Android Phones IMEI null (invalid) repair {Guide} 1 Attachment(s) Hallo to all, Those days i see many users asking to help For Chines android phones imei repair i don't know why still users face this problems here we have good imei tool (Maui META) for imei repair and easy to use Here i will see some threads Anyway here i will guide u to all how to repair imei in chines android phones With Maui META tool Produce :-
Note :- 2 things mainly problem face all users 1. stock on cdc drivers ( i will attch this drivers ) 2. Stock on (NVRAM database file) mostly user can't select file that's why field to write Here is the link all BPLGU modem files All Mtk BPLGU Modem files for Imei change.rar Here is the Latest Maui META tool MauiMETA_3G_exe_v6.1316.1 MauiMETA_3G_exe_v6.1248.0 MauiMETA_exe_3G_v6.1244.1 MauiMETA_exe_3G_v6.1140.0 Here is the detailed video's Invalid IMEI repair Change IMEI * For this tool change imei U no need to root Ur phone |
Added to Sticky perfectly explained. Like to add all mtk baseband run on NVRAM. path in androids phones "/dev/nvram" you can use 2 way to reflash nvram. one by first post bplg MAUI_1XAMD_W1X_XX_SP_V1X basic function like Imei etc work with most alternative bplg. second once nvram is corrupted you must use flash tool solution with correcting scatter to __NODL_NVRAM to NVRAM and make select correct working phone nvram file for same baseband. Regards, Chevli |
How to phone em meta mode???? |
Unfortunately Maui META will not connect withe phone. Any suggestions? |
need help for repairing invalid imei on mtk6572 i9500 hi sir i need ur help to repair imei on i9500 clon based on mtk 6572 chip. pls post nvm file & flash file iff needed to repair this. i tried a lot to write imei but no result. B.R. BABBU |
Pls see video its easy like "plug in play" |
Here is one more {4.1.1 Jelly bean firmware } phone imei repair OK:) Brand :- INTEX Modal :- AQUAWONDER CPU :- Mtk6577 Version :- 4.1.1 Jelly bean firmware { Phone Not rooted } |
one thing sir..how you put in imei dounload couse i try this software and always get version thanks |
hi i need chinese n7000 imei repair file mt6255 thanksz |
yes it s work fine but i need n7000 mt6255 file plese thanks |
thanks i will try and let you know |
please help mtk6572,E01 file |
