Alfahd android tools v2 Alfahd android tools v2 http://store2.up-00.com/2016-03/145943655914581.jpg links alfahd android tools v2 - Download - 4shared - fahd abdulaziz or alfahd android tools v2 1- Reset data: This option will wipe user data and factory reset , and you must root your device 2- Go to recovery : to go to recovery via adb mode 3- Go to fastboot: to go to fastboot via adb 4- Reset by fastboot : in this option when you are in ADB mode the mobile will restat to fastboot mode and will wipe user data , and if not work you can use step 5 5- Reset by bootloader: it's the same step 4 but in other command 6- Format by fastboot: this command format userdata 7- Reboot your device: to reboot your device normaly 8- G0 to download mode: reboot you’re your devices in download mode a. Check adb: you must enable USB debugging (Android Debug Bridge) , and this option check if you enabled adb f. check fastboot: to check if you in fastboot mode m. install more local application and to give the app grand without root d. to viwe the main details of your mobile v. to view all information about your mobile and create text file for it u. to erase pattern lock , in this option you must root your mobile e. exit from this tool |
