LG Nexus 4 hard reset LG E960 If you forgot your LG E960 unlock pattern password. Recovery solution for LG Nexus4Â Android phone At the same time press and hold Volume Down Key + Power/Lock Key.. When phone vibrates, release keys and repeatedly tap the Back Key + Home Key until the green Android Robot animation appears. NOTE: All data will be lost! Thank you GSM.. |
i have LG Nexus4 after power ON shows.....Type Password to decrypt storage......i did Wipe/Factory Reset....but still asking for Password to decrypt storage......how i can rid out of it....Thanks |
volume down + volume up + power key phone go to recovery mode.:p:p |
1. Power off your phone. 2. Press and hold Volume Down, and then press the Power button until the device turns on (while still pressing Volume Down). You will see the word Start with an arrow drawn around it. 3. Press Volume Down twice to designate Recovery mode. 4. Press the Power button to restart into Recovery mode. You will see an image of an Android robot with a red exclamation mark. 5. While holding down the Power button, press and release Volume Up. 6. Use the volume keys to scroll to wipe data/factory reset and press the Power button to select it. 7. Scroll down to Yes - erase all user data and press the Power button to select it. Your device will reset to factory settings. |
i need a way to remove pin without losing data |
thanks brother i have solve problem in my lg E960 mobile by your help |
