09-30-2013, 07:17 | #1 (permalink) | |
No Life Poster Join Date: May 2008 Location: DHAKA,BANGLADESH
Member: 775086 Status: Offline Sonork: 100.1603609 Thanks Meter: 376 | repair IMEI of MTK Smartphone without PC Hello all,i saw here many of our forum members have this prolem.So after many googling i am going to share a hot thing. you can now change all MTK android phones IMEI no without PC. Change IMEI of MTK Smartphone For changing the IMEI no you just following this instructions... DOWNLOAD Mobile Uncle Tools from Google play store. Mobileuncle MTK Tools OR Download... Mobileuncle English version [IMG]http://4.bp.********.com/-4AZo7riCHHw/UN7JVnRfylI/AAAAAAAACas/mNPA28knz_M/s1600/unnamed.png[/IMG] English version Screenshots Description Mobileuncle Tools is power tools for MTK android device:1 display device info 2 information of device and running status 3 easy open engineer mode and MTK engineer mode 4 backup IMEI for MTK mobile 5 recovery online update 6 easy update tool via sdcard 7 Enable USB Mass Storage Device,connect cable first 8 crack operator GPRS lock for MTK 9 free the network access limited via GPRS 10 power GPS search 11 Power the gps search satellite ability 12 enable AP 13 easy reboot to recovery Backup valid IMEI no, Quote:
Instructions
[IMG]http://3.bp.********.com/--5VKqWUIwoM/UN7JFufDlbI/AAAAAAAACak/zq-T77fSv6E/s320/unnamed.jpg[/IMG]
Here you can see Phone1 and Phone2, in that select phone2, because most of the Chinese clone phone the 1st Sim which is a 3G will work perfectly. Only the problem happens when we insert the second sim. If you check you can see the IMEI of 1st sim will start with 35xxxxx and the 2nd will start with 88xxxxxxxx. That is why the second sim is not able to register to the network, because its not in international formatted IMEI. So usually we need to change the IMEI of phone 2.
Here you can see a command line with “AT+”. Now just add this command to it AT+EGMR=1,10,”15 digit YOUR NEW IMEI NO” And press “send at command” button. [ if you want to change the the phone 1 IMEI AT+EGMR=1,7,”NEW IMEI NO”] Yes we all done… now you can restart the phone and check the IMEI by pressing *#06# | |
The Following 8 Users Say Thank You to shuvo007 For This Useful Post: |
04-21-2014, 07:01 | #5 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2171942 Status: Offline Thanks Meter: 0 | W450-MTK6582 no network signal problem ...Model is W450 having MTK6582 processor. Problem is phone is not showing any signal when any sim is inserted. I have vodafone and docomo sims. When Either single or both sims are inserted in either sim slot, signal is not available and "emergency calls only" message on main menu. In available networks if i select choose automatically, it says "can't connect to this network right now. Try again later". In select manually it shows all available mobile networks properly (vodafone/airtel/loop/reliance/dolphin) but when any selected shows same "can't connect" message. Have reset the phone (power +vol up) still same problem. My other older android phone works properly on both sims. The below battery sticker has two diff IMEI numbers printed on it. Please suggest a solution, as it is new phone and already no |
12-25-2014, 15:57 | #11 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1547224 Status: Offline Thanks Meter: 0 | 1 mobileunc 2 engineers tools 3 cds ????????? there is no directory with this in my version of mob/unc I have just updated and still it does not show cds is there some secret menu or has this been omitted from mob/un Thanks |
02-14-2015, 14:05 | #12 (permalink) | |
No Life Poster Join Date: Feb 2015 Location: IRAN-TABRIIZ
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | Quote:
https://play.google.com/store/apps/d...odeMtkShortcut | |
02-27-2015, 13:46 | #13 (permalink) |
Freak Poster Join Date: Jul 2014
Member: 2217517 Status: Offline Sonork: 1660095 Thanks Meter: 24 | mobile uncle tool every thing went well but after enter imei and press send at command it says ""this command is not allowed in user build"" whats the solution |
