LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
04-12-2017, 19:54 | #18 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2706069 Status: Offline Thanks Meter: 0 | Unfortunately there is no sim unlock for ZVD and the previous unlock methods don't work. I can't decide if it's worth trying to roll back to ZVB as the phone is a paperweight anyways right now. |
04-19-2017, 18:25 | #22 (permalink) |
Junior Member Join Date: Oct 2016 Location: Libya
Member: 2639924 Status: Offline Thanks Meter: 0 | i followed the steps but keep getting the same error here is the log, 19:01:59: {ERROR: OpenPort:4197 It took 17.68800000 seconds to open port. Which is longer than 3.000. This indicates your target is not stable |
04-25-2017, 07:50 | #24 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | my set h815 dead after flash .now detect withpc relink HS-USB QDLoader 9008(com47) and qfil log Validating Download Configuration Image Search Path: C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device RAWPROGRAM file path: C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\rawprogram0.xml PATCH file path:C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\patch0.xml Programmer Path:C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\prog_emmc_firehose_8992_lite.mbn Start Download COM Port number:47 Switch To EDL Download Fail:Failed to Switch to Emergency Download mode Download Fail:Switch To EDL FailFireHose Fail Finish Download |
04-28-2017, 11:33 | #26 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Bajaur Agency Pakistan Age: 39
Member: 485816 Status: Offline Sonork: 100.1623308 Thanks Meter: 18 | my set is LG H811 V10d Program Path:C:\Users\MyPC\Desktop\G4 unbrick\G4 unbrick\LS991_ARB_02_RecoveryImage\LS991_ARB_02_Re coveryImage\prog_emmc_firehose_8992_lite.mbn COM Port number:9 Sahara Connecting ... Sahara Version:2 Start Sending Programmer Sending Programmer Finished Switch To FireHose Wait for 3 seconds... Max Payload Size to Target:49152 Bytes Device Type:eMMC Platform:8x26 Disable Ack Raw Data Every N Packets Skip Write:False Always Validate:False Use Verbose:False COM Port number:9 Sending NOP ReadFile last error: 0 Response is NULL NOP: Fail Code: 14 Unable to send FireHose NOP, Device is not in Firehose mode ! Download Fail:FireHose Fail FireHose Fail:Failed to send Firehose NOP to the phone. Finish Download |
04-28-2017, 12:29 | #27 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | unlucky but how about those device already in HS Qcom Dloader mode unlucky but how about those device already in HS Qcom Dloader mode? most of them allways error in flashing Last edited by ...:::SHAMIM:::...; 02-21-2018 at 16:00. |
04-28-2017, 14:22 | #29 (permalink) | |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
Read Carefully #1 Post and follow to thread step by step. H811 Bricked you can Recover it only Download mode if you did wrong software or Downgrade by your self. LG G4 Maximum phone Hang on logo Emmc Faults! If you are Everything did Correctly Then Check the Phone Hardware. Rehot EMMC or Replace it Best Regards, Shamim Last edited by ...:::SHAMIM:::...; 08-01-2017 at 18:27. | |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
04-28-2017, 14:28 | #30 (permalink) | |
Lg G4 Most of Phone EMMC Faults! If phone is EMMC Fault You cannot recover it via that Qualcomm Tool. You Should Ressurect it via a Professional Tool. Otherwise ReHot and Replace EMMC please | |
