LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
07-25-2015, 12:13 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: WITH JESUS Age: 44
Member: 54260 Status: Offline Thanks Meter: 4 | Lg-vs950 after flash,loose service |
05-19-2016, 02:05 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: InTheSky
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | 1.- Need to be rooted, if not rooted use framaroot 2.-install root explorer or a buld.prop editor and change a line on it: Code: ro.build:target_operator=VZW TO THIS: ro.build:target_operator=OPEN 3.- install NETWORK by Philipp Mangelow from playstore its free 4. Turn off yoyr device insert your gsm simcard, and turn on again the device. 5.- once your booted, open NETWORK and change network type to WCDMA PREFERED, now you should be using gsm... to get data working just set you APN on mobile network settings **This steps, are for JELLYBEAN, IF YOU ARE ON ICE CREAM SANDWICH just install NETWORK an change network type dont need modify build.prop or be rooted*** |
01-22-2017, 20:47 | #5 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2419445 Status: Offline Thanks Meter: 10 | first of all check basband version on your device in settings->About->Software information. In baseband unknown - reflash phone. If baseband available-need to reset modem. If your phone rooted - just erase modemst1 and modemst2. If not rooted - root and do these steps. In most cases it help |
01-11-2018, 03:09 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Monrovia
Member: 231737 Status: Offline Sonork: 100.1606447 Thanks Meter: 163 | I have Android v4.0.4 on my phone and after installed the ''Network_v1.03.apk'' by Philipp Mangelow. Application is not opening it's saying that ''This application does not work on this device'' and just closing by self. Quote:
