11-26-2015, 13:36 | #1 (permalink) |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Oppo R7 [R7FEX_11_A.08_150914][Firmware][Flash Done] Oppo R7 r7kf logo restart done by flash ROM OS COLOR UP GUIDE THROUGH RECOVERY Note: First to test the battery capacity to 30% on new versions updating offline Is This way in case of an error guide re flash ROM science or computer science are using the new version you want to return the old version. Note : The way up is mandatory to backup all data stored in memory (contacts, messages, applications Code: 1. Transfer the firmware zip file to root of your phone’s SD card or Internal Storage (require above 1.5 GB freespace) 2. Unlock your phone, navigate to Files > All files > (tap SD card if you have downloaded the package to SD card) > select the zip file > tap Update now. 3. Your phone will then reboot and start installation process. (Do not do anything on the phone or power off it during the process). 4. Once the process is completed, your phone will reboot and remain on the Oppo logo for 3 to 5 minutes (Do not power off the device) Direct Download SD CARD ROM ===> R7EX_11_OTA_008_all_201509142105.zip Mirror Google Drive ===> R7FEX_11_A.08_150914.7z Mirror androidfilehost ===> R7FEX_11_A.08_150914.rar Last edited by ...:::::NP™:::::...; 07-30-2018 at 06:35. Reason: Firmware download links has been updated |
