LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
10-30-2017, 06:51 | #92 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 |
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim |
11-06-2017, 06:15 | #95 (permalink) |
Freak Poster Join Date: Mar 2012 Location: istanbul - turkey
Member: 1739390 Status: Offline Sonork: 100.1623876 Thanks Meter: 5 | I have ls995 soft bricked ---------------- Start Download Program Path:C:\Users\Aziz\Desktop\LS991_ARB_02_RecoveryIm age\prog_emmc_firehose_8992_lite.mbn COM Port number:55 Sahara Connecting ... Sahara Version:2 Start Sending Programmer Sending Programmer Finished Switch To FireHose Max Payload Size to Target:49152 Bytes Device Type:eMMC Platform:8x26 Disable Ack Raw Data Every N Packets Ack Raw Data:False Skip Write:False Always Validate:False Use Verbose:False COM Port number:55 Sending NOP NOP: Fail Code: 10 Unable to send FireHose NOP, Device is not in Firehose mode ! Download Fail:System.Exception: Failed to send Firehose NOP to the phone. at QC.QMSLPhone.Phone.QPHONEMS_FireHoseNOP() at QC.SwDownloadDLL.SwDownload.FireHoseDownloadImage( Boolean bResetPhone, List`1 rawprogramFilesList, List`1 patchFilesList, Single& fImageSizeInMB, Single& fThroughput) Download Fail:FireHose Fail FireHose Fail Finish Download --------------- I tried all of the fils in these models but not succeed can you help by the correct file for LS995 please |
11-08-2017, 13:57 | #96 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Ukraine, Kharkov Age: 36
Member: 243551 Status: Offline Thanks Meter: 24 | i have LS991 after flash and another model. qfil not flash. i am tried flash witout testpoint. cm2 failed too. Code: Validating Application Configuration Load APP Configuration COM:90 SAHARA:True SAHARA:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\prog_emmc_firehose_8992_lite.mbn SEARCHPATH:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage RAWPROGRAM: rawprogram0.xml PATCH: patch0.xml ACKRAWDATAEVERYNUMPACKETS:False ACKRAWDATAEVERYNUMPACKETS:100 MAXPAYLOADSIZETOTARGETINBYTES:False MAXPAYLOADSIZETOTARGETINBYTES:49152 DEVICETYPE:eMMC PLATFORM:8x26 READBACKMODE:0 RESETAFTERDOWNLOAD:False MAXDIGESTTABLESIZE:8192 SWITCHTOFIREHOSETIMEOUT:30 RESETTIMEOUT:200 RESETDELAYTIME:2 METABUILD:G:\GSM1\SE\e6653\APP-SW_Sumire_GLOBAL-LTE2A_32.3.A.2.33_1295-7444_S1-SW-LIVE-F936-PID1-0006-MBR\boot\boot_delivery.xml FLATBUILDPATH:C:\ FLATBUILDFORCEOVERRIDE:True QCNPATH:C:\Temp\00000000.qcn QCNAUTOBACKUPRESTORE:False SPCCODE:000000 ENABLEMULTISIM:False Load ARG Configuration Process Index:0 Validating Download Configuration Image Search Path: G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage RAWPROGRAM file path: G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\rawprogram0.xml PATCH file path:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\patch0.xml Programmer Path:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\prog_emmc_firehose_8992_lite.mbn Meta Build Content XML Path: G:\GSM1\SE\e6653\APP-SW_Sumire_GLOBAL-LTE2A_32.3.A.2.33_1295-7444_S1-SW-LIVE-F936-PID1-0006-MBR\boot\boot_delivery.xml Fail to load contents.xml: В документе XML (1, 2) присутствует ошибка. Start Download Program Path:G:\GSM1\LG\ls991\LS991_ARB_02_RecoveryImage\LS991_ARB_02_RecoveryImage\prog_emmc_firehose_8992_lite.mbn COM Port number:90 Sahara Connecting ... Sahara Version:2 Start Sending Programmer Sending Programmer Finished Switch To FireHose Wait for 3 seconds... Max Payload Size to Target:49152 Bytes Device Type:eMMC Platform:8x26 Disable Ack Raw Data Every N Packets Skip Write:False Always Validate:False Use Verbose:False COM Port number:90 Sending NOP ReadFile last error: 995 Response is NULL NOP: Fail Code: 14 Unable to send FireHose NOP, Device is not in Firehose mode ! Download Fail:FireHose Fail Failed to send Firehose NOP to the phone. Finish Download |
11-18-2017, 07:31 | #97 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2779962 Status: Offline Thanks Meter: 0 | I'm keep getting this while trying to unbrick LG G4 LS991 Download Fail: FireHose Fail FireHose Fail: Failed to send Firehose NOP to the phone. Problem History: My LG G4 LS991 got into Qualcomm HS-USB QDLoader 9008 mode while i was trying to flash it. and whenever i connect it to pc, the mobile is being detected as Qualcomm HS-USB QDLoader 9008 by itself. Is there any solution for this? i'd much appreciate your help. |
11-19-2017, 01:53 | #98 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2001933 Status: Offline Thanks Meter: 2 | Someone unbrick H810 version? I tried with QFIL but always I get FireHose Fail. When I connect with USB is shown like QDLoader 9008 mode. Some news for this? Sent from my iPhone using Tapatalk |
11-19-2017, 11:38 | #99 (permalink) |
Member: 2779962 Status: Offline Thanks Meter: 0 | [QUOTE=...:::SHAMIM:::...;12434128][CENTER][CENTER][B][FONT=Tahoma][U]Unbrick LG G4 Brick hs-usb Qdloader 9008 I'm keep getting this while trying to unbrick LG G4 LS991 Download Fail: FireHose Fail FireHose Fail: Failed to send Firehose NOP to the phone. Problem History: My LG G4 LS991 got into Qualcomm HS-USB QDLoader 9008 mode while i was trying to flash it. and whenever i connect it to pc, the mobile is being detected as Qualcomm HS-USB QDLoader 9008 by itself. Is there any solution for this? i'd much appreciate your help. |
11-19-2017, 16:43 | #100 (permalink) | |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | [QUOTE=SKS007;12792079] Quote:
Most Of Phone faulty by eMMC Problem! The thread of Solution Only for Who did Downgrade or Wrong Firmware Flashed by His Self. He can Try it. Otherwise Rehot, Replace eMMC by Hardware. Try to Check Your Phone by Hardware.
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
01-04-2018, 23:20 | #104 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2796368 Status: Offline Thanks Meter: 1 | lg g4 h815 unbrick 9008 this failure massage appear on "qfile". is reason because you not have correct "firehose program. |
The Following User Says Thank You to tolk2tm For This Useful Post: |
01-08-2018, 12:34 | #105 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Italy
Member: 2108317 Status: Offline Thanks Meter: 4 | H815 hard-brick after downgrade for mistake Validating Application Configuration Load APP Configuration COM:-1 SAHARA:True SAHARA:C:\Users\Admin\Desktop\H815_Recovery\H815_R ecovery\H815_ForFusingDevice\prog_emmc_firehose_89 92_lite.mbn SEARCHPATH:C:\Users\Admin\Desktop\H815_Recovery\H8 15_Recovery\H815_ForFusingDevice RAWPROGRAM: rawprogram0.xml PATCH: patch0.xml ACKRAWDATAEVERYNUMPACKETS:False ACKRAWDATAEVERYNUMPACKETS:100 MAXPAYLOADSIZETOTARGETINBYTES:False MAXPAYLOADSIZETOTARGETINBYTES:49152 DEVICETYPE:eMMC PLATFORM:8x26 READBACKMODE:0 RESETAFTERDOWNLOAD:False MAXDIGESTTABLESIZE:8192 SWITCHTOFIREHOSETIMEOUT:30 RESETTIMEOUT:200 RESETDELAYTIME:2 FLATBUILDPATH:C:\ FLATBUILDFORCEOVERRIDE:True QCNPATH:C:\Temp\00000000.qcn QCNAUTOBACKUPRESTORE:False SPCCODE:000000 Load ARG Configuration Process Index:0 Validating Download Configuration Image Search Path: C:\Users\Admin\Desktop\H815_Recovery\H815_Recovery \H815_ForFusingDevice RAWPROGRAM file path: C:\Users\Admin\Desktop\H815_Recovery\H815_Recovery \H815_ForFusingDevice\rawprogram0.xml PATCH file path:C:\Users\Admin\Desktop\H815_Recovery\H815_Rec overy\H815_ForFusingDevice\patch0.xml Programmer Path:C:\Users\Admin\Desktop\H815_Recovery\H815_Rec overy\H815_ForFusingDevice\prog_emmc_firehose_8992 _lite.mbn Start Download Program Path:C:\Users\Admin\Desktop\H815_Recovery\H815_Rec overy\H815_ForFusingDevice\prog_emmc_firehose_8992 _lite.mbn COM Port number:4 Sahara Connecting ... Sahara Version:0 Start Sending Programmer Download Fail:Unable to download Flash Programmer using Sahara Protocol Download Fail:Sahara FailSahara Fail Finish Download |
