Unbrick LG G4 Brick hs-usb Qdloader 9008 Without Box Unbrick LG G4 Brick hs-usb Qdloader 9008 Model Supportedhttp://www.upgrademag.com/web/wp-con...5/IMG_3902.png Credit Goes To Alnajat Soft Team Engineer Mohammed Alshikh H815 H818 H818N H818P H819 LS995 LS991 H811 LG G4 H811 fix.zip H810 Fix By QFIL.zip 1. Download QPST.WIN.2.7-00430-GENERAL Run setup.exe Windows [Start] button >> Allprograms >> QPST >> QFIL installation confirmation http://www.sevensistersmysteryschool...k-1024x106.png 2. Download Qdload9008_HSUSB_Driver Install Drivers http://www.sevensistersmysteryschool...k-1024x106.png 3. D / L via QFIL To force QDloader download mode, connect the FORCED_USB emmc section with a jumper. Or pressing key combination (volup + voldown) and poweron to boot Emergency D / L mode After two points in the red circle are shorted and connected by power or USB connection, Qdloadmode can be entered and connected to QFIL http://www.lgbbs.com:41/data/attachm...yy99ei4hky.png In Emergency D / L mode, check the port in Device Manager after connecting USB -> QS http://www.lgbbs.com:41/data/attachm...4j9n4fewe4.png http://www.sevensistersmysteryschool...k-1024x106.png Windows [Start] button >> All programs >> QPST >> Run QFIL http://www.lgbbs.com:41/data/attachm...rcz3jpppr3.png Select Port 1. Click the "Select Port" button If you deselect Show Non Diagnostic Port, only the "Diagnostic" or "QDLoader" port will be visible Selecting the port identified by Device Manager http://www.lgbbs.com:41/data/attachm...rryiiorey6.png http://www.sevensistersmysteryschool...k-1024x106.png MBN file selection 2. Click the "Browse" button Select the file "prog_emmc_firehose_8992_lite_stable.mbn" in the folder where the images are stored. For fusing samples, use images made for fusing. ForFusingDevice: For Fusing Devices -> Download to LAF after recovery NotForFusingDevice: for non-fused devices -> Restore and download http://www.lgbbs.com:41/data/attachm...9r6atns9wv.png Select Build, RawProgram, Patch Check http://www.sevensistersmysteryschool...k-1024x106.png Check RawProgram and Patch settings Check the rawprogram0.xmlpatch0.xml file included in the -Select Build path. firehoseprogrammer MBN selected in the same folder Rawprogram0.xml, patch0.xml are loaded. http://www.lgbbs.com:41/data/attachm...onpz2312pd.png http://www.sevensistersmysteryschool...k-1024x106.png SWDownload 4. Click the "Download" button - The progress bar below is completed and the Download Succeed -> Finish Download message is confirmed. http://www.lgbbs.com:41/data/attachm...cripxjp1uy.png |
THANKS BRO ...Recover File for h811-ls995-h818p/n is the same as h818? |
H811 I keep trying the steps, using ls991 on h811, no luck, just keep getting error, took 178.04845t6 seconds, target may be unstable. :o |
Whats the Condition on Your H811? What Was The Problem? Does Your Phone Automatic Detected PC Qualcomm hs-usb Qdloader 9008 Port By Wrong Software or Downgraded Flash. Explain Your Details Problem! |
Which file should I use to recover the H811? |
As for as i knw these files are not official, these file are generated from kdz using UFI Box and added matching cpu emmc firehose.mbn with this i guess. Better go for emmc isp or try via usb repair if supported by jtag boxes, try medusa , ufi etc.. |
For H811 I Selected LS911. It will back your Download mode and LG Logo only! but You can't Run Your Phone by New Software. If You make flash that phone by H811 Firmware it will become again Brick. Because both of phone Boot partition are not Same! But You can Try to Reflash with phone any professional Device and let us know. |
Download Fail:Sahara FailSahara Fail Finish Download |
COM Port number:83 Sahara Connecting ... Download Fail:Could not connect to the COMPORT Download Fail:Sahara FailValue cannot be null. Parameter name: key Finish Download any advice ??? |
Need H810 F500L Files Too Plz |
I have a LS991 running ZVD and I wish to rollback to ZVB. I have an octopus box but I can't download ZVB firmware from there(I can get firmware from rwilco's repository) but my question is if I rollback to ZVB using Octopus box, will it still result in a hard brick? I know octopus box is a useless box as it only does what LG Flash tools are capable of doing and nothing more. Thanks! |
