LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
07-26-2013, 13:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Belgrade - Serbia Age: 45
Member: 669559 Status: Offline Thanks Meter: 156 | SOLVED LG-E400 aplication camera (process com.lge.camera) has stopped SOLUTION aplication camera (process com.lge.camera) has stopped application settings messages (process com.android.settings) has stopped Instruction to follow:
Press Volume + Volume - and power on once you see emergency mode on the screen connect immediately your LGE E400 to PC
If all goes well, in 5-10 minutes the phone will be flashed with the new firmware. After that, you need the following: You only need to go to the HERE Download and Install the USB DRIVER Software Update & Drivers Install and Execute the LG MOBILE SUPPORT TOOL make sure USB debugging is enabled (usually in Settings -> Applications -> Development -> USB debugging) Connect your phone to PC by using the bundled USB Cable Click Start Updating within the LG Mobile Support Tool to begin. If your phone needs to upgrade, the Start Updating button will be enable. The process takes about 20min The phone software upgrade stopped before completion. 1. Don’t close the update tool, disconnect the cable and reconnect it. And check the USB Driver connection on your PC. After that, please restart the update. 2. Otherwise, please select “Customer Support” – “Recovery Phone” in LG MOBILE SUPPORT TOOL. Then, you can start to recover your phone. Thats it and tested by me just right now |
