PM> Setting frequence to 21 Mhz 15-Apr-18 8:13:14 PM> CMD Pullup Level: 175 mV 15-Apr-18 8:13:14 PM> CMD Active Level: 2516 mV 15-Apr-18 8:13:14 PM> eMMC Init returned = 0 15-Apr-18 8:13:14 PM> EMMC Device Information : 15-Apr-18 8:13:14 PM> EMMC CID: 11010030313647453200479D2669B12C 15-Apr-18 8:13:14 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 15-Apr-18 8:13:14 PM> EMMC Manufacture Name: TOSHIBA , EMMC NAME: 016GE2 , EMMC NAME (HEX): 303136474532 , S/N: 479D2669 , rev. 0x00 15-Apr-18 8:13:14 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2014 15-Apr-18 8:13:14 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 15-Apr-18 8:13:14 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 15-Apr-18 8:13:14 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 15-Apr-18 8:13:14 PM> EMMC Permanent Write Protection: No 15-Apr-18 8:13:14 PM> EMMC Temporary Write Protection: No 15-Apr-18 8:13:14 PM> Extended CSD Information : 15-Apr-18 8:13:14 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 15-Apr-18 8:13:14 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 15-Apr-18 8:13:14 PM> Boot Bus Config: 0x00 , width 1bit 15-Apr-18 8:13:14 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 15-Apr-18 8:13:14 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 15-Apr-18 8:13:14 PM> Device supports partitioning features 15-Apr-18 8:13:14 PM> Device can have enhanced technological features in partitions and user data area 15-Apr-18 8:13:14 PM> Device can have extended partitions attribute 15-Apr-18 8:13:14 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 15-Apr-18 8:13:14 PM> Backup saved: 016GE2_479D2669_20180415_201314.extcsd 15-Apr-18 8:13:14 PM> EMMC Init completed. 15-Apr-18 8:13:14 PM> 15-Apr-18 8:13:14 PM> Warning: Health report is very BAD 15-Apr-18 8:13:14 PM> 15-Apr-18 8:13:14 PM> Device Life Time Estimation (MLC) [269]: 0x00 Not defined 15-Apr-18 8:13:14 PM> Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used 15-Apr-18 8:13:14 PM> Pre EOL information [267]: 0x01 Normal 15-Apr-18 8:13:14 PM> 15-Apr-18 8:13:14 PM> Opening file: F:\FLASH FILES\ANDROID ROMS\LG\F520S\F520S20G_00 SKU\F520S20G_00.kdz 15-Apr-18 8:13:14 PM> 15-Apr-18 8:13:14 PM> Filename: F520S20G_00.kdz 15-Apr-18 8:13:15 PM> Model: LG-F520S 15-Apr-18 8:13:15 PM> Software: F520S20g 15-Apr-18 8:13:15 PM> BuildTime: 0000-00-00 00:00:00 15-Apr-18 8:13:15 PM> Total Files: 41 15-Apr-18 8:13:15 PM> 15-Apr-18 8:13:15 PM> The size of the last section has been updated 15-Apr-18 8:14:00 PM> 15-Apr-18 8:14:00 PM> Looking for EasyJTAG box... 15-Apr-18 8:14:00 PM> EasyJTAG API ver. 2022 15-Apr-18 8:14:00 PM> Setting IO Levels to 2.8V 15-Apr-18 8:14:00 PM> Setting frequence to 21 Mhz 15-Apr-18 8:14:00 PM> EasyJTAG Box Serial = 0A0050225B0FD73F 15-Apr-18 8:14:00 PM> EasyJTAG Box Firmware = 1.62 15-Apr-18 8:14:01 PM> HiPower mode is ON 15-Apr-18 8:14:01 PM> Setting frequence to 21 Mhz 15-Apr-18 8:14:01 PM> CMD Pullup Level: 165 mV 15-Apr-18 8:14:01 PM> CMD Active Level: 2516 mV 15-Apr-18 8:14:01 PM> eMMC Init returned = 0 15-Apr-18 8:14:01 PM> EMMC Device Information : 15-Apr-18 8:14:01 PM> EMMC CID: 11010030313647453200479D2669B12C 15-Apr-18 8:14:01 PM> EMMC CSD: D05E00320F5903FFFFFFFFEF924000D2 15-Apr-18 8:14:01 PM> EMMC Manufacture Name: TOSHIBA , EMMC NAME: 016GE2 , EMMC NAME (HEX): 303136474532 , S/N: 479D2669 , rev. 0x00 15-Apr-18 8:14:01 PM> EMMC Manufacture ID: 0x11 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Manufacture Date: 11/2014 15-Apr-18 8:14:01 PM> EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) 15-Apr-18 8:14:01 PM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 15-Apr-18 8:14:01 PM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 15-Apr-18 8:14:01 PM> EMMC Permanent Write Protection: No 15-Apr-18 8:14:01 PM> EMMC Temporary Write Protection: No 15-Apr-18 8:14:01 PM> Extended CSD Information : 15-Apr-18 8:14:01 PM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 15-Apr-18 8:14:01 PM> Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot 15-Apr-18 8:14:01 PM> Boot Bus Config: 0x00 , width 1bit 15-Apr-18 8:14:01 PM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 15-Apr-18 8:14:01 PM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 15-Apr-18 8:14:01 PM> Device supports partitioning features 15-Apr-18 8:14:01 PM> Device can have enhanced technological features in partitions and user data area 15-Apr-18 8:14:01 PM> Device can have extended partitions attribute 15-Apr-18 8:14:01 PM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 15-Apr-18 8:14:01 PM> Backup saved: 016GE2_479D2669_20180415_201401.extcsd 15-Apr-18 8:14:01 PM> EMMC Init completed. 15-Apr-18 8:14:01 PM> 15-Apr-18 8:14:01 PM> Warning: Health report is very BAD 15-Apr-18 8:14:01 PM> 15-Apr-18 8:14:01 PM> Device Life Time Estimation (MLC) [269]: 0x00 Not defined 15-Apr-18 8:14:01 PM> Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used 15-Apr-18 8:14:01 PM> Pre EOL information [267]: 0x01 Normal 15-Apr-18 8:14:01 PM> 15-Apr-18 8:14:01 PM> Operation: Write by vendor (LG) 15-Apr-18 8:14:01 PM> 15-Apr-18 8:14:01 PM> Creating GPT-partitioninig 15-Apr-18 8:14:02 PM> GPT-partitioning done 15-Apr-18 8:14:02 PM> 15-Apr-18 8:14:02 PM> Filename: F520S20G_00.kdz 15-Apr-18 8:14:02 PM> Model: LG-F520S 15-Apr-18 8:14:02 PM> Software: F520S20g 15-Apr-18 8:14:02 PM> BuildTime: 0000-00-00 00:00:00 15-Apr-18 8:14:02 PM> Total Files: 41 15-Apr-18 8:14:02 PM> 15-Apr-18 8:14:02 PM> Unpacking files from the firmware. Please wait ... 15-Apr-18 8:14:05 PM> Unpack done 15-Apr-18 8:14:05 PM> 15-Apr-18 8:14:05 PM> Partition name: MODEM 15-Apr-18 8:14:05 PM> Filename: modem_16384.bin , Offset: 000000800000 , filesize: 56098816 bytes 15-Apr-18 8:14:05 PM> eMMC switching to ROM1 15-Apr-18 8:14:05 PM> Erasing partition... 15-Apr-18 8:14:08 PM> Writing partition... 15-Apr-18 8:15:15 PM> Done writing partition. Write speed: 823.89 KB/s 15-Apr-18 8:15:15 PM> Partition name: SBL1 15-Apr-18 8:15:15 PM> Filename: sbl1_147456.bin , Offset: 000004800000 , filesize: 524288 bytes 15-Apr-18 8:15:15 PM> eMMC switching to ROM1 15-Apr-18 8:15:15 PM> Erasing partition... 15-Apr-18 8:15:15 PM> Writing partition... 15-Apr-18 8:15:16 PM> Done writing partition. Write speed: 844.51 KB/s 15-Apr-18 8:15:16 PM> Partition name: RPM 15-Apr-18 8:15:16 PM> Filename: rpm_149504.bin , Offset: 000004900000 , filesize: 524288 bytes 15-Apr-18 8:15:16 PM> eMMC switching to ROM1 15-Apr-18 8:15:16 PM> Erasing partition... 15-Apr-18 8:15:17 PM> Writing partition... 15-Apr-18 8:15:17 PM> Done writing partition. Write speed: 823.04 KB/s 15-Apr-18 8:15:17 PM> Partition name: TZ 15-Apr-18 8:15:17 PM> Filename: tz_150528.bin , Offset: 000004980000 , filesize: 524288 bytes 15-Apr-18 8:15:17 PM> eMMC switching to ROM1 15-Apr-18 8:15:17 PM> Erasing partition... 15-Apr-18 8:15:18 PM> Writing partition... 15-Apr-18 8:15:19 PM> Done writing partition. Write speed: 848.95 KB/s 15-Apr-18 8:15:19 PM> Partition name: SDI 15-Apr-18 8:15:19 PM> Filename: sdi_151552.bin , Offset: 000004A00000 , filesize: 524288 bytes 15-Apr-18 8:15:19 PM> eMMC switching to ROM1 15-Apr-18 8:15:19 PM> Erasing partition... 15-Apr-18 8:15:19 PM> Writing partition... 15-Apr-18 8:15:20 PM> Done writing partition. Write speed: 859.15 KB/s 15-Apr-18 8:15:20 PM> Partition name: ABOOT 15-Apr-18 8:15:20 PM> Filename: aboot_152576.bin , Offset: 000004A80000 , filesize: 1048576 bytes 15-Apr-18 8:15:20 PM> eMMC switching to ROM1 15-Apr-18 8:15:20 PM> Erasing partition... 15-Apr-18 8:15:21 PM> Writing partition... 15-Apr-18 8:15:22 PM> Done writing partition. Write speed: 841.26 KB/s 15-Apr-18 8:15:22 PM> Partition name: RPMB 15-Apr-18 8:15:22 PM> Filename: rpmb_156672.bin , Offset: 000004C80000 , filesize: 524288 bytes 15-Apr-18 8:15:22 PM> eMMC switching to ROM1 15-Apr-18 8:15:22 PM> Erasing partition... 15-Apr-18 8:15:23 PM> Writing partition... 15-Apr-18 8:15:23 PM> Done writing partition. Write speed: 745.33 KB/s 15-Apr-18 8:15:23 PM> Partition name: TZB 15-Apr-18 8:15:23 PM> Filename: tzb_157696.bin , Offset: 000004D00000 , filesize: 524288 bytes 15-Apr-18 8:15:23 PM> eMMC switching to ROM1 15-Apr-18 8:15:24 PM> Erasing partition... 15-Apr-18 8:15:24 PM> Writing partition... 15-Apr-18 8:15:25 PM> Done writing partition. Write speed: 879.09 KB/s 15-Apr-18 8:15:25 PM> Partition name: ABOOTB 15-Apr-18 8:15:25 PM> Filename: abootb_158720.bin , Offset: 000004D80000 , filesize: 1048576 bytes 15-Apr-18 8:15:25 PM> eMMC switching to ROM1 15-Apr-18 8:15:25 PM> Erasing partition... 15-Apr-18 8:15:25 PM> Writing partition... 15-Apr-18 8:15:27 PM> Done writing partition. Write speed: 845.96 KB/s 15-Apr-18 8:15:27 PM> Partition name: PERSIST 15-Apr-18 8:15:27 PM> Filename: persist_212992.bin , Offset: 000006800000 , filesize: 5242880 bytes 15-Apr-18 8:15:27 PM> eMMC switching to ROM1 15-Apr-18 8:15:27 PM> Erasing partition... 15-Apr-18 8:15:28 PM> Writing partition... 15-Apr-18 8:15:34 PM> Done writing partition. Write speed: 829.43 KB/s 15-Apr-18 8:15:34 PM> Partition name: LAF 15-Apr-18 8:15:34 PM> Filename: laf_278528.bin , Offset: 000008800000 , filesize: 12582912 bytes 15-Apr-18 8:15:34 PM> eMMC switching to ROM1 15-Apr-18 8:15:34 PM> Erasing partition... 15-Apr-18 8:15:35 PM> Writing partition... 15-Apr-18 8:15:50 PM> Done writing partition. Write speed: 829.06 KB/s 15-Apr-18 8:15:50 PM> Partition name: BOOT 15-Apr-18 8:15:50 PM> Filename: boot_327680.bin , Offset: 00000A000000 , filesize: 8912896 bytes 15-Apr-18 8:15:50 PM> eMMC switching to ROM1 15-Apr-18 8:15:50 PM> Erasing partition... 15-Apr-18 8:15:51 PM> Writing partition... 15-Apr-18 8:16:01 PM> Done writing partition. Write speed: 824.04 KB/s 15-Apr-18 8:16:01 PM> Partition name: RECOVERY 15-Apr-18 8:16:01 PM> Filename: recovery_372736.bin , Offset: 00000B600000 , filesize: 9437184 bytes 15-Apr-18 8:16:01 PM> eMMC switching to ROM1 15-Apr-18 8:16:02 PM> Erasing partition... 15-Apr-18 8:16:03 PM> Writing partition... 15-Apr-18 8:16:14 PM> Done writing partition. Write speed: 830.78 KB/s 15-Apr-18 8:16:14 PM> Partition name: RCT 15-Apr-18 8:16:14 PM> Filename: rct_459776.bin , Offset: 00000E080000 , filesize: 524288 bytes 15-Apr-18 8:16:14 PM> eMMC switching to ROM1 15-Apr-18 8:16:14 PM> Erasing partition... 15-Apr-18 8:16:15 PM> Writing partition... 15-Apr-18 8:16:15 PM> Done writing partition. Write speed: 745.91 KB/s 15-Apr-18 8:16:15 PM> Partition name: FACTORY 15-Apr-18 8:16:15 PM> Filename: factory_507904.bin , Offset: 00000F800000 , filesize: 11534336 bytes 15-Apr-18 8:16:15 PM> eMMC switching to ROM1 15-Apr-18 8:16:15 PM> Erasing partition... 15-Apr-18 8:16:17 PM> Writing partition... 15-Apr-18 8:16:30 PM> Done writing partition. Write speed: 828.02 KB/s 15-Apr-18 8:16:30 PM> Partition name: SBL1B 15-Apr-18 8:16:30 PM> Filename: sbl1b_622592.bin , Offset: 000013000000 , filesize: 524288 bytes 15-Apr-18 8:16:30 PM> eMMC switching to ROM1 15-Apr-18 8:16:30 PM> Erasing partition... 15-Apr-18 8:16:31 PM> Writing partition... 15-Apr-18 8:16:32 PM> Done writing partition. Write speed: 760.78 KB/s 15-Apr-18 8:16:32 PM> 15-Apr-18 8:16:32 PM> All done time: [00:02:26:978] 15-Apr-18 8:16:32 PM> |
