12-09-2015, 16:30 | #16 (permalink) |
Insane Poster Join Date: Jun 2008 Location: visakhapatnam
Member: 786547 Status: Offline Sonork: 100.1645883 Thanks Meter: 8 | BEST REGARDS; GLOBAL NETWORK |
12-10-2015, 12:10 | #17 (permalink) |
Product Manager Join Date: Mar 2011 Location: kuwait Age: 32
Member: 1541551 Status: Offline Sonork: +965 99095810 Thanks Meter: 4,695 | @ serajloves My Post Read Carefully i also Say 1st Time Read Nv File If Imei damage Then Write NV File Problem Solve 99% Safe Imei 1% damage Only Imei Then You Do Not Tension Try To My Solution I hove Successfully So Good Luck BR Dipankor-ctg Paid Unlock Team |
02-05-2016, 00:34 | #19 (permalink) |
Freak Poster Join Date: Feb 2014 Location: karachi Age: 31
Member: 2119336 Status: Offline Sonork: mansoor_baloch12 Thanks Meter: 28 | MTK frp lock done by Volcano Merapi tool dont use this it is big risk because Some MTK nand chip phone when u format Preloader Its ur luck nand problem has come or not ... By the way some mtk phones Factory file not availble on net if u have so do this Easy way use MERAPITOOl bypass frp lock 1: open merapitool 1.3.6 2: Go To android tool tab 3: reset gmail lock (frp lock) Now process is done Enjoy |
02-09-2016, 12:53 | #20 (permalink) |
Junior Member Join Date: Jan 2015 Location: Lahore,Pakistan
Member: 2333065 Status: Offline Sonork: 100.1671927 Thanks Meter: 1 | I dont think All type od MTK cpu just one file ..... this file show mt-6580 ,,,, and there are many type of cpu mt-6572 , 6577, 6583 like that ... |
09-24-2016, 07:27 | #24 (permalink) | |
Moderator Join Date: Nov 2009 Location: Italia Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,105 | Quote:
Which Chip Inside Fast Try To Find Out After Try For Next Step Best Regard Sent from my SM-G928F using Tapatalk
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. | |
09-24-2016, 14:01 | #25 (permalink) | |
Hello Dear User Diponkor Said Here Which Think You Understand He Said If Your TAB is MTK Based & Have You That Phone or Tab Same Version Firmware Just Make Format By SPtools With Scatt & Expect Boot Loader Than Flow All Procudore From Bing Step To Last Procudore If You Don't Understand Just Post Result
12-06-2016, 17:39 | #26 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2309401 Status: Offline Thanks Meter: 0 | Just check start adress and length for FRP in scatter file and format only FRP partition with SPTool under manual format. No need to flash afterwards. No need to worry about losing Imei. only format FRP partition. Done You're welcome... |
