Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 04-12-2017, 19:39   #16 (permalink)
Member: 2706069
Originally Posted by Faheem Anjum View Post
zvd is latest one while zvb is old both are ota updates downgrading will kill phone
Thanks for replying! But, ain't this thread a post to revive devices which are killed that way?
Old 04-12-2017, 19:43   #17 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
in latest models downgrade mean you want to kill phone always try to find out the latest update
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 04-12-2017, 19:54   #18 (permalink)
Member: 2706069
Unfortunately there is no sim unlock for ZVD and the previous unlock methods don't work. I can't decide if it's worth trying to roll back to ZVB as the phone is a paperweight anyways right now.
Old 04-14-2017, 14:55   #19 (permalink)
Member: 2475433
Thanks Meter: 9
Link on mega doesnt work
Old 04-16-2017, 13:46   #20 (permalink)
dilbarkhan's Avatar
Member: 1814786
Sonork: 100.1619255
Thanks Meter: 37
I have f500l doesn't work
Old 04-16-2017, 14:32   #21 (permalink)
.:Abdul-Basit:.'s Avatar
Member: 1727711
Sonork: 100.1590443
Thanks Meter: 1,331
Hi
Always Read Post Carefully
Supported Model List Doesnt Have Written Your Model Number ..
Model Supported
H815
H818
H818N
H818P
H819
LS995
LS991
H811
The Following 2 Users Say Thank You to .:Abdul-Basit:. For This Useful Post:
Old 04-19-2017, 18:25   #22 (permalink)
Member: 2639924
i followed the steps but keep getting the same error here is the log,
19:01:59: {ERROR: OpenPort:4197 It took 17.68800000 seconds to open port. Which is longer than 3.000. This indicates your target is not stable
Old 04-23-2017, 15:49   #23 (permalink)
Member: 2493870
Thanks Meter: 16
it`s true it kill my my phone
Old 04-25-2017, 07:50   #24 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 171
my set h815 dead after flash .now detect withpc relink HS-USB QDLoader 9008(com47)
and qfil log
Validating Download Configuration
Image Search Path: C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device
RAWPROGRAM file path: C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\rawprogram0.xml
PATCH file path:C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\patch0.xml
Programmer Path:C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\prog_emmc_firehose_8992_lite.mbn
Start Download
COM Port number:47
Switch To EDL
Download Fail:Failed to Switch to Emergency Download mode
Download Fail:Switch To EDL FailFireHose Fail
Finish Download
Old 04-26-2017, 06:48   #25 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Check Driver and Port Setting correctly!
Old 04-28-2017, 11:33   #26 (permalink)
mhassanrazabj's Avatar
Member: 485816
Sonork: 100.1623308
Thanks Meter: 18
my set is LG H811 V10d
Program Path:C:\Users\MyPC\Desktop\G4 unbrick\G4 unbrick\LS991_ARB_02_RecoveryImage\LS991_ARB_02_Re coveryImage\prog_emmc_firehose_8992_lite.mbn
COM Port number:9
Sahara Connecting ...
Sahara Version:2
Start Sending Programmer
Sending Programmer Finished
Switch To FireHose
Wait for 3 seconds...
Max Payload Size to Target:49152 Bytes
Device Type:eMMC
Platform:8x26
Disable Ack Raw Data Every N Packets
Skip Write:False
Always Validate:False
Use Verbose:False
COM Port number:9
Sending NOP
ReadFile last error: 0
Response is NULL
NOP: Fail Code: 14
Unable to send FireHose NOP, Device is not in Firehose mode !
Download Fail:FireHose Fail FireHose Fail:Failed to send Firehose NOP to the phone.
Finish Download
Old 04-28-2017, 12:29   #27 (permalink)
Member: 1741973
Thanks Meter: 115
unlucky but how about those device already in HS Qcom Dloader mode
unlucky but how about those device already in HS Qcom Dloader mode? most of them allways error in flashing
Old 04-28-2017, 14:17   #28 (permalink)
Lvrajal's Avatar
Member: 1979249
Thanks Meter: 63
H815 i got this error:
Download Fail:FireHose Fail FireHose Fail:Failed to Upload the emmc images to the phone using Firehose.
Old 04-28-2017, 14:22   #29 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
COM Port number:9
Sahara Version:2
Switch To FireHose
Device Type:eMMC
Platform:8x26
Skip Write:False
Use Verbose:False
COM Port number:9
Sending NOP
Response is NULL
NOP: Fail Code: 14
Finish Download
I think You missed something on your steps.
Read Carefully #1 Post and follow to thread step by step.
H811 Bricked you can Recover it only Download mode if you did wrong software or Downgrade by your self.
LG G4 Maximum phone Hang on logo Emmc Faults!
If you are Everything did Correctly Then Check the Phone Hardware.
Rehot EMMC or Replace it
Best Regards,
Shamim
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 04-28-2017, 14:28   #30 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Lg G4 Most of Phone EMMC Faults!
If phone is EMMC Fault You cannot recover it via that Qualcomm Tool.
You Should Ressurect it via a Professional Tool.
Otherwise ReHot and Replace EMMC please
Page generated in 0.26283 seconds with 8 queries
