11-08-2015, 05:10 | #1 (permalink) |
Product Manager Join Date: Mar 2011 Location: kuwait Age: 32
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | bypass any Chinese Smart Android Google verify account only by Dipankor-ctg Android Factory Reset After Show Face Problem google verify account Then My Solution Try 100% Solve Your Problem It Is Try To Success Many Many Gsm-Forum User If You Not Success Then Contact With Me On Sonork Or Skype I ready To Help Just Say You Problem... a lot of user having this issue. this is looks like pls first look out this post those phone contain 5.0.0 or lower version. this software just for update like 5.1.1 upper version work.this day the software become a business Install Driver in WINDOWS 8 Code: Instruction to install Driver Software Manually Extract the firmware file Press “ Windows Key + C ” button in your keyboard to open the charms bar Go to “Settings” on your PC Then select “Change Pc Settings” option Then update recovery>>recovery>>below “advanced start up” then select “restart” After restart>> go to troubleshoot>>advanced option>>start up setting>>restart Now your pc will restart and now it will show some option Then click on “7” to disable driver signature verification and pc will restart again After successful restart your pc, right click on “my computer/this pc” option And then select “Manage” then select “device manager” Now select “Action” option at the top and then select “add legacy hardware” Then click “next” then select “install the hardware” option and select next and again select “next” Then select “have disk” option it will show you a pop up notification box Then click “Browse” and go to GM Lollipop 5.0 firmware file> VCOM driver for win 8>VCOM>win7>select “MDMCPQ” file and then select ok Then select “next” and again select “next” Then a red box will appear. Select install driver software anyway That’s it! You have successfully installed MTK Driver. First Time You Read Nvrom Or Bin File Read Then Format After Remove Phone Network Or Phone Dead Smart Phone Flash Tool Auto Format Flash How To Format After Format Your Phone Dead Don't Worry Friends Again Full Flash Then Phone Full Rum Without Google verify account You Just Phone Active Normal You Face Problem Solve Happy To See Flash Tool Instruction of WALTON PRIMO H4 Download Link- Primo H4 Firmware 1. Install driver 2. Open Flash Tool. 3. Open "scatter_loading" and select scatter file (Primo H4 Firmware>Primo H4 software>MT6580_Android_scatter) 4. Click "Firmware Upgrade" then select "Download" and then connect USB cable with mobile (mobile must be off) 5. Then start "Downloading/Flashing Firmware" 6. When it shows "Download Ok" it means the installation/flashing firmware is completed. if any one need any help regarding the issue. i m ready to help. pls reply here. with success history. The Track Depend on Phone and version all are not same . You need find by your self. Don't asked for it I have tested to many Samsung mobile Even Lollipop I used this method since Starting this problem Its Will help you if you findout the Track by your self Otherwise Sorry Maybe its old history for all Of you . But I shared for the new guy BR Dipankor-ctg * Always Follow Forum Rules Here * Use Only Thanks Button * Use Search Button Before make Thread |
The Following 12 Users Say Thank You to Dipankor-ctg For This Useful Post: |
11-08-2015, 05:43 | #2 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | question... can i read the factory firmware from the locked phone ? example: i6i qmobile is lock with google account, now can i read from this phone and do the same as you did in the above post ? or need to read from another working phone ? thanx waiting for answer |
The Following User Says Thank You to khalidjan For This Useful Post: |
11-08-2015, 05:43 | #3 (permalink) |
11-08-2015, 07:07 | #8 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Okara,Punjab {Pakistan}
Member: 578870 Status: Offline Sonork: 100.1625279 MUGHAL MOBILE Thanks Meter: 934 | I Think This Is Not A Perfect Solution If You Have A Perfect Solution Then Post Here..... |
The Following User Says Thank You to Muhammad Aleem For This Useful Post: |
11-09-2015, 13:08 | #12 (permalink) | |
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,698 | Quote:
select scatter file then format now after phone not run then Full Flash problem Will Be Solve Not solve Your Problem Then Contact With Me On Sonork Or Skype pls reply here with success history Bro Dipankor-ctg | |
The Following User Says Thank You to Dipankor-ctg For This Useful Post: |
