04-28-2013, 13:03 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 37
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | Dumping ROM using ADB guide a pc, usb cable and your android device with sdcard What you need to download : Android SDK. here's the link on how to install it and download link.. Setting Up an Existing IDE | Android Developers USB driver of your device. if not have then read mine previous post http://forum.gsmhosting.com/vbb/9384748-post1.html RKDump file. rkdump Instructions: 1. enable USB debugging on the device 2. Download and Install android SDK (dont forget JAVA JDK if you havent got it yet) 3. now connect your device to your pc, you will see Windows will try to install appropriate driver for your device, if it installed properly then you're lucky, you can proceed to step 4, if not then we need to install the driver using USB driver how to install driver http://forum.gsmhosting.com/vbb/9384748-post1.html now for the adb part.. 4. copy RKdump file you downloaded on the same folder as ADB.exe, usually its in folder Program Files (x86)/android/android-sdk/platform-tools 5. click menu and on search bar, type cmd, right click cmd.exe and run as administrator. 6. on the cmd command prompt, type "cd\program files (x86)/android/android-sdk/platform-tools" without the quote. 7. type Code: adb devices 8. type Code: adb push rkdump /data/ 9. type Code: adb shell 10. type Code: chmod 755 /data/rkdump 11. type Code: /data/rkdump /dev/block/mtdblock5 /sdcard/update.img the end. note: if you want to copy any other part of your device partition.. look in here rkutils | androtab.info special thank's: geoRG77 |
The Following 12 Users Say Thank You to ..:: Devil_king ::.. For This Useful Post: |
05-23-2013, 18:24 | #2 (permalink) |
Registered User Join Date: Nov 2007 Location: ID
Member: 624177 Status: Offline Thanks Meter: 23 | 1|root@android:/ # cat /proc/mtd cat /proc/mtd /proc/mtd: No such file or directory 1|root@android:/ # /data/rkdump /dev/block/mtdblock1 /sdcard/kernel.img /data/rkdump /dev/block/mtdblock1 /sdcard/kernel.img /data/rkdump: /dev/block/mtdblock1: No such file or directory |
05-27-2013, 06:25 | #3 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: antipolo philippines Age: 41
Member: 882142 Status: Offline Thanks Meter: 380 | Quote:
same HERE.................................. | |
05-27-2013, 12:34 | #4 (permalink) | |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | Quote:
06-12-2013, 12:35 | #8 (permalink) |
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | bro read out dump using that method can be used to restore\upgrade firmware using mmc .. get phone in recovery menu there is a option named "apply update from sd card" |
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post: |
08-04-2013, 15:14 | #13 (permalink) |
Major Poster Join Date: Jul 2013 Location: abuja city Age: 37
Member: 1983926 Status: Offline Thanks Meter: 44 | Nice work devil's king, hope dz hlp me tackle the latest tecno android phones, any success report on 'logo hang at start up' problem of tecno p3 models? |
09-02-2013, 14:42 | #15 (permalink) | |
yes these pulled dump work on same phone No need rooted phone for push file in faulty phone | |
