LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
03-10-2015, 23:56 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | [ROM][Stock][KITKAT] D955 flashable 4.4.2 Stock Rom !! This ROM is fully Stock, (have all inside) NOTE: When you flash this ROM you'll lose your Custom Recovery TIP: if you have installed one TWRP can flash this "ROM" easy in "AdbSideLoad", put device in TWRP Recovery Mode, Mount AdbSideLoad, Flash via Pc "Prompt Command", wait 15 min.s, (Rom is 1.05 GB), when finish process you phone is Full Working, "NOT INTERRUPT PROCESS". Any Missing Part like Imei, BaseBand itc... just insert sim and use it Download Link: https://docs.google.com/file/d/0B4eG...tmWS03N1U/edit Press Only Thanks Button BR allumts |
The Following 5 Users Say Thank You to allumts For This Useful Post: |
01-25-2016, 08:38 | #2 (permalink) |
Freak Poster Join Date: Mar 2013
Member: 1900449 Status: Offline Sonork: 100.1613676 Thanks Meter: 26 | How to install twrp in d955 lg flex phone i have too same prob after flash done in octopes now imei is null pls help me urgent gsm friends waiting for u |
The Following User Says Thank You to wadoodkhan For This Useful Post: |
01-25-2016, 11:26 | #3 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | This Solution is for FREE users, if you had issue with Octopus Box post in section Not here. BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
02-23-2016, 16:43 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: WestSide Age: 38
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | @allumt I'm facing this kinda problem bith D955 device. Sideload always fails, any idea ? C:\adb>adb devices List of devices attached 064847fc4f5513da sideload C:\adb>adb sideload C:\adb\ROM.zip loading: 'C:\adb\ROM.zip' * failed to write data 'protocol fault (no status)' * C:\adb>adb devices List of devices attached 064847fc4f5513da sideload C:\adb>adb sideload C:\adb\ROM.zip loading: 'C:\adb\ROM.zip' * failed to write data 'protocol fault (no status)' * C:\adb> |
02-23-2016, 19:06 | #5 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read thread for Right Command in Sideload. Wrong Command: Quote:
allumts | ||
02-24-2016, 15:19 | #6 (permalink) |
Member: 254137 Status: Offline Sonork: 1592525 Thanks Meter: 275 | No bro, this is not command problem, anyway: C:\adb>adb devices * daemon not running. starting it now on port 5037 * * daemon started successfully * List of devices attached 064847fc4f5513da sideload C:\adb>adb sideload ROM.zip loading: 'ROM.zip' * failed to write data 'protocol fault (no status)' * C:\adb> It hangs and guive this error 85% sometime 86%. Last edited by .:==di@bila==:.; 02-24-2016 at 15:25. |
02-24-2016, 15:36 | #8 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Hi why are you trying Rom instead of trying stock firmware Download mode working or not? ps. yu can use otg to flash custom roms |
02-25-2016, 09:38 | #10 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @jamesjerss Bro, i've done this guide for same issue in this model, only recovery mode, this "ROM" in reality is one Firmware complete and with me has worked 100%, of course loock post data, wasn't there out Lollipop version, it's 4.4.2KK. @.:==di@bila==:. i not know what fw you had inside first of Brick, but remember that "Rom" in reality is one Firmware Full tested many times in KK version of LG D955, so if for you Not flash i cannot know what you do or what had first in this phone, i've restored, after many guide and spent a lot of the time in try, with SUCCESS in adbsideload my LG D955 with this "Rom/Firmware". It's all. BR allumts |
