12-23-2013, 22:06 | #46 (permalink) | |
No Life Poster Join Date: May 2006 Location: Palermo
Member: 281998 Status: Offline Thanks Meter: 117 | Quote:
Code: BPLGUInfoCustomAppSrcP_MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_P3_1_wg_n | |
01-25-2014, 07:48 | #47 (permalink) | |
Junior Member Join Date: Jul 2010 Location: Bangladesh
Member: 1342309 Status: Offline Sonork: 100.1612607 Thanks Meter: 7 | Quote:
Driver - USB VCOM Driver | |
02-22-2014, 13:53 | #48 (permalink) |
No Life Poster Join Date: May 2005 Location: Lecco Italia
Member: 149010 Status: Offline Sonork: 100.1611929 Thanks Meter: 801 | |
02-28-2014, 16:38 | #49 (permalink) |
No Life Poster Join Date: Sep 2011 Location: GSM Forum Age: 31
Member: 1663011 Status: Offline Sonork: 100.1609944 QQ.1504180136 Thanks Meter: 1,594 | All Mtk BPLGU Modem files for Imei change... https://mega.co.nz/#F!0UJVFJhS!KQvzaiz76HR6TPP7RkwwQQ Enjoy..... Br, Sanjeev Chauhan Mobile-Outlet Noida-India |
03-22-2015, 12:14 | #50 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2366831 Status: Offline Sonork: mammukaptm Thanks Meter: 4 | support for lenovo,micromax,and all mtk device *#*#3646633#*#* or download mobile uncle tool from play stor 1- Go to Engineer mode in mobile Uncle tool. 2- Select Engineer mode[MTK] 3- Go to CDS information 4- Select Radio Information 5- Select the phone 1 or 2 phone-1 AT+EGMR=1,7,”15 digit IMEI NO” phone-2 Add this command to it AT+EGMR=1,10,”15 digit IMEI" press “send at command” button. reboot your phone.....done. Last edited by mahamood.ka; 03-22-2015 at 12:22. |
09-18-2015, 17:47 | #51 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,930 | Imei Repair For Almost All Chinese Phones including Lenovo,TEcno,etc Quite a number of MTK users have been having this issue on their MTK devices after flashing one ROM or another; something i call the 'Custom ROM fever'. This issue is mostly caused by wiping / corruption of the data partition. The Baseband and radio (for network signal) are controlled by the NVRAM (located in data/nvram/md/NVRAM/NVD_IMEI) and a file called MP0B_001. Once this file is missing or the NVRAM partiton is corrupted, your phone's IMEI and radio functionality cease to exist. There are several methods to fix this: + Go to Settings > About and check Baseband. If it says Unknown then flash the Stock MTK backup using Sp flash tool - to regain Baseband MP0B_001 Method 1. Download ROM toolbox lite from Playstore 2. Download IMEI.zip (to create a new IMEI file) then unzip the content of the folder (imei.exe) to a folder on your desktop 3. In command prompt, navigate to the imei.exe containing folder you just created on your desktop * NOTE cd\ then enter (returns to root directory Code: cd.. enter (goes up one directory) Code: cd foldername enter (navigates to a folder called foldername) 5. When you're inside the imei folder in command prompt, type imei.exe <15digit_IMEI_1> <15digit_IMEI_2> Code: imei.exe 123456789111111 123456789111124 7. If both IMEIs you gave are of the correct format, a file named MP0B_001_NEW will be created. Rename it MP0B_001. 8. Now you can send it to the sd of your phone 9. Install ROM toolbox lite then go to root explorer 10. In root explorer, delete the existing MP0B_001 file (located @ device/data/nvram/md/NVRAM/NVD_IMEI) and replace with the one you just created 11. Long press the new MP0B_001, go to permissions and tick all 9 boxes at the top then select ok (don't tick special pernissions) 12. Restart your phone 13. Your SIMs should be detected, IMEI reflect and Baseband version change from unknown to what it should be. * Note that getting this done might not be this direct due to different scenarios but replacing the MP0B_001 file is the ultimate goal in order to fix the issue. IMEI Replacement Method This method involves the use of MTK droid tools and is only applicable when your SIM cards are detected but IMEI is invalid or null. To do this: 1. Download MTK droid tools 2. Download PdaNet 3. Enable USB debugging on the phone then connect it to the PC (don't enable mass storage) 4. Install PdaNet on the PC with the phone connected; you should get a message saying drivers installed successfully. 5. Extract then launch MTK droid tools on the PC (still with phone connected to PC) 6. MTK droid tools should detect and display your phones details 7. Click on IMEI/NVRAM 8. Supply the IMEI(s) then click replace 9. Restart your phone if it isn't automatically restarted 10. Your IMEI issue should have been resolved - NVRAM Restore Method * Note that you need a working phone of the same model to backup NVRAM first 1. Download MTK droid tools 2. Download PdaNet 3. Enable USB debugging on the GOOD phone then connect it to the PC (don't enable mass storage) 4. Install PdaNet on the PC with the phone connected; you should get a message saying drivers installed successfully. 5. Extract then launch MTK droid tools on the PC (still with phone connected to PC) 6. MTK droid tools should detect and display your phones details 7. Click IMEI / NVRAM 8. Click Backup 9. When backup is complete, open the MTK Folder > BackupNVRAM to confirm that backup was successful 8. Connect the phone with Basebrand / IMEI error to the PC still with MTK droid tools open 9. Still under IMEI / NVRAM, click Restore 10. Select the appropriate files from the windows that pop up 11. Reboot the phone once the procedure is complete Engineering Mode Method 1. Download and Install Mobile Uncle then grant superuser permission 2. Select Engineer mode 3. Select Engineer mode (MTK) 4. Navigate to the Connectivity tab 5. Select CDS information 3. Select Radio Information 4. At Phone 1: Insert the command below then click Send at command Code: AT+EGMR=1,7,"IMEI1" Code: AT+EGMR=1,10,"IMEI2" Code: AT+ EGMR=The rest of the code 7. Click on Engineer Mode 8. Select Engineer mode (Android) 9, Select Phone information 10. Click Turn on radio All Credits Goes to HovaTek Forum and i tested each method and every one of them work on certain phone depends on the phone but most of the phones repaired using MP0B_001 Method And Most Of MTK Phone Lose imei When You Format it Using SP Tool Most Of Phones stuck on Logo Only Need Flash Only and After You Flash Make Sure You Wipe The Phone FRom Recovery Any Questions Please Post and i will be Happy To Help You |
01-14-2016, 17:42 | #57 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, If It Has MTK CPU So Use This Method & Post Result Please. http://forum.gsmhosting.com/vbb/f781...ualok-1924211/ |
03-07-2016, 17:14 | #59 (permalink) |
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Dear Friend, Always Use The Search Button Please. It's Fast & Really Works. http://forum.gsmhosting.com/vbb/f811...-done-1895200/ All MTK 6571 IMEI Repair Solution. |
