Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 02-12-2013, 05:53   #1 (permalink)
Member: 1814355
Sonork: 100.1604958
Thanks Meter: 26
LG P970 (P970H) unbrick/flash using SmartFlash Tool
SmartFlash Tool completly erases device memory during flashing.
Phone will make Factory Reset at first boot after flashing!
You can upgrade and downgrade. You can downgrade from V20N too!
This also will remove phone lock if you forget unlock code or pattern. (phone lock, NOT simlock or network lock...)
This method doesn't need internet connection.
If you want to flash an LG P970H download correct ROM from link below.
Old 02-12-2013, 05:55   #2 (permalink)
Member: 1814355
Sonork: 100.1604958
Thanks Meter: 26
Downloads:
- SmartFlash Tool (mirror) [password: radkor@XDA]
- stock ROM V10A EEU XXX with .bin & .fls. [CRC MD5: d880b8834400575b5827bafbf29a745e] - DepositFiles, FileServe, WUpload.
Other bin/fls ROMs are HERE.
You need to install LG Mobile drivers. They are located HERE. [CRC MD5: e4614071e72c0292d3a8238908b5c7ba]
1. Unpack SFT.rar that contains SmartFlash Tool program.
2. Unpack, preffered C: drive, firmware pack BIN_LGP970AT-00-V10a-EEU-XXX-MAY-09-2011_0.zip
Inside there will be 2 files: LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_AP.bin i LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_CP.fls.
3. Run B_SmartFlashTool_Extern.exe
4. Choose:
1) ROM copy D/L bookmark
2) in Select mode choose Normal mode
3) choose CP file: LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_CP.fls
4) choose AP file: LGP970AT-00-V10a-EEU-XXX-MAY-09-2011+0_AP.bin
*) connect phone in S/W Update mode with battery in it (on the phone that is switched off, plug in USB cable WHILE HOLDING Vol+ button)
5) choose COM port.
6) choose LGE Mobile USB Serial Port in Communication Driver
7) click Start and wait till end.
It takes about 3 mins to flash.
After successfully flashing, phone will reboot and make Factory Reset.
And that's all!
The Following User Says Thank You to Bl@cK_MooN For This Useful Post:
Old 02-12-2013, 05:57   #3 (permalink)
Member: 1814355
Sonork: 100.1604958
Thanks Meter: 26
Settings:
Flashing:
Finished:
Now your phone should be unbricked and working.
I will not take any responsibility if something goes wrong when you trying this solution. For me and many others it worked well.
Old 02-12-2013, 12:15   #4 (permalink)
BesTCooL's Avatar
Member: 18442
Sonork: 111110
Thanks Meter: 622
how convert kdz to ap and cp for p940
Old 02-18-2013, 22:59   #5 (permalink)
Member: 139591
This thread will make FLS+BIN for any LG kdz ever made for any model.
hope this helps.
Old 04-23-2013, 02:59   #6 (permalink)
Member: 1534095
can i use smartflash tool on my lg v909 tab? i have the .dll for my model and the AP and CP files both in .bin format.
Old 04-23-2013, 11:04   #7 (permalink)
TOZE's Avatar
Member: 54945
Thanks Meter: 22
which cable ???
thanks
Old 04-23-2013, 12:56   #8 (permalink)
Member: 1049285
Thanks Meter: 16
please after flash no network imei spoil need guilde
Old 04-23-2013, 13:23   #9 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
if you have eeprom backup restore it ,
Old 06-26-2013, 20:57   #10 (permalink)
Registered User
Member: 1221313
Thanks Meter: 263
need arabic rom pls help me..................
Old 10-23-2013, 07:40   #11 (permalink)
Member: 1805549
Sonork: 100.1620595
Thanks Meter: 45
LG p970
driver problem i need good link you send other link plz 2much urgent
Old 12-23-2013, 22:46   #12 (permalink)
Member: 1182314
Sonork: 100.1620769
Thanks Meter: 10
when try to put in download mode it giving charging and don't want enter download
Old 12-25-2013, 16:43   #13 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
press volume up button (+) then insert cable while phone turned off
Old 02-06-2015, 04:26   #14 (permalink)
him82's Avatar
Member: 646646
Sonork: 100.1664464
Thanks Meter: 240
SFT .RAR LINK NOT WORKING
ALL POST LINK IS REPEAT POST THANK YOU
The Following User Says Thank You to him82 For This Useful Post:
Page generated in 0.18674 seconds with 8 queries
