Dumping ROM using ADB guide What you need : a pc, usb cable and your android device with sdcard What you need to download : Android SDK. here's the link on how to install it and download link.. Setting Up an Existing IDE | Android Developers USB driver of your device. if not have then read mine previous post http://forum.gsmhosting.com/vbb/9384748-post1.html RKDump file. rkdump Instructions: 1. enable USB debugging on the device 2. Download and Install android SDK (dont forget JAVA JDK if you havent got it yet) 3. now connect your device to your pc, you will see Windows will try to install appropriate driver for your device, if it installed properly then you're lucky, you can proceed to step 4, if not then we need to install the driver using USB driver how to install driver http://forum.gsmhosting.com/vbb/9384748-post1.html now for the adb part.. 4. copy RKdump file you downloaded on the same folder as ADB.exe, usually its in folder Program Files (x86)/android/android-sdk/platform-tools 5. click menu and on search bar, type cmd, right click cmd.exe and run as administrator. 6. on the cmd command prompt, type "cd\program files (x86)/android/android-sdk/platform-tools" without the quote. 7. type Code: adb devices 8. type Code: adb push rkdump /data/ 9. type Code: adb shell 10. type Code: chmod 755 /data/rkdump 11. type Code: /data/rkdump /dev/block/mtdblock5 /sdcard/update.img the end. note: if you want to copy any other part of your device partition.. look in here rkutils | androtab.info special thank's: geoRG77 |
1|root@android:/ # cat /proc/mtd cat /proc/mtd /proc/mtd: No such file or directory 1|root@android:/ # /data/rkdump /dev/block/mtdblock1 /sdcard/kernel.img /data/rkdump /dev/block/mtdblock1 /sdcard/kernel.img /data/rkdump: /dev/block/mtdblock1: No such file or directory |
same HERE.................................. |
how restore back up? |
when i try to the dump flash file on the phone say me Permise Denied |
anyway to dump the rom or to convert it to .pac? |
bro read out dump using that method can be used to restore\upgrade firmware using mmc .. get phone in recovery menu there is a option named "apply update from sd card" |
By tested me 100%101 working thank you bro ;) BR dicle_Gsm |
update.zip compress file Winzip update .zip ? very interesting |
Dumping full Rom flashing ms-dos ? |
Nice work devil's king, hope dz hlp me tackle the latest tecno android phones, any success report on 'logo hang at start up' problem of tecno p3 models? |
does this dumping method works on all android device or it is CPU dependent ? and will this dump works on same set without root ? |
yes these pulled dump work on same phone No need rooted phone for push file in faulty phone |
