Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 12-23-2013, 22:06   #46 (permalink)
Member: 281998
Thanks Meter: 92
Originally Posted by [email protected] View Post
All Mtk BPLGU Modem files for Imei change: https://mega.co.nz/#F!0UJVFJhS!KQvzaiz76HR6TPP7RkwwQQ
BPLGUInfoCustomAppSrcP_MT6225_S00_
BPLGUInfoCustomAppSrcP_MT6235B_S01_Q28_CELKON_H_DGP_CEBC7220U
BPLGUInfoCustomAppSrcP_MT6250_S00_ZS826AA_074A_V8_0_2
BPLGUInfoCustomApp_MT6516_S01_MAUI_10A_W10_48.e1000_klx2
bplguinfocustomappsrcp_mt6577_s00_maui_11amd_w12_22_sp_v1
BPLGUInfoCustomAppSrcP_MT6575_S01_MAUI_11AMD_W11_50_SP_V14
BPLGUInfoCustomAppSrcP_MT6577_S00_MAUI_11AMD_W12_22_SP_V8
bplguinfocustomappsrcp_mt6252_s01_dep3-w608_01_v1-0-005_110901
bplguinfocustomappsrcp_mt6253_s00_e513_pp_f1_tn_v08
BPLGUInfoCustomAppSrcP_MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V6_P8
BPLGUInfoCustomAppSrcP_MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V1
bplguinfocustomappsrcp_mt6575_s01_maui_11amd_w11_50_sp_v30_p2
bplguinfocustomappsrcp_mt6577_s00_maui_11amd_w12_22_sp_v5
22/12/2013 add:
BPLGUInfoCustomAppSrcP_MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V1_P3_1_wg_n
Tested by me
Old 01-25-2014, 07:48   #47 (permalink)
Member: 1342309
Sonork: 100.1612607
Thanks Meter: 9
Originally Posted by mrnewrochelle View Post
Also I have the same problem, it shows "ger version", where you able to solve this problem? Thanks!
vcom port" driver
Driver - USB VCOM Driver
Old 02-22-2014, 13:53   #48 (permalink)
B Smith's Avatar
Member: 149010
Sonork: 100.1611929
Thanks Meter: 801
Originally Posted by robert2 View Post
please help mtk6572,E01 file
Old 02-28-2014, 16:38   #49 (permalink)
Sanjeev_Chauhan's Avatar
Member: 1663011
Sonork: 100.1609944 QQ.1504180136
Thanks Meter: 1,584
Originally Posted by mcclinic View Post
Need mtk6572 Mtk BPLGU Modem file.
All Mtk BPLGU Modem files for Imei change...
Enjoy.....
Br,
Sanjeev Chauhan
Mobile-Outlet
Noida-India
Old 03-22-2015, 13:14   #50 (permalink)
Member: 2366831
Sonork: mammukaptm
Thanks Meter: 4
support for lenovo,micromax,and all mtk device
*#*#3646633#*#* or download mobile uncle tool from play stor
1- Go to Engineer mode in mobile Uncle tool.
2- Select Engineer mode[MTK]
3- Go to CDS information
4- Select Radio Information
5- Select the phone 1 or 2
phone-1 AT+EGMR=1,7,”15 digit IMEI NO”
phone-2 Add this command to it AT+EGMR=1,10,”15 digit IMEI"
press “send at command” button. reboot your phone.....done.
Old 09-18-2015, 18:47   #51 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 6,871
Imei Repair For Almost All Chinese Phones including Lenovo,TEcno,etc
Quite a number of MTK users have been having this issue on their MTK devices after flashing one ROM or another; something i call the 'Custom ROM fever'. This issue is mostly caused by wiping / corruption of the data partition. The Baseband and radio (for network signal) are controlled by the NVRAM (located in data/nvram/md/NVRAM/NVD_IMEI) and a file called MP0B_001. Once this file is missing or the NVRAM partiton is corrupted, your phone's IMEI and radio functionality cease to exist. There are several methods to fix this:
+ Go to Settings > About and check Baseband. If it says Unknown then flash the Stock MTK backup using Sp flash tool - to regain Baseband
MP0B_001 Method
1. Download ROM toolbox lite from Playstore
2. Download IMEI.zip (to create a new IMEI file) then unzip the content of the folder (imei.exe) to a folder on your desktop
3. In command prompt, navigate to the imei.exe containing folder you just created on your desktop
* NOTE cd\ then enter (returns to root directory
cd.. enter (goes up one directory)
cd foldername enter (navigates to a folder called foldername)
4. A faster method is to open the imei.exe containing folder > Hold down Shift > Right-click on an empty space > Select "Open Command Window here"
5. When you're inside the imei folder in command prompt, type imei.exe <15digit_IMEI_1> <15digit_IMEI_2>
imei.exe 123456789111111 123456789111124
6. Press Enter
7. If both IMEIs you gave are of the correct format, a file named MP0B_001_NEW will be created. Rename it MP0B_001.
8. Now you can send it to the sd of your phone
9. Install ROM toolbox lite then go to root explorer
10. In root explorer, delete the existing MP0B_001 file (located @ device/data/nvram/md/NVRAM/NVD_IMEI) and replace with the one you just created
11. Long press the new MP0B_001, go to permissions and tick all 9 boxes at the top then select ok (don't tick special pernissions)
12. Restart your phone
13. Your SIMs should be detected, IMEI reflect and Baseband version change from unknown to what it should be. * Note that getting this done might not be this direct due to different scenarios but replacing the MP0B_001 file is the ultimate goal in order to fix the issue.
IMEI Replacement Method
This method involves the use of MTK droid tools and is only applicable when your SIM cards are detected but IMEI is invalid or null. To do this:
1. Download MTK droid tools
2. Download PdaNet
3. Enable USB debugging on the phone then connect it to the PC (don't enable mass storage)
4. Install PdaNet on the PC with the phone connected; you should get a message saying drivers installed successfully.
5. Extract then launch MTK droid tools on the PC (still with phone connected to PC)
6. MTK droid tools should detect and display your phones details
7. Click on IMEI/NVRAM
8. Supply the IMEI(s) then click replace
9. Restart your phone if it isn't automatically restarted
10. Your IMEI issue should have been resolved -
NVRAM Restore Method
* Note that you need a working phone of the same model to backup NVRAM first
2. Download PdaNet
3. Enable USB debugging on the GOOD phone then connect it to the PC (don't enable mass storage)
7. Click IMEI / NVRAM
8. Click Backup
9. When backup is complete, open the MTK Folder > BackupNVRAM to confirm that backup was successful 8. Connect the phone with Basebrand / IMEI error to the PC still with MTK droid tools open 9. Still under IMEI / NVRAM, click Restore
10. Select the appropriate files from the windows that pop up
11. Reboot the phone once the procedure is complete
Engineering Mode Method
1. Download and Install Mobile Uncle then grant superuser permission
2. Select Engineer mode
3. Select Engineer mode (MTK)
4. Navigate to the Connectivity tab
5. Select CDS information 3. Select Radio Information
4. At Phone 1: Insert the command below then click Send at command
AT+EGMR=1,7,"IMEI1"
5. At Phone 2: Insert the command below then click Send at command
AT+EGMR=1,10,"IMEI2"
5a. If you get an error like "This command is not allowed in user build" then leave a space between AT+ and EGMR as show below
AT+ EGMR=The rest of the code
6. Go back to Mobile uncle home screen
7. Click on Engineer Mode
8. Select Engineer mode (Android)
9, Select Phone information
10. Click Turn on radio
All Credits Goes to HovaTek Forum and i tested each method and every one of them work on certain phone depends on the phone but most of the phones repaired using MP0B_001 Method
And Most Of MTK Phone Lose imei When You Format it Using SP Tool Most Of Phones stuck on Logo Only Need Flash Only and After You Flash Make Sure You Wipe The Phone FRom Recovery
Any Questions Please Post and i will be Happy To Help You
__________________
Market Feed Back Rules Are There to Read it
USE "THANKS" Button.
The Following 2 Users Say Thank You to ~Leo~ For This Useful Post:
Old 10-10-2015, 17:23   #52 (permalink)
gwlime's Avatar
Member: 1493085
Sonork: n/a
Thanks Meter: 64
MP0B_001 Method
6. Press Enter
2. Download PdaNet
2. Download PdaNet
8. Click Backup
AT+EGMR=1,7,"IMEI1"
MTK 6582 INVALID IMEI
success with Engineering Mode Method
Thank You
Old 12-01-2015, 23:26   #53 (permalink)
Member: 2494655
hi i need chinese MSM7225 imei repair file
Old 12-06-2015, 08:10   #54 (permalink)
Member: 2460697
IMEI null (invalid) repair
tanks for sharing
Old 12-21-2015, 06:57   #55 (permalink)
Member: 160245
Thanks Meter: 19
need file for BPLGU Modem files for Imei change for MTK 6582 INVALID IMEI and BASEBAND UNKNOWN
Old 01-14-2016, 17:38   #56 (permalink)
welfreng's Avatar
Member: 239158
Sonork: 100.1602571
Thanks Meter: 29
hi i need cdc serial for alcatel 4007a any helpme thk
Old 01-14-2016, 17:42   #57 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,148
Dear Friend,
If It Has MTK CPU So Use This Method & Post Result Please.
[GUIDE] How To Install Unsupported CDC Drivers By Sonualok
Old 03-07-2016, 06:13   #58 (permalink)
Member: 1148373
Sonork: gsmhosting
Mtk 6571 nvram database file
Old 03-07-2016, 17:14   #59 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,148
Dear Friend,
Always Use The Search Button Please. It's Fast & Really Works.
Mtk 6571Cpu Imei Change Done
All MTK 6571 IMEI Repair Solution.
__________________
Read The Rules Carefully!!!
WBR
MyGSM World.
Old 03-14-2016, 18:33   #60 (permalink)
Member: 2241913
there will be all ready nvram file or we should it for every phone
Page generated in 0.67003 seconds with 8 queries
