Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 04-28-2017, 15:30   #31 (permalink)
Lvrajal's Avatar
Member: 1979249
Thanks Meter: 52
Originally Posted by Lvrajal View Post
H815 i got this error:
Download Fail:FireHose Fail FireHose Fail:Failed to Upload the emmc images to the phone using Firehose.
Total download file size: 115.2642MB
Total download time: 1 Min 11 Sec
Throughput: 1.618243MB/s
Download Succeed
Finish Download
But still in qualcomm mode,so i think EMMC fault.
Old 04-28-2017, 15:30   #32 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 1,949
Whats The Phone History?
More Explain please.
Old 04-29-2017, 08:22   #33 (permalink)
Lvrajal's Avatar
Member: 1979249
Thanks Meter: 52
Automatic detected like hs-usb Qdloader 9008,before and even after this.So EMMC fault i think
Old 04-30-2017, 08:20   #34 (permalink)
Member: 2651465
Help!!!!!! Unbrick LG LS676 Boostmobile
Help!!!!!! Unbrick LG LS676 Boostmobile hs-usb Qdloader 9008
Old 04-30-2017, 11:08   #35 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 1,949
Check that above post and You will get Your answer!
Unbrick LG G4 Brick hs-usb Qdloader 9008 Without Box
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 05-01-2017, 17:51   #36 (permalink)
beli_gl's Avatar
Member: 272517
Sonork: 1604061
Thanks Meter: 64
Not working br...
Start Download
COM Port number:459
Switch To EDL
Download Fail:Failed to Switch to Emergency Download mode
Download Fail:Switch To EDL FailFireHose Fail
Finish Download
Old 05-01-2017, 20:15   #37 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 1,949
Originally Posted by beli_gl View Post
Not working br...
Start Download
COM Port number:459
Switch To EDL
Finish Download
Are you sure phone in Qualcomm hs-usb Qdloader 9008 mode?
Old 05-04-2017, 06:29   #38 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 133
Originally Posted by asif-rashid View Post
my set h815 dead after flash .now detect withpc relink HS-USB QDLoader 9008(com47)
and qfil log
Validating Download Configuration
Image Search Path: C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device
RAWPROGRAM file path: C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\rawprogram0.xml
PATCH file path:C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\patch0.xml
Programmer Path:C:\Users\Engineer\Desktop\G4 unbrick\G4 unbrick\H815_Recovery\H815_Recovery\H815_ForFusing Device\prog_emmc_firehose_8992_lite.mbn
Start Download
COM Port number:47
Switch To EDL
Finish Download
set stiker h815 but set board in side h810
plz sir help me thanks in advanc
Old 05-12-2017, 06:35   #39 (permalink)
Member: 2686620
ihave h811 alive with image ls991. but in boot i have error 1009. and when the phone is open:no sound, no network, no cam, no imei.
Old 05-12-2017, 15:19   #40 (permalink)
Moderator
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 1,949
Lightbulb
Repertition and reflash with a professional Tool!
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
The Following 2 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post:
Old 05-14-2017, 16:17   #41 (permalink)
Member: 2686620
repertition? i no have idea. you can explain me
Old 05-16-2017, 14:56   #42 (permalink)
Member: 2715705
i cant complete please help
COM Port number:3
Sahara Connecting ...
Sahara Version:2
Start Sending Programmer
Sending Programmer Finished
Switch To FireHose
Wait for 3 seconds...
Max Payload Size to Target:49152 Bytes
Device Type:eMMC
Platform:8x26
Disable Ack Raw Data Every N Packets
Skip Write:False
Always Validate:False
Use Verbose:False
COM Port number:3
Sending NOP
ReadFile last error: 0
Response is NULL
NOP: Fail Code: 14
Unable to send FireHose NOP, Device is not in Firehose mode !
Download Fail:FireHose Fail FireHose Fail:Failed to send Firehose NOP to the phone.
Finish Download
i pressed the power and volume up+down , is this right ?
nothing happened
Old 05-27-2017, 14:55   #43 (permalink)
Member: 2508405
Sonork: 100.1671124
Thanks Meter: 23
it's worke fine but after flash the phone when turn it off
no thing elsse if u flash it egain
how can i fix it
lg g4 ( h811 h815 vs986 )
Old 06-09-2017, 14:15   #44 (permalink)
Member: 2205481
Sonork: 100.1667971
Thanks Meter: 26
LG G4 Boot Repair Done With QPST QFill Tool......This is Awsome..Trick's
The Following 2 Users Say Thank You to Dipu Razz For This Useful Post:
Old 06-20-2017, 11:20   #45 (permalink)
Member: 2246570
Sonork: 100.1673265
brother can you help me to unbrick ls 770 kindly?????????
Page generated in 0.36982 seconds with 7 queries
