01-31-2017, 13:43 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2678959 Status: Offline Thanks Meter: 0 | Need rom for iPhone6+ clone MT6572 It has NAND flash. s24(DOT)postimg(DOT)org/rzy33w4gl/image(DOT)jpg s24(DOT)postimg(DOT)org/tufizdgut/image(DOT)jpg http://s24.postimg.org/rzy33w4gl/image.jpg http://s24.postimg.org/tufizdgut/image.jpg Last edited by MyGSM World; 01-31-2017 at 17:21. Reason: Link Added. |
02-01-2017, 06:03 | #2 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | But you can post here file information only image you cannot get properly solution. Willbe better post information by Commercial Tools . Example like this Code: MT62XX_NAND_FISE76_11A_PCB01_hspa_MT62XX_S01.MAUI_11A_W11_12_MP_Vxxx_xx Best regard
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
02-01-2017, 17:47 | #3 (permalink) |
Member: 2678959 Status: Offline Thanks Meter: 0 | The phone is formatted, I cant install stuff like CPU-Z to see specs of the phone. Do you have a link to the "Commercial Tools"? I also tried MTKDroidTools but i get nothing. I know it has NAND flash and MT6572 cpu. I also remember in CPU-Z it said something ALPS. in the board name I flashed some random rom and the only thing that happened is that the camera flash turned on This is what is says in the scatter file of the rom: general: MTK_PLATFORM_CFG info: - config_version: V1.1.1 platform: MT6572 project: e127_lca storage: NAND boot_channel: NONE block_size: 0x20000 Last edited by emil75; 02-01-2017 at 17:52. |
02-01-2017, 21:56 | #4 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | With a professional set of tools do you guys post information, than i can help you. Without information where can I provide you firmware, a wrong firmware may be kill your set preloader permanent dead
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
02-10-2017, 00:09 | #5 (permalink) |
No Life Poster Join Date: Jun 2005
Member: 154448 Status: Offline Sonork: not yet Thanks Meter: 50 | nee the flash file of iphone china info : 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 135 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8B00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : 00AD00BC00900055005400AD00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008B , [HYNIX] H9DA4VH2GJAMCR_4EM [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0054 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 DEV RID : 0x1220238DE89ED8F750082144AD649732 INT RAM : 0x00020000 EXT RAM : 0x10000000 [256 MiB] BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : benrui72_wet_lca ProdModel : benrui72_wet_lca Device : benrui72_wet_lca AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.8 Done! Elapsed: 00:00:17 Reconnect Power/Cable! I:\MT6572_NAND_alps__benrui72_wet_lca__benrui72_we t_lca__4.2.2__ALPS.JB3.MP.V1.8.rar |
