LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
09-22-2013, 06:00 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: egypt
Member: 648590 Status: Offline Thanks Meter: 267 | p768 Dead Boot Repair FAILED (remote: partition does not exist) Plug USB cable wait 4 seconds and put battery back in. waiting for OMAP44xx device... Device descriptor: bLength = 18 bDescriptorType = 1 bcdUSB = 528 bDeviceClass = 255 bDeviceSubClass = 255 bDeviceProtocol = 255 bMaxPacketSize0 = 64 idVendor = 451 idProduct = D00F bcdDevice = 0 iManufacturer = 33 iProduct = 37 iSerialNumber = 0 bNumConfigurations = 1 reading ASIC ID usb_write 4 usb_read 81 [*] read 0 bytes NumOfSubblocks: 0x5 Subblock ID: 0x1 Subblock Size: 0x5 CH enabled: 0x7 ROM revision: 0x4 Checksum Subblock: 0x15 CHIP: 4430 IDEN: 4d0acb808f8060e968124bfd5362668a7f7f66fd MPKH: 5f4092eccddf90fa43f546adf89508b31b9c74795e9516194c 0ea6412fdcb7f6 CRC0: 9c669ad9 CRC1: 682adccf sending 2ndstage to target... f0030002 usb_write 4 usb_write 4 wait 5-lelelel... [*] msg size = 4 usb_write 21552 [*] data size = 21552 usb_close Reopen usb... Device descriptor: bLength = 18 bDescriptorType = 1 bcdUSB = 528 bDeviceClass = 255 bDeviceSubClass = 255 bDeviceProtocol = 255 bMaxPacketSize0 = 64 idVendor = 451 idProduct = D00F bcdDevice = 0 iManufacturer = 33 iProduct = 37 iSerialNumber = 0 bNumConfigurations = 1 waiting for 2ndstage response... usb_read 4 usb read = aabbccdd accepted 2ndstage response sending image to target... size = 246272 usb_write 4 usb_write 246272 ** Done ** < waiting for device > sending 'x-loader' (384 KB)... OKAY [ 0.200s] writing 'x-loader'... FAILED (remote: partition does not exist) finished. total time: 0.207s sending 'u-boot' (1024 KB)... OKAY [ 0.528s] writing 'u-boot'... FAILED (remote: partition does not exist) finished. total time: 0.535s Done Press any key to continue . . . |
The Following User Says Thank You to tornado2008 For This Useful Post: |
02-20-2014, 11:06 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Octoplus/Octopus Box LG Software v1.2.1 Release Notes Added support for the following models: - LG P760 - added Dead Boot Repair (without JTAG). - LG P765 - added Dead Boot Repair (without JTAG). - LG P768 - added Dead Boot Repair (without JTAG). - LG P768e - added Dead Boot Repair (without JTAG). - LG P768f - added Dead Boot Repair (without JTAG). - LG P768g - added Dead Boot Repair (without JTAG). - LG P768n - added Dead Boot Repair (without JTAG). - LG P769 - added Dead Boot Repair (without JTAG). - LG P769BK - added Dead Boot Repair (without JTAG). - LG P769BKGO - added Dead Boot Repair (without JTAG). - LG P769BKGO1 - added Dead Boot Repair (without JTAG). - LG P778G - added Dead Boot Repair (without JTAG). - LG F220K - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Security, Write Security Backup, - LG F220K - Write Firmware, Read/Write/Repair NVM, Read Full Flash (Dump NAND), - LG F220K - Reset Screen Lock (including Reset Password, Pin, Pattern, Face Lock). - LG F220L - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Security, Write Security Backup, - LG F220L - Write Firmware, Read/Write/Repair NVM, Read Full Flash (Dump NAND), - LG F220L - Reset Screen Lock (including Reset Password, Pin, Pattern, Face Lock). - LG F220S - added Direct Unlock, Repair IMEI, Repair BT Address, Repair Security, Write Security Backup, - LG F220S - Write Firmware, Read/Write/Repair NVM, Read Full Flash (Dump NAND), - LG F220S - Reset Screen Lock (including Reset Password, Pin, Pattern, Face Lock). |
02-20-2014, 11:13 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Bootloader Unlock So far, the P768 does not have the ability to unlock the bootloader normally, so to do this, we have to flash P760 software which can unlock the bootloader. Lucky for us P768 users, flashing P760 KDZ doesnt affect our screen like P769 users. It still has problems but we are only using it to unlock - nothing more. Bootloader unlocking is a one time action - Once its unlocked, it stays unlocked if you change KDZ/ROM. Extra step. If you need to keep all your data before doing this unlock, root with the lelus method and then install the locked bootloader version of CWM and then take a nandroid backup. You can restore it once you have custom recovery at the end of this tutorial. (Thanks to lelus for tip) Step 1. Flash the P760 V20B/V20C Europe Open KDZ to your phone with the offline flash method. After flashing, you may need to hard reset for the phone to boot. Step 2. Connect your phone to your PC in LG Software Mode with USB Debugging switched on. Step 3. Connect your phone to WiFi and make sure you are able to access the internet. Then leave your phone for 30 mins. This makes sure the device is ready to be unlocked. Step 4. Extract 'ADB_and_Recovery_Images-P768.rar'. Navigate to where 'adb.exe' is stored on your pc and open a command line (Shift + Right Click in Windows Explorer. Step 5. Check your phone has been recognised by typing 'adb devices'. If your phone is connected, type 'adb reboot oem-unlock' Step 6. You should have a black screen with white text with a confirmation to unlock the bootloader. Press Volume Up button to unlock the bootloader. Now you will be in LG Fastboot mode. Step 7. Switch off the phone by holding the power button for 10 seconds. Switch your phone back on. Step 8. Use Offline flash method to flash back to your desired P768 Jelly Bean version. After flashing, you may need to hard reset for the phone to boot. Step 9. Once you have P768 Firmware reinstalled, boot and setup your phone. Installing Custom Recovery with Fastboot Now our phone doesnt allow us to switch to fastboot mode in the same way that P760 users do. I have found that using lelus's fastboot script, we can switch to fastboot and then send recovery. Step 1. Extract fastboot.zip and install fastboot drivers by following README instructions. Step 2. Place chosen recovery into the fastboot directory and rename it to 'recovery.img' Step 3. After installing drivers, navigate to where 'fastboot.exe' is stored on your pc and open a command line (Shift + Right Click). Step 4. Minimise the command line you opened, then Open 'start.bat' from extracted fastboot.zip. Step 5. Select option 1. Switch off your phone, remove the battery and then hit enter. Insert USB cable and then insert battery after 4 seconds. Step 6. Once you are in fastboot mode, your phone will show a black screen. Switch to the command line opened in step 2. Type 'fastboot devices' to check your device has been recognised. Step 7. Type 'fastboot flash recovery recovery.img' to send the recovery image Step 8. Reboot by typing ' fastboot reboot' Extra step. If you took a backup of your data partition at the start. Restore your backup now to regain all data from pre-mod backup. |
