Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 03-14-2016, 14:31   #1 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,158
LG Leon H345 & MS345 Network Searching problem after Reset Mobile from Settings.
LG Leon H345 (T-Mobile) & MS345 (Metro PCs) Network Searching problem after Reset Mobile from Settings.
01. These Mobile was Locked By Operator.
02. Then Use Device Unlock App from Mobile to "Permanent Unlock" for Unlock it.
03. It Showed "Unlock Approved : Mobile device is permanent unlocked" Restart Now.
04. then after 2-3 days using sim, it was work fine. but when it reset from setting. now show "Searching" only. ( I have Three Mobile like this, 2 pcs is H345 ( T-Mobile ) 1 pcs is MS345 ( Metro PCs ).
05. I was Flashed mobile with same version firmware, and try to Unlock again via "Device app Unlock" but not solved.
06. Need Solution for this Problem.
The Following User Says Thank You to razib143 For This Useful Post:
Old 03-14-2016, 16:06   #2 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 64
I have same problem here... with several ms345
Old 03-15-2016, 01:26   #3 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 347
Maybe are blacklisted at tmobile (also check worldwide database), over here looks like only one carrier allow such phones.
Old 03-15-2016, 09:30   #4 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,158
Exclamation
If These phones are Blacklisted, then why they Approved Unlock via there Server by Dollar Cost?
Old 03-18-2016, 09:39   #5 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,158
any Solution for this Network Problem?.... UP....
Old 03-18-2016, 09:46   #6 (permalink)
david-gsm's Avatar
Member: 1890645
Sonork: 100.1627104
Thanks Meter: 365
hi
try change imei?
maybe work
Old 03-18-2016, 19:07   #7 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 64
Doesnt works changing imei...tried, also tried flashing, updating android to latest version, but same result
Old 03-19-2016, 01:41   #8 (permalink)
shahsoft's Avatar
Member: 2302076
Sonork: 100.1663298
Thanks Meter: 182
Also tried many qcn but no solve anyone repair it??
Shahzaib Jahangir
Old 03-19-2016, 02:21   #9 (permalink)
Cheater -Don't Deal with him-
Member: 452256
Sonork: 100.1651051
Thanks Meter: 585
I face same problem 2 phones unlocked and sfter reset network searching
Where is the problem and who can help ?
Old 03-27-2016, 04:08   #10 (permalink)
Member: 2550682
Thanks Meter: 2
LG Leon H345 & MS345 Network Fail
As I have understood this is the best forum phones in the world. I will bring my experience with this model. First of all I want to note that this model has an engineer menu from which you can observe several operating parameters. The access code is 277634 engineer menu # * # there you can see the ID of the cell, and the status of all parameters of the GSM modem. What I have observed in models that fail to connect is that they are not able to correctly identify the ARM canal, nor are capable of indicating the level of GSM signal reception and not perform network registration. All these failures occur a few days after the phone is unlocked. I've tried flashing, write QCN, hard reset, put another SIM. It was not possible to repair the connection. Unfortunately I did not keep the log radius of this phone but would be a helpful tool that GSM specialist analyze the log that creates this phone about the operation of radio. Maybe someone in the forum could provide a log.
The Following 2 Users Say Thank You to raudelroque For This Useful Post:
Old 03-31-2016, 04:48   #11 (permalink)
Member: 1892086
Sonork: 1671742
Thanks Meter: 255
same problem here with 18 pcs
Old 04-08-2016, 14:43   #12 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,211
any 1 success repair Network Searching problem
Old 04-19-2016, 17:09   #13 (permalink)
yusniel's Avatar
Member: 1537172
Thanks Meter: 64
Up Up...still searching for solution
Old 05-03-2016, 06:48   #14 (permalink)
Member: 1622774
Sonork: 34610
Thanks Meter: 17
My ms345 same problem ,any 1 give soulation ,please
Old 05-10-2016, 07:58   #15 (permalink)
Member: 2570898
Thanks Meter: 2
I have bought online H345 t-mobile usa phone. Since I live in Serbia - Europe, I have done unlocking via device unlock app. Phone was working normaly 2-3 days, than it restarted by itself and got stuck on network search. Than I noticed in some parts of town it can register to a network and works normaly, and than, when I move away from that area it lose network again. Please help...
The Following 2 Users Say Thank You to atahuallpa For This Useful Post:
Page generated in 0.39679 seconds with 7 queries
