Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 06-23-2019, 07:06   #1 (permalink)
Member: 1632035
Sonork: DW
Thanks Meter: 2
LG V35 Thinq (AT&T LM-V350AWM) Unable to Unlock
Greetings. I'm pretty sure I am stuck without a solution, but figured it couldn't hurt to ask if anyone knew of a one.
I had to switch firmwares on this phone to the Korean version for FRP Bypass. However, there are no KDZs for the AT&T variant and I do not get a prompt to input a network unlock code. I've tried the dial codes (2945*#350#, 2945*#71001#, and 2945*#20001#) to no avail on both the Korean firmware and on the Google Fi one. Since I don't have a way to get back to AT&T firmware, am I out of luck with unlocking this one? Thanks for your time.
Nevermind - found solution on XDA: Insert AT&T card, wait for it to read (does not have to be active) then switch to another carrier's SIM and it asks for the code. Whew!
Old 06-23-2019, 13:43   #2 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
I did it too ...with stylo 4 from at&t lm-q710wa i flashed a canadian firm to frp bypass now i cant get back ...cant find at&t firmware to put network code... do you found solution?
Old 06-23-2019, 15:34   #3 (permalink)
Member: 1025079
Thanks Meter: 311
You will not find it, AT&T firmware are not available anywhere.
Old 06-23-2019, 15:52   #4 (permalink)
Member: 1632035
Sonork: DW
Thanks Meter: 2
What worked for me on the V35 - put an AT&T SIM in first then after it reads it, swap in a not accepted one. Network unlock request came right up.
Old 06-24-2019, 01:29   #5 (permalink)
reyxito's Avatar
Member: 2549748
Thanks Meter: 212
Not worked for me
Enviado desde mi SM-G975U1 mediante Tapatalk
Old 06-25-2019, 02:33   #6 (permalink)
Member: 1632035
Sonork: DW
Thanks Meter: 2
Not worked for me
I forgot to mention that I was on the Google Fi / ULM Oreo firmware when I did that.
V350ULM10e_00_NAO_US_OP_0717
If you're on Pie then I doubt you can roll back, but I was on AT&T Oreo update then went to the Fi / Unlocked ULM10e to the Korean KT N10S back to the ULM10e just fine.
Page generated in 0.18357 seconds with 8 queries
