03-31-2015, 20:27 | #528 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 672823 Status: Offline Thanks Meter: 6 | help please sking model 15360 hang on logo after format here is info Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 00C800BC90555400 FLASH LEN:0x20000000 |
The Following User Says Thank You to NABIL17 For This Useful Post: |
04-02-2015, 11:42 | #529 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Mobile servicing field Age: 33
Member: 1319163 Status: Offline Sonork: no need... Thanks Meter: 89 | kingstar ks-a22 pac file need for pettern lock..... |
The Following User Says Thank You to uzzal10 For This Useful Post: |
04-12-2015, 09:49 | #531 (permalink) |
Freak Poster Join Date: Mar 2009 Location: INDIA
Member: 1000479 Status: Offline Sonork: 100.1638119 Thanks Meter: 52 | All files are deleted plz if any person have another link plz share I need micromax a67 reset file thanks in advance |
The Following User Says Thank You to Rajendra gupta For This Useful Post: |
04-19-2015, 09:11 | #532 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | G'FIVE A8 2mb lock remove file needed ......this set always hang on logo after format with volcano so need this file for another a8 which is pattern lock ...and if you upload full flash pic file for already hang gfive a8 then i will be very thankfull to you |
The Following User Says Thank You to zeerik For This Useful Post: |
04-24-2015, 22:53 | #534 (permalink) |
Junior Member Join Date: Apr 2015
Member: 2384328 Status: Offline Thanks Meter: 1 | Winds Android Note Need help hard reset winds android phone. try using winds-note-spd-android-gmail-lock-reset-done-reset-file-azimbahar-1759870/ method but usb not detected. Got error with SPRD COM Enumerator 1 & 2. its like failed to install driver |
The Following User Says Thank You to nacon115 For This Useful Post: |
04-28-2015, 11:53 | #536 (permalink) |
Insane Poster Join Date: Mar 2005 Location: Portugal Age: 41
Member: 128139 Status: Offline Thanks Meter: 1 | hi friends, i have a chinese android (Jugate P328) and i need to reset pattern lock, i try recovery mode but the only options that i saw in recovery are: spreadtrum factory test full phone test item test BT MUT mode clt collabution And the usb debugging isnīt enabled. regards |
