02-03-2018, 16:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: United Kingdom Age: 48
Member: 6524 Status: Offline Thanks Meter: 246 | A9(6)After flash phone die, now cant flash any file. Please help me A9(6)After flash phone die,now cant flash any file.. getting error in sp flash tool..urgent help needed |
The Following User Says Thank You to GSMsurgeon For This Useful Post: |
02-03-2018, 16:57 | #2 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Quote:
Before flashing you "must backup/read" firmware. if something wrong, you can flash with backup firmware to bring the phone as before. i am using CM2 tool for MTK phones. you need to flash it again with different version of SPTool. and try to find anothers firmware. | |
The Following User Says Thank You to pazeth™ For This Useful Post: |
02-04-2018, 00:35 | #3 (permalink) | |
Member: 6524 Status: Offline Thanks Meter: 246 | Quote:
02-04-2018, 18:33 | #4 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | what is the error ? provide log here , maybe hardware issue. |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
02-04-2018, 19:27 | #5 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | @ GSMsurgeon Please, open the set back cover & disconnect the battery connection from the phone, than re connection battery after try to flash with correct version preloader with firmware.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
02-04-2018, 19:52 | #6 (permalink) | |
Junior Member Join Date: Dec 2017
Member: 2787248 Status: Offline Thanks Meter: 7 | Quote:
do you analysis/test the preloader of the firmware you flashed? however, you could try to find working firmware and flash using .sp flash tools. | |
The Following User Says Thank You to Slim Inc. For This Useful Post: |
02-05-2018, 00:28 | #7 (permalink) |
Member: 6524 Status: Offline Thanks Meter: 246 | Attached org firmware Orginal firmware details attached in the above link..also error details pls check that link and last post..thanks |
02-05-2018, 00:39 | #9 (permalink) |
Member: 6524 Status: Offline Thanks Meter: 246 | But I don’t have back up for restore..where did I can get correct firmware? Firmware details screen shot attached in above link..pls check and help me..thanks |
02-05-2018, 06:12 | #10 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | You can try with the firmware, MT6580_alps_gxq6580_weg_l_gxq6580_weg_l_5.1_ALPS.L 1.MP6.V2_GXQ6580.WEG.L_P69 Firmware Credit gem-flash.com File RAR Password is: PHP Code:
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 02-05-2018 at 06:18. |
The Following 2 Users Say Thank You to ...:::::NP™:::::... For This Useful Post: |
02-05-2018, 14:56 | #11 (permalink) | |
02-05-2018, 17:51 | #12 (permalink) | |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
Your preloader may be killed, the faulty version firmware flash. First make a format with the 5.1 firmware by sptools, select auto format flash + format whole flash expected boot loader. After you did this method complete, if did not tacking flash, if you get the same error, you must change your CPU. You do again the same method complete with new CPU.
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. | |
02-06-2018, 14:34 | #14 (permalink) |
Member: 6524 Status: Offline Thanks Meter: 246 | phone was working phone was working befor i flash this v6 flash file..after flashing compleate phone not flashing to any file..like prelopader damage..i dont think so wrong file damaged cpu..still phone detecting vcom..so any diffrent methode for reload preloader ? |
02-06-2018, 14:56 | #15 (permalink) | |
Member: 6524 Status: Offline Thanks Meter: 246 | same error in format Quote:
