01-20-2016, 06:57 | #2 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Un Known
Member: 2408771 Status: Offline Thanks Meter: 152 | by Infinity Chinese Miracle-2 and A copy from the phone I am I had the same problem Look at to the thread http://forum.gsmhosting.com/vbb/f425...e-cm2-2023828/ |
01-20-2016, 08:35 | #3 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | Quote:
Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 87 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034470203089434B0DF DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , G40CM [eMMC] : FLASH_CID : 7001004D4D433034470203089434B0DF [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E2C00000 [eMMC] : FLASH_UCP : 3628 MiB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG] FlashID [1] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [2] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Init Failed! Looks like HW error or incompatible image Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! | |
01-20-2016, 09:55 | #4 (permalink) | |
Member: 2408771 Status: Offline Thanks Meter: 152 | Quote:
