11-11-2013, 14:38 | #18 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 300043 Status: Offline Thanks Meter: 360 | tools: http://sdrv.ms/1ge1HV5 drivers: http://sdrv.ms/GCxUWg rom: https://skydrive.live.com/redir?resi...DEXb9ZzwMqkSR4 install the "mtk driver" open "flash_tool" click "scatter-loading" choose "MT6589_Android_scatter_emmc" ( in the ROM folder ) now click "firmware->upgrade" turn off the phone connect to PC |
The Following User Says Thank You to LBOZ_GSM For This Useful Post: |
11-12-2013, 07:27 | #26 (permalink) |
Insane Poster Join Date: Jul 2008 Location: CHURU
Member: 822223 Status: Offline Thanks Meter: 6 | Common Hint: For SP Flash Tool issues: Please supply your tool version, GUI screen shot, and tool logs when you encounter trouble with the latest tool. How to obtain the tool logs? 1. Run the tool; 2. Press Ctrl+Alt+t(Tool Title Hint: Runtime Trace Mode); 3. [Menu]Help-[SubMenu]Open logs folder. BROM ERROR : S_BROM_CMD_STARTCMD_FAIL (2005) [BROM] Can not pass bootrom start command via USB cable! [HINT]: 1. Possibly target power up too early, please try again. 2. Load in the phone does not support bootloader download DA, please try to use BootRom download DA instead. How to use BootRom download DA? Step1. Unplug battery and USB cable in the target. Step2. Plug in battery. Step3. Press USB download key and do not loose it. Step4. Plug in USB cable. Step5. After DA is downloading, USB download key could be loosed. Step6. If it dose not work, please retry from Step1 to Step6. --------------------------- OK --------------------------- ERROR IN SP FLASH TOOL WHAT I DO........... |
11-12-2013, 07:52 | #27 (permalink) |
Member: 822223 Status: Offline Thanks Meter: 6 | --------------------------- Smart Phone Flash Tool --------------------------- Common Hint: For SP Flash Tool issues: Please supply your tool version, GUI screen shot, and tool logs when you encounter trouble with the latest tool. How to obtain the tool logs? 1. Run the tool; 2. Press Ctrl+Alt+t(Tool Title Hint: Runtime Trace Mode); 3. [Menu]Help-[SubMenu]Open logs folder. SP FLASH TOOL ERROR : ( 8200 ) [Platform Error] The load and target are inconsistent! [HINT]: The load to be downloadeded is for MT6589; The target platform is MT6572_S00. Please select a correct load according to the target to download. --------------------------- OK --------------------------- |
11-12-2013, 09:01 | #29 (permalink) |
Member: 822223 Status: Offline Thanks Meter: 6 | I HAVE MT6572 FILE ALSO ... THERE ARE ALSO ERROR IN SP FLASH TOOL.. --------------------------- Smart Phone Flash Tool --------------------------- Common Hint: For SP Flash Tool issues: Please supply your tool version, GUI screen shot, and tool logs when you encounter trouble with the latest tool. How to obtain the tool logs? 1. Run the tool; 2. Press Ctrl+Alt+t(Tool Title Hint: Runtime Trace Mode); 3. [Menu]Help-[SubMenu]Open logs folder. SP FLASH TOOL ERROR : ( 8045 ) No valid Partition Management Table(PMT) for storage device! [HINT]: Please make sure there is a correct load in the target. "Firmware Upgrade" could not be executed without PMT! Please "Download" ONLY first to create PMT on the target! --------------------------- OK --------------------------- |
