03-10-2013, 00:49 | #1 (permalink) |
Insane Poster Join Date: Apr 2011 Location: Serang - Indonesia Age: 39
Member: 1555384 Status: Offline Sonork: 236618AD Thanks Meter: 45 | How Imo Z5 Flashing Tool & Driver: Please Download it Here [Html]http://adf*ly/KZ3BP[/html] Frimware original Stock ROM: Download Here For Logo IMEI IMO White[Html]http://adf*ly/KZ3am[/html] Dowmload Here For Logo IMEI IMO Silver [Html]http://adf*ly/KZ3rQ[/html] [B]update:[/ B] If you are behind Tablet IMO Z5 has a sticker that reads a white base color IMEI information please download link bluetooth version 5875Y, If you are behind Tablet IMO Z5 has a sticker that reads information IMEI gray base color silver please download link bluetooth version 5875 This provision applies because a different bluetooth versions, which, if you choose the wrong firmware, the later can be the Bluetooth function is not working. How to Flashing / Upgrade ... Method 1: 1. Ensure readiness: Firmware File Image, Live Suite, USB Cable, Courage, Perseverance, and Patience 2. Previous Backup all your data with third party applications such as Titanium Backup or World Clock Mod Recovery. 3. Open LiveSuit.exe derived from the Live File ektrasi Suite.rar 4. Click the icon that first, then browse dancari where the firmware file is located and click Ok. 5. Turn off Tablet IMO Z5 and never turned back on, plug the USB cable while you press and hold the power button and vol + about 10-30 seconds. 6. Live Suite program detects the presence of Z5 when finished installing the driver, if you have not please check in device manager, is there a device called Android ADB? 7. The question arises as to format, please format if you want a really fresh as new. If you do not select Upgrade (Application installed morbidly lost.) 8. The process lasts up to 100%, if the program is not responding promptly dislodged Z5 cable and start the program again. 9. If it is 100%, wait until Z5 raises IMO and Boot Animation logo transform into Robot Androi, not David Villa again. Method 2: This method is more simple. 1. If you have an SD Memory Card Class Medium (6-8) or Tinngi (10) can use this alternative. 2. Insert your SD Card into your computer through a card reader or through direct Z5 USB storage mode. 3. Copy the firmware image file to a folder td outermost dr memory card SD Card (Root Folder). 4. Change the name of the file to be update.img 5. Mount or Insert your SD Card again. 6. Turn off your Z5. 7. Turn your Z5. 8. Later there will be a question whether you want to upgrade select yes. 9. The upgrade process runs. 10. If it is 100%, wait until Z5 raises IMO and Boot Animation logo transform into Robot Androi, not David Villa again. To Reset: This method can be used to IMO TAB Z5 and Z6 1. Pray first hope hope in this way to make TAB ny ga in the ICU 2. Press the power button 3-4 seconds -> off and followed by pressing the Volume - (Down) 3. You will go into recovery mode every Chinese-language statement. 4. In the table that appears, TAP Menu Number 2 (top right position). My friend says if it's the meaning of "Tools" 5. Well .. in this step you will be faced with several options table again, of course, the language of china as well. Please TAP bottom left column (row 3) and let the flash take place (if there is no reaction, TAP wrote literary green color bottom left). But, there are some cases when the TAP menu number 2 (point 4) that appear only IMEI number and description of guns off the menu like the description above. If like that, do it like this: a. At the time of the screen displays the IMEI number, and hold TAP Screen and Back TAP menu (which is in a row of menu Home, menu, Back, and Search) b. Then TAP the bottom of the left column (row 3) 6. TAB you are going to reboot ... 7. Kuran Let stand 10 seconds, then turn it back TAB. 8 Welcome .... TAB agan already succeeded in Flash Greetings, (^ _ ^) Last edited by Dhamma; 03-10-2013 at 00:59. |
09-10-2013, 09:41 | #4 (permalink) |
Member: 1555384 Status: Offline Sonork: 236618AD Thanks Meter: 45 | check here fot tutorial video... Video Tutorial Flashing Android TAblet IMO Z5 Full By Dhamma? - YouTube [video]http://www.youtube.com/watch?v=9ij2KlhOuW0[/video] |
