LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
03-27-2013, 08:44 | #1 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Philippines
Member: 1777400 Status: Offline Sonork: 100.86843 Thanks Meter: 50 | LG-Optimus E612 Hard Reset!!! power off the phone,press vol.down + power on If the soft touch lights, release vol.down & Power tap home for 3 secs. and the phone will power on and process hard reset do not touch the phone w8 until the phone will reboot screenshots done! hope it helps |
The Following 3 Users Say Thank You to rhedlj_88 For This Useful Post: |
11-22-2013, 08:53 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Using the hard reset aka factory reset Optimus L5, resetting LG E610, reset LG E612, reset E451g When the phone is switched off, press and hold the Volume down key + Power key with your left hand. When the LED on the bottom of the phone lights up, release Volume down key + Power keys and press and hold the Home key (for about 2 seconds) at the same time. The phone will turn on and perform a factory reset immediately. Do not operate your phone for at least a minute, while the hard reset is carried out. You will then be able to switch your phone back on. If you perform a hard reset, all user applications, user data and DRM licences will be deleted. Please remember to back up any important data before performing a Hard Reset. How to reset LG Optimus L5 hard reset To reset your LG Optimus L5 hard reset phone to factory settings and erase all the data on your phone, Select Settings → Back up and reset→ Factory data reset → Reset device→ Delete all. Resetting the Andorid phone does not erase any system software updates you have downloaded or any files on your microSD card, such as music or photos. If you reset the phone in this way, you are prompted to re-enter the same information that you did when you first started Android. or You can use LG Mobile Support tool to repair your LG cell phone, after download select menu Customer Support > Recovery Phone Go to Support > Mobile Phone Support > Select the Model (LG-E617g). L5 |
The Following 2 Users Say Thank You to khem For This Useful Post: |
11-22-2013, 12:51 | #3 (permalink) |
No Life Poster Join Date: Mar 2013 Location: NewYork Age: 32
Member: 1900437 Status: Offline Thanks Meter: 113 | I would rather prefer you to use LG mobile support !! you can download it from LG support section like Khem has said !! |
The Following User Says Thank You to Promo87 For This Useful Post: |
03-27-2018, 17:43 | #7 (permalink) |
Freak Poster Join Date: Apr 2015 Location: @kilinochchi, Sri Lanka
Member: 2372779 Status: Offline Sonork: 100.1680276 Thanks Meter: 33 | LG-E612 Hrd Reset and Write Firmware with Octoplus not done Hi Octoplus LG Module My device LG-E612 its was unfortunately "some apps name" has been stoped working, this is the problem. Then i do first Factory reset via phone setting after reset successfully user data is not deleted and has been the same issue. Then i do write firmware download from Octoplus LG module download area then i flash it successfully after flash the device ist same issue no deleted anything i'm full tired to solve it plz help me Octoplus Team By-Thina |
07-18-2018, 11:59 | #8 (permalink) | |
Insane Poster Join Date: Sep 2010
Member: 1394213 Status: Offline Thanks Meter: 11 | Same her, i think is a memory ploblem. Write proctected or something Quote:
