04-19-2015, 01:12 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Bamako Mali
Member: 1803689 Status: Offline Sonork: 100.1659873 Thanks Meter: 154 | Need BML E615 SPD 6820/8810 flash file Hi all please help me if some one have BML E615 SPD 6820/8810 pac file or others flash file i read backup before format with volcano but volcano can't write backup. PS: phone hang on android logo Here are phone info Volcano Updated: 2015-04-03 Connecting... Connection successful,connected state! Version: V3.8 SN:703-676-133 Port:COM190 After format or Flash you have to press & hold power button for at least 1.30 mins. Note for win7 users : Start your Win 7 64bit with F8 key and choose 'Disable Driver Signature Enforcement'. After that the spd drivers will have the ability to be loaded. For many phones, charge pins need to be set in order to identify USB devices. Detecting D+ and D-... Vcc: null Gnd: 5 Detection initiated... D+ = 3, D- = 2 Detection D+/D- with 5,74 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 1 4 Detection completed. Setting pinouts... Find USB device:SCI USB2Serial (COM189), (VID_1782&PID_4D00) Pinout setting complete. Available Ports:COM37 COM38 COM190 Detection initiated... Vcc: null Gnd: 5 Analyzing D+ and D-... D+ = 3, D- = 2 Detection D+/D- with 5,68 seconds. Continue to detect BOOT pin... Found [SPD] USB device: SCI USB2Serial,(VID_1782&PID_4D00) BOOT(Pull Down) = 1 4 Setting... Find USB device:SCI USB2Serial (COM189), (VID_1782&PID_4D00) Pinouts setting complete! Waiting for phone's response, press the Power on the phone Internal version: SPRD3 Boot downloaded. Start boot please wait a moment.... Spreadtrum Boot Block version 1.1 Boot downloaded. CPU TYPE:SC8810/6820 [88100001] Flash ID: 00AD00BC90555600 Flash Type:[Hyundai] NAND_HY27UT088G2A FLASH LEN:0x20000000 mtdparts=sprd-nand:256k(spl),512k(2ndbl),256k(params),512k(vmjal una),10m(modem),3840k(fixnv),3840k(backupfixnv),51 20k(dsp),3840k(runtimenv),10m(boot),10m(recovery), 265m(system),115m(userdata),60m(cache),256k(misc), 1m(boot_logo),1m(fastboot_logo),3840k(productinfo) ,512k(kpanic),512k(simlock),10m(intmemory) >>Analysis flash internal data successfully. thank to all |
01-11-2016, 16:33 | #2 (permalink) |
Major Poster Join Date: Jan 2005 Location: GSM Network Age: 43
Member: 104927 Status: Offline Thanks Meter: 60 | Hello all. I have the same problem here, i need a .pac file for this model of phone. I googled all the chinese and russian forums but with no luck. Here is my log: Scanning USB Serial port... SU2Serial Port: COM19 Connecting to Phone,Wait.. Done. Infor: SPRD3 Initialize boot13... CPU type: 8810/6820 Flash type: NAND Flash ID: 00AD00BC Flash Model: HYNIX H8BCS0UN0MCR Flash Size: 0x21000000(528,0M) Being analyzed,Wait... 256k(spl),512k(2ndbl),256k(params),512k(vmjaluna), 10m(modem),3840k(fixnv),3840k(backupfixnv),5120k(d sp),3840k(runtimenv),10m(boot),10m(recovery),230m( system),150m(userdata),60m(cache),256k(misc),1m(bo ot_logo),1m(fastboot_logo),3840k(productinfo),512k (kpanic),512k(simlock),10m(intmemory) >>Analyzed data OK.(4) As i understand, the firmware is GC925 JHM (01) BT FM WIFI LDA492117 6820s E10-C925-001 x9 and is not working from the http://forum.gsmhosting.com/vbb/f728.../#post11006445 because the screen its goes half and fuzzy, after flashing with the miracle box and the spd upgrade tool. Some help is appreciated. Thank you. |
01-27-2016, 22:17 | #3 (permalink) |
Member: 104927 Status: Offline Thanks Meter: 60 | I found that the original .pac firmware of this phone is the gc925_1.03_jhm_e15_v13 but it's impossible to find it. Anyone is having this firmware? Thank you all. |
