Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 12-10-2011, 05:34   #1 (permalink)
RIJAS2010's Avatar
Member: 1417101
Sonork: 100.1619006
Thanks Meter: 152
Lg p970 pattern lock
CAN I UNLOCK LG P970 PATTERN LOCK .
1 Switch off the phone, take out the battery and reinsert back in.
2 Hold the home and volume down button.
3 Hold the power button until phone turns on.
4 Follow the instructions on-screen.
i already try this method but same . any other solution .please help me ...
Old 05-18-2013, 13:36   #2 (permalink)
Member: 1593885
Sonork: 1652227:mobile
Thanks Meter: 7
hi bro i will also same problum ''' but i will try in ufs-3 lg open and chose t310 rj 45 cable w-300 conect the phone factry reset done its 1000000% working i will try it sucess
Old 05-18-2013, 15:22   #3 (permalink)
Member: 541042
Thanks Meter: 518
Select Phone Kp100 and cabel kp100 100% Wiorking
The Following User Says Thank You to wolfgang1502 For This Useful Post:
Old 05-26-2013, 07:56   #4 (permalink)
Member: 1946517
not working so plz give me any other format
Old 05-26-2013, 08:02   #5 (permalink)
GSM_PHILIPPINES's Avatar
Member: 1778770
Thanks Meter: 105
used octopus box
follow this procedure..
select T310 model in phone model list, selct correct (box) COM port, power phone on, connect it via Micro UART cable not usb cable, hit "Factory reset"
Old 05-27-2013, 06:09   #6 (permalink)
Adityaram's Avatar
Member: 576025
Sonork: meghalaya_459
Thanks Meter: 125
try this,
hard reset LG P970 with HWK
Old 05-27-2013, 06:30   #7 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 889
Use z3x lg box
select model kp110
and just factory reset.
Ur problem will solve
Old 05-28-2013, 20:04   #8 (permalink)
RIJAS2010's Avatar
Member: 1417101
Sonork: 100.1619006
Thanks Meter: 152
12-10-11, 10:04
check date
my problem solved
Lg p970 optimus flashing guide
also i create new post for how to do flashing and unlocking
Old 08-04-2013, 09:25   #9 (permalink)
Member: 1731300
Thanks Meter: 16
1. Use Octoplus Lg
2. Press 'Reset SCreen lock'
3. no need factory reset
4. no lost data
Old 08-27-2013, 11:49   #10 (permalink)
Member: 1101297
Thanks Meter: 3
Welcome to Octoplus/Octopus Box LG Software version 1.2.4
Platform: LG Infineon
Connection mode: OMAP
Selected model: P970
Please, disconnect battery and connect P999 cable (with 910k resistor).
Initializing device...OK
Connecting to application CPU...OK
Checking partition...
Checking partition failed!
Selected port: COM8
Looking for phone...Failed!
Disconnected.
Please, reboot the phone manually.
Checking partition...OK
Resetting Screen Lock...OK
Resetting screen lock successfully completed!
Disconnected.
Old 03-25-2014, 07:35   #11 (permalink)
Member: 1198046
Thanks Meter: 11
hi guys .......
its possible to hard reset lg p970
try this methode
1 press and hold the volume down: home button and g button....
2 then hold the power button when lg logo appers relese the power button............
Autometically it was hard reset ......
enjoy
Old 03-25-2014, 07:41   #12 (permalink)
Member: 2087036
Sonork: 100.1646084
try with this tool I've done many p970 using this tool.
((android multi tools_1.0 by azimbahar ( one-man) parvez))
Old 03-26-2014, 14:00   #13 (permalink)
Member: 1645482
Help please how to repair LG-P925 short-circuit (batteries +and- connectors are in shot-circuit)
Old 04-09-2014, 16:17   #14 (permalink)
Member: 300760
Thanks Meter: 2
lgp970 pattern lock done by vygis tool box.select lgt310 with GS102 cable and do reset factory setting it works like magic
Old 05-09-2014, 08:30   #15 (permalink)
Member: 528183
Thanks Meter: 7
yss for me done with select p520 n cable g300 fbus
Plug cable to the phone-phone must be ON, if phone can't be powered connect it OFF and press Power ON and keep it pressed until bootloader will start ...
Aborted by user
Reseting phone ...
Plug cable to the phone - phone must be ON ... OK
======== Process completed ========
Operation time - 00:07
thnks 2 all
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 02-26-2016 13:52
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-26-1999 06:22
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-26-1999 01:00
Page generated in 0.43117 seconds with 8 queries
