iOS Application, games & media area App, cydia, games, media discussions for Iphone, Ipad, Ipod & other Apple products |
01-15-2013, 14:14 | #1 (permalink) |
Member: 1489030 Status: Offline Sonork: 100.1649409 Thanks Meter: 5,368 | How to Install IPA now Installous has gone Here is a solution i use myself that i find brilliant Yes there are other solutions but this is what i know and im gonna share it First Download the Package bellow https://dl.dropbox.com/u/37235863/IP...verfox0786.zip This is a package i repacked with 4 deb files these debs are what install when you install Installous: Installous 5, Appsync 5x+, weeloader, hackulous repo. From there is a bit complicated for novices Install the Debs files by SFTPing into the idevice (Install VSFTPD from Cydia) go to private/var/tmp and drop your deb files into there then you need to ssh install them (Install OpenSSH from Cydia) shh into idevice default is root and alpine then type command cd /private/var/tmp/ then dpkg -i devicename.deb do this for all deb files once done your apps will be installed and installous will be on the spring board from here is the fun part open installous and select remove meta as you normally do etc etc now grab your ipa files from where ever you want from vshare you can download them select dont install and ftp in and get them from /private/var/mobile/Library/appvv From appcake get them from /private/var/mobile/AppCake what you will need to do is place them into the installous directory /private/var/mobile/Documents/Installous/Downloads once there they will apear in installous from here you disable WIFI and Data and use installous as normal and you can have removed meta data and sync back to itunes what fun YAY If i missed anything or your not sure of something then im sure asking here will get you help from myself and others Thanks |
The Following 6 Users Say Thank You to azhergoga007 For This Useful Post: |
01-15-2013, 19:05 | #4 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Little apt called Alhambra
Member: 13748 Status: Offline Thanks Meter: 84 | the easyest way is using iFunbox ( i-FunBox v2.1 | File Manager, Browser, Explorer, Transfer Tool for iPhone, iPad & iPod ) donīt need to have your iPhone jailbroken, just connect and press "INSTALL IPA" BR |
01-15-2013, 20:33 | #5 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1396255 Status: Offline Thanks Meter: 1 | or u can use 25 pp u dont have to have ur phone jailbroken http://www.youtube.com/watch?v=XagYVAfjdgM http://www.youtube.com/redirect?q=ht...AxMzU4Mjc4NTQw |
01-16-2013, 21:02 | #7 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Barcelona
Member: 221644 Status: Offline Thanks Meter: 18 | Easy and simply way is after jailbreak add this source: cydia.iphonecake.com then install appcake from appcake you can downlod and install app from mobile like installous. or after this you can also use i-FunBox v2.1 from your computer to install apps |
01-16-2013, 21:38 | #8 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Morocco
Member: 1421995 Status: Offline Sonork: 1001640545 Thanks Meter: 56 | ant Install0us,Give try to these Alternative's | ::.. http://forum.gsmhosting.com/vbb/f780...tives-1591944/ |
