10-08-2016, 19:16 | #31 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: morrocco
Member: 345974 Status: Offline Thanks Meter: 23 | Quote:
help me please The File Information: N/A Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM39) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_006E Nand Flash Code: 002C00BC(00900066) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0x20000/0x10000000 >>NO EMMC File, EXIT | |
10-08-2016, 19:32 | #33 (permalink) | |
10-24-2016, 15:44 | #37 (permalink) |
No Life Poster Join Date: May 2013 Location: Cameroon Paris Age: 37
Member: 1943435 Status: Offline Sonork: 1955 Thanks Meter: 377 | Info : CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... EMMC Size: 0x00E7000000 Flash Type: EMMC INT/EXT RAM Size: 0x0+0x0 Reading infr(EMMC)... PRELOADER BaseAddr:0x0 Size:0x1400000 MBR BaseAddr:0x1400000 Size:0x80000 EBR1 BaseAddr:0x1480000 Size:0x80000 PRO_INFO BaseAddr:0x1500000 Size:0x300000 NVRAM BaseAddr:0x1800000 Size:0x500000 PROTECT_F BaseAddr:0x1D00000 Size:0xA00000 PROTECT_S BaseAddr:0x2700000 Size:0xA00000 SECCFG BaseAddr:0x3100000 Size:0x20000 UBOOT BaseAddr:0x3120000 Size:0x60000 BOOTIMG BaseAddr:0x3180000 Size:0x600000 RECOVERY BaseAddr:0x3780000 Size:0x600000 SEC_RO BaseAddr:0x3D80000 Size:0x40000 MISC BaseAddr:0x3DC0000 Size:0x80000 LOGO BaseAddr:0x3E40000 Size:0x300000 EXPDB BaseAddr:0x4140000 Size:0xA00000 ANDROID BaseAddr:0x4B40000 Size:0x1F400000 CACHE BaseAddr:0x23F40000 Size:0xC800000 USRDATA BaseAddr:0x30740000 Size:0x36600000 FAT BaseAddr:0x66D40000 Size:0x7F3C0000 BMTPOOL BaseAddr:0xFFFF00A8 Size:0x0 >>Done. Link Here password : Code: www.gem-flash.com Pls bro need help 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Plase select filename MT65xx ANDROID EMMC File: The File Information: N/A 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM107) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot11 ... >>ERR21002.00 MT65xx ANDROID EMMC File: The File Information: N/A 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set MediaTek USB Port (COM107) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... >>ERR21002.00 thx |
12-29-2016, 11:04 | #39 (permalink) |
Crazy Poster Join Date: Nov 2014 Location: USA, Bangladesh & Dubai
Member: 2290009 Status: Offline Sonork: WhatsApp +971569445116 Thanks Meter: 12 | password : www.gem-flash.com |
01-13-2017, 10:10 | #40 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Lahore,Pak Age: 35
Member: 2112799 Status: Offline Thanks Meter: 87 | There are two version commonly coming with this model SM-G530H, That are 4.4.4 & 4.4.2 So please,before you do any operation you should be aware about version,if you can't get access to find it,then you should download both of two firmware. try one by one you will get success Sm-G530H (Mt6572) Ver 4.4.2 |
The Following User Says Thank You to RanaBhai For This Useful Post: |
02-01-2017, 17:06 | #41 (permalink) |
Crazy Poster Join Date: Jan 2014 Location: meherpur
Member: 2098116 Status: Offline Sonork: taposhmobile Thanks Meter: 4,294,967,267 | CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: [Micron] MT29F4G16 Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0x20000/0x10000000 Reading Size: 0x21000000 Reading infr(Nand)... PRELOADER BaseAddr:0x0 Size:0x80000 PRO_INFO BaseAddr:0x80000 Size:0x100000 NVRAM BaseAddr:0x180000 Size:0x180000 PROTECT_F BaseAddr:0x300000 Size:0x180000 PROTECT_S BaseAddr:0x480000 Size:0x180000 SECCFG BaseAddr:0x600000 Size:0x20000 UBOOT BaseAddr:0x620000 Size:0x60000 BOOTIMG BaseAddr:0x680000 Size:0x600000 RECOVERY BaseAddr:0xC80000 Size:0x600000 SEC_RO BaseAddr:0x1280000 Size:0x40000 MISC BaseAddr:0x12C0000 Size:0x60000 LOGO BaseAddr:0x1320000 Size:0x100000 EXPDB BaseAddr:0x1420000 Size:0x200000 FAT BaseAddr:0x1620000 Size:0x2800000 ANDROID BaseAddr:0x3E20000 Size:0x12C00000 CACHE BaseAddr:0x16A20000 Size:0x700000 USRDATA BaseAddr:0x17120000 Size:0x84A0000 BMTPOOL BaseAddr:0xFFFF0050 Size:0x0 help me...... |
