01-25-2014, 14:56 | #2 (permalink) |
Product Manager Join Date: Feb 2011 Location: Dubai
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony W10 Symphony W10 Hardreset way 1. Press Hold Volume Up & Down 2. Press Power 3. Show Screen Recovery Mode :Volume Up Factory Mode :Volume Down 4. Press volume up to select recovery mode 5. Then select factory data reset. |
01-25-2014, 14:57 | #3 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony W35 hard reset.. press and hold the vol - and power together for 5-10 sec a menu will come with many options just select clear ems..done! |
01-25-2014, 15:00 | #4 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony W150 Hard Reset Symphony W150 Hard Reset Turn the phone off Press & hold Volume (+) button then press power button shortly. When an android logo(NO COMMAND is written under the logo) appears on the screen then press power button shortly again. Select wipe data factory reset with volume Down (-) key then press Voume + to OK. Select Yes by volume Down key & press volume Up to OK. Reboot System no. |
01-25-2014, 15:02 | #5 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony W125 hard reset 1000% Symphony W125 hard reset 1000% 1) Press Hold Volume Up 2) Press Power 3) Select wipe data/factory reset Using Volume Down Key 4) Select power baton |
01-25-2014, 15:03 | #6 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | symphony w71 hardreset symphony w71 hardreset press volume-button with power button wait 15 sec you see android menu china language select emmc clear with volume-button than press power button again wait 15 sec.that it enjoy. |
01-25-2014, 15:05 | #7 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony w20 Hard Reset Symphony w20 Hard Reset HARD-RESET ----------------------- Press Volume Up & Power After You Will See Recovery Mode Now Choice Clear Flash Enjoy |
01-25-2014, 15:07 | #8 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony W25 Hard Reset & Root Tested _BY GOLDEN A H SHARIF Symphony W25 Hard Reset & Root Tested Found Hard Reset & Root methods: Detailed Method for Rooting Symphony W25 Step 1: Download the ROM from the following link: update.zip Step 2: Copy the downloaded update.zip file to the root of the memory card and then insert the memory card into the phone. Step 3: Power off the phone (note the battery should be kept above 50%) press and hold up the volume + key sources Continue holding Until the recovery screen appears red, then let go Step 4: Select apply update from sdcard (in the recovery screen, use the volume key up to move up and down, press and hold the power key to select) Step 5: Select the file update.zip Wait till your ROM file gets installed The machine has completed installing ROM file Step 6: Select Reboot now |
01-25-2014, 15:12 | #11 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | symphony w65 hard reset power off the phone press and holdVOLUME UP + POWER ON BUTTON screen show android logo THEN PRESS POWER ON BUTTON screen show recovery manu THEN PRESS VOLUME DOWN BUTTON AND SELECT WIPE DATA RESET NOW PRESS VOLUME UP BUTTON screen show delet all user data NOW PRESS VOLUME DOWN BUTTON and select delet all user data NOW PRESS VOLUME UP BUTTON and enjoy ...... |
01-25-2014, 15:14 | #12 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony W68 pattern lock done using hard-reset Symphony W68 pattern lock done using hard-reset 1.Trun Of The Mobile 2.Then Press Volume Doun+Power Swich 3.Then Clear eMMC |
01-25-2014, 15:16 | #13 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony w70 hard reset Symphony w70 hard reset Symphony w70 hard reset 10000% 1. turn of set 2. press and hold "V- and power button 3. Clear eMMC |
01-25-2014, 15:17 | #14 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony w80 hard reset done Symphony w80 hard reset done Press and hold Volume up + power until Red DisplayRelease power key press 2/3 times volume Down Button |
01-25-2014, 15:21 | #15 (permalink) |
Member: 1524668 Status: Offline Sonork: n/a Thanks Meter: 468 | Symphony Xplorer / W90 series Symphony Xplorer / W90 series
4. If you seen under screen menu, then choose “- wipe data / factory reset” navigation key use by volume up and down button. 5. Then Select (- reboot system now). (by 6. no menu list) Now your mobile successfully restored like factory state. |
