Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() Join Date: Dec 2007 Location: indonesia
Member: 667202 Status: Offline Thanks: 0
| how to flash the tablet android china Why do I write a little review tutorial how to install Android on Tablet china, before I wrote this tutor a lot into its core e-mail me asking for help how to flash the tablet android china because most of those who ask no complaints sound the same after flashing his touchsreen had no puncture There is also an experienced boot loop, did not want to start any Android logo appears only In this tutorial I have tried to install the Universal Uberoid Uberoid ROM WM8650 by HCH Here are step by step tutorial on how Uberoid wm8650 flashing via, this way I do and 100% successful touchscreen Soud and had normal lumbar: 1. Download Universal Uberoid WM8650 by HCH to your pc 2. Extract the zip file to a directory on your computer using winrar or other archive software. 3. Connect the sd card into your pc 4. look carefully at what drives the location of what is on your SD F what where. 5. open the downloaded file was already extracted. 6. when it is in the polder double click ''changer.bat'' will display the picture as below http://dc501.4shared.com/img/O-PtAt5...tartup21_2.jpg 7. Type the command'' SDFORMAT "will display some drives select the drive where your SD is waiting to complete the process of formating 8. after any key press format 9. Click again when the menu is missing changer.bat, select the number that corresponds to your android tablet type clay sample images: http://dc268.4shared.com/img/pTz-2d0...econdmenu1.jpg http://www.tech-recipes.com/wp-conte...eroidcopy1.png completion of the copy remove the SD card into the SD input your android Tablet will automatically do the flashing yourself waiting up to 100% then he would pull the SD card automatically retstar after retstar not in SD karu his first pair because there is still the source for more information click here GOOD CAN HELP BY WAHID |
| | #6 (permalink) |
| Junior Member ![]() Join Date: Jan 2013 Location: Belarus, Minsk
Member: 1873806 Status: Offline Sonork: 100:1637805 Thanks: 1
| Still I will add from myself according to the MTKdroidTools program Code: A. If on china Android v 2.2.1 - 2.3.5 or v4.x.x with Kernel v3.x.x is established 1 . We install drivers for ADB 2 . We install the program on a disk with enough of an empty seat 3 . We insert the SD card into phone, it is better to sim to take out. On MT6575 and 77 on the majority of phones at backup by default without cache and userdata, everything has to will be located on the internal card. Except for insertions with a reduced volume of the internal card and phones with the flash MTD type. 4 . We start the program and we connect switched-on phone with the SD card a cable to PC. If all OK, below on the bottom bar the blue indicator lights up and on a tab information will appear information on phone. 5 . On the bottom bar we press the ROOT button. If the button isn't present, root shell already means is! After a while has to there will be temporary root. Thus the indicator will replace color on green and there will be information on the uboot version and the display controler. If it didn't occur, it is possible to receive root shell only through CWM insertion. 6 . It will be offered to keep бдоки phone (backup, a backup). We keep. If there are no mistakes allow to pack in archive and we copy this archive in a reliable place 7 . It will be offered to establish SU (SuperUser). If it is necessary - agrees. These are many associate with the term "receive rues" (get root). 8 . The BuildProp button will correct the build.prop file and after dumping on factory settings phone will be started in Russian and with time zone Moscow. If necessary it is possible to edit before it the build_prop_replace.txt file 9 . The Delete china button will remove unnecessary Chinese appendices. The list can be edited in the files_for_delete.txt file 10 . The Recovery and Boot button will establish and will prepare CWM and patchenny boot. Patchenny boot is necessary for constant root shell and the program it will be possible to keep all blocks having connected phone in a usual mode. CWM we look for in a subject of the phone for the insertion. Or we look for CWM from similar phone and we collect the program on the basis of the quarrystone and this CWM from similar phone. In more detail about it http://forum.china-iphone.ru/viewtopic.php?p=714115#p714115 11 . Prezagruzhayem phone. Conveniently button on the bottom bar. 12 . We have own backup, the factory cleaned insertion with SuperUser, patchenny boot and established CWM for the phone. It isn't necessary to spread the section userdata in public access! It contains personal data and IMEI. It is necessary to spread files already prepared for FlashTool! B.If of Android v2.3.6 or 4.x.x with Kernel v2.6.* and for this insertion is CWM 1 . We install drivers for ADB and we install the program on a disk with enough of an empty seat 2 . We stitch through FlashTool only CWM. If necessary it is possible to receive scatter for FlashTool by means of this program in a window after pressing the Card of Blocks button. 3 . We insert the SD card into phone. On the internal card in the CWM mode while it is impossible to keep. 4 . We start the program and we connect switched-on phone in the CWM mode a cable to PC. If everything OK below on the bottom bar lights up MTKdroidTools.rar |
| | #9 (permalink) | |
| Major Poster ![]() ![]() Join Date: Mar 2006
Member: 241664 Status: Offline Thanks: 6
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| How can I do a Welcome note for my 6110 a dosn't have any one ? | Viper | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 07-18-2012 07:57 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
