Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 09-30-2013, 07:17   #1 (permalink)
shuvo007's Avatar
Member: 775086
Sonork: 100.1603609
Thanks Meter: 376
Thumbs up repair IMEI of MTK Smartphone without PC
Hello all,i saw here many of our forum members have this prolem.So after many googling i am going to share a hot thing. you can now change all MTK android phones IMEI no without PC.
Change IMEI of MTK Smartphone
For changing the IMEI no you just following this instructions...
DOWNLOAD
Mobile Uncle Tools from Google play store.
Mobileuncle MTK Tools
OR
Download...
Mobileuncle English version
[IMG]http://4.bp.********.com/-4AZo7riCHHw/UN7JVnRfylI/AAAAAAAACas/mNPA28knz_M/s1600/unnamed.png[/IMG]
English version Screenshots
Description
Mobileuncle Tools is power tools for MTK android device:1 display device info
2 information of device and running status
3 easy open engineer mode and MTK engineer mode
4 backup IMEI for MTK mobile
5 recovery online update
6 easy update tool via sdcard
7 Enable USB Mass Storage Device,connect cable first
8 crack operator GPRS lock for MTK
9 free the network access limited via GPRS
10 power GPS search
11 Power the gps search satellite ability
12 enable AP
13 easy reboot to recovery
Backup valid IMEI no,
Its really difficult to get for individual, so take copy IMEI no of your old unused mobile phone, and be sure we will never switch on the phone ever again. If you switch it on, the both sim will not register to the network.
Its all done….
Instructions
  • Go to Engineer mode in mobile Uncle tool
[IMG]http://3.bp.********.com/--5VKqWUIwoM/UN7JFufDlbI/AAAAAAAACak/zq-T77fSv6E/s320/unnamed.jpg[/IMG]
  • Select Engineer mode[MTK]
  • Go to CDS information
  • Select Radio Information
Here you can see Phone1 and Phone2, in that select phone2, because most of the Chinese clone phone the 1st Sim which is a 3G will work perfectly. Only the problem happens when we insert the second sim. If you check you can see the IMEI of 1st sim will start with 35xxxxx and the 2nd will start with 88xxxxxxxx. That is why the second sim is not able to register to the network, because its not in international formatted IMEI. So usually we need to change the IMEI of phone 2.
  • Select the phone 2
Here you can see a command line with “AT+”. Now just add this command to it
AT+EGMR=1,10,”15 digit YOUR NEW IMEI NO”
And press “send at command” button.
[ if you want to change the the phone 1 IMEI
AT+EGMR=1,7,”NEW IMEI NO]
Yes we all done… now you can restart the phone and check the IMEI by pressing *#06#
The Following 8 Users Say Thank You to shuvo007 For This Useful Post:
Old 10-18-2013, 09:26   #2 (permalink)
mkwatis's Avatar
Member: 22893
Sonork: 100.1607086
Thanks Meter: 131
@shuvo007
can this software being of ENGLISH?
Old 10-20-2013, 17:51   #3 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
there is no such thing like Go to CDS information
Old 10-27-2013, 12:48   #4 (permalink)
shuvo007's Avatar
Member: 775086
Sonork: 100.1603609
Thanks Meter: 376
Originally Posted by mkwatis View Post
@shuvo007
Brother English version already included.please see the post again.
Old 04-21-2014, 07:01   #5 (permalink)
Member: 2171942
W450-MTK6582 no network signal problem ...Model is W450
having MTK6582 processor. Problem is phone is not showing any
signal when any sim is inserted. I have vodafone and docomo sims.
When Either single or both sims are inserted in either sim slot,
signal is not available and "emergency calls only" message on main
menu. In available networks if i select choose automatically, it
says "can't connect to this network right now. Try again later".
In select manually it shows all available mobile networks properly
(vodafone/airtel/loop/reliance/dolphin) but when any selected
shows same "can't connect" message. Have reset the phone (power
+vol up) still same problem. My other older android phone works
properly on both sims. The below battery sticker has two diff IMEI
numbers printed on it.
Please suggest a solution, as it is new phone and already no
Old 06-07-2014, 15:35   #6 (permalink)
Crazy Poster
Member: 1818878
Thanks Meter: 2
There is, just swipe your screen to the left
Old 06-07-2014, 15:43   #7 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
not possible all mtk bro possible only canvas2
Old 07-24-2014, 12:09   #8 (permalink)
Member: 1686673
Thanks Meter: 53
Not Work qmobile A5 not ShowCDS information menu
Old 08-17-2014, 21:40   #9 (permalink)
Member: 2242034
can these process brick a phone, most especially techno m3
Old 10-25-2014, 13:42   #10 (permalink)
Member: 1610809
Sonork: 100.1616347
Thanks Meter: 23
this tool only mtk chip , before were do it make sure youre devices already rooted
br
Old 12-25-2014, 15:57   #11 (permalink)
Member: 1547224
1 mobileunc
2 engineers tools
3 cds ????????? there is no directory with this in my version of mob/unc I have just updated and still it does not show cds
is there some secret menu or has this been omitted from mob/un
Thanks
Old 02-14-2015, 14:05   #12 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 332
Originally Posted by fandm View Post
1 mobileunc
2 engineers tools
Thanks
download this apk and run engineer mod.
https://play.google.com/store/apps/d...odeMtkShortcut
Old 02-27-2015, 13:46   #13 (permalink)
MobileCarein's Avatar
Member: 2217517
Sonork: 1660095
Thanks Meter: 24
mobile uncle tool
every thing went well but after enter imei and press send at command it says ""this command is not allowed in user build""
whats the solution
Old 03-17-2015, 10:02   #14 (permalink)
Member: 2362823
Sonork: RAJSHAFI
check wheather u r phone is rooted or not
i have done so many mtk cpus with this tool
Old 08-12-2015, 13:07   #15 (permalink)
Member: 2443123
Sonork: kunmi2009
hello
dsfhdjfiAJDJQWPEO
The Following User Says Thank You to kunmi2009 For This Useful Post:
Page generated in 0.41217 seconds with 9 queries
