LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
02-12-2013, 05:53 | #1 (permalink) |
Junior Member Join Date: Sep 2012 Location: dhaKa.BD Age: 36
Member: 1814355 Status: Offline Sonork: 100.1604958 Thanks Meter: 26 | LG P970 (P970H) unbrick/flash using SmartFlash Tool Phone will make Factory Reset at first boot after flashing! You can upgrade and downgrade. You can downgrade from V20N too! This also will remove phone lock if you forget unlock code or pattern. (phone lock, NOT simlock or network lock...) This method doesn't need internet connection. If you want to flash an LG P970H download correct ROM from link below. |
02-12-2013, 05:55 | #2 (permalink) |
Member: 1814355 Status: Offline Sonork: 100.1604958 Thanks Meter: 26 | Downloads: - SmartFlash Tool (mirror) [password: radkor@XDA] - stock ROM V10A EEU XXX with .bin & .fls. [CRC MD5: d880b8834400575b5827bafbf29a745e] - DepositFiles, FileServe, WUpload. Other bin/fls ROMs are HERE. You need to install LG Mobile drivers. They are located HERE. [CRC MD5: e4614071e72c0292d3a8238908b5c7ba] 1. Unpack SFT.rar that contains SmartFlash Tool program. 2. Unpack, preffered C: drive, firmware pack BIN_LGP970AT-00-V10a-EEU-XXX-MAY-09-2011_0.zip Inside there will be 2 files: LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_AP.bin i LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_CP.fls. 3. Run B_SmartFlashTool_Extern.exe 4. Choose: 1) ROM copy D/L bookmark 2) in Select mode choose Normal mode 3) choose CP file: LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_CP.fls 4) choose AP file: LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_AP.bin *) connect phone in S/W Update mode with battery in it (on the phone that is switched off, plug in USB cable WHILE HOLDING Vol+ button) 5) choose COM port. 6) choose LGE Mobile USB Serial Port in Communication Driver 7) click Start and wait till end. It takes about 3 mins to flash. After successfully flashing, phone will reboot and make Factory Reset. And that's all! |
The Following User Says Thank You to Bl@cK_MooN For This Useful Post: |
02-12-2013, 05:57 | #3 (permalink) |
Member: 1814355 Status: Offline Sonork: 100.1604958 Thanks Meter: 26 | Settings: Flashing: Finished: Now your phone should be unbricked and working. I will not take any responsibility if something goes wrong when you trying this solution. For me and many others it worked well. |
02-06-2015, 04:26 | #14 (permalink) |
No Life Poster Join Date: Dec 2007 Location: DHARAMPUR<GUJRAT>INDIA
Member: 646646 Status: Offline Sonork: 100.1664464 Thanks Meter: 240 | LG P970 (P970H) unbrick/flash using SmartFlash Tool SFT .RAR LINK NOT WORKING ALL POST LINK IS REPEAT POST THANK YOU |
The Following User Says Thank You to him82 For This Useful Post: |
