08-10-2013, 12:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Android Phones IMEI null (invalid) repair {Guide} Those days i see many users asking to help For Chines android phones imei repair i don't know why still users face this problems here we have good imei tool (Maui META) for imei repair and easy to use Here i will see some threads Anyway here i will guide u to all how to repair imei in chines android phones With Maui META tool Produce :-
Note :- 2 things mainly problem face all users 1. stock on cdc drivers ( i will attch this drivers ) 2. Stock on (NVRAM database file) mostly user can't select file that's why field to write Here is the link all BPLGU modem files All Mtk BPLGU Modem files for Imei change.rar Here is the Latest Maui META tool MauiMETA_3G_exe_v6.1316.1 MauiMETA_3G_exe_v6.1248.0 MauiMETA_exe_3G_v6.1244.1 MauiMETA_exe_3G_v6.1140.0 Here is the detailed video's Invalid IMEI repair Change IMEI * For this tool change imei U no need to root Ur phone Last edited by ...:::::NP™:::::...; 08-03-2017 at 13:29. Reason: Download link update |
The Following 26 Users Say Thank You to .::AZEEM::. For This Useful Post: |
08-10-2013, 12:50 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Added to Sticky perfectly explained. Like to add all mtk baseband run on NVRAM. path in androids phones "/dev/nvram" you can use 2 way to reflash nvram. one by first post bplg MAUI_1XAMD_W1X_XX_SP_V1X basic function like Imei etc work with most alternative bplg. second once nvram is corrupted you must use flash tool solution with correcting scatter to __NODL_NVRAM to NVRAM and make select correct working phone nvram file for same baseband. Regards, Chevli |
The Following 8 Users Say Thank You to stanner_austin For This Useful Post: |
08-11-2013, 13:04 | #5 (permalink) |
Member: 50037 Status: Offline Sonork: 1580523 Thanks Meter: 193 | need help for repairing invalid imei on mtk6572 i9500 hi sir i need ur help to repair imei on i9500 clon based on mtk 6572 chip. pls post nvm file & flash file iff needed to repair this. i tried a lot to write imei but no result. B.R. BABBU |
The Following 2 Users Say Thank You to babbu For This Useful Post: |
08-12-2013, 06:11 | #6 (permalink) | |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
Pls see video its easy like "plug in play" Last edited by aZimBahar; 05-17-2016 at 10:57. | |
The Following User Says Thank You to .::AZEEM::. For This Useful Post: |
08-12-2013, 06:56 | #7 (permalink) |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Here is one more {4.1.1 Jelly bean firmware } phone imei repair OK Brand :- INTEX Modal :- AQUAWONDER CPU :- Mtk6577 Version :- 4.1.1 Jelly bean firmware { Phone Not rooted } |
The Following 6 Users Say Thank You to .::AZEEM::. For This Useful Post: |
08-12-2013, 12:46 | #8 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: INSIDE OUT
Member: 1015414 Status: Offline Thanks Meter: 155 | Quote:
one thing sir..how you put in imei dounload couse i try this software and always get version thanks | |
The Following User Says Thank You to jasper-j For This Useful Post: |
08-20-2013, 12:53 | #11 (permalink) |
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Here is Ur file BPLGUInfoCustomAppSrcP_MT6225_S00_.rar |
08-20-2013, 15:58 | #13 (permalink) | |
Freak Poster Join Date: Sep 2010
Member: 1385730 Status: Offline Sonork: zubair84 Thanks Meter: 30 | Quote:
