09-17-2015, 14:27 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | SOLUTION-MTK 6572 dead in flashing and now flash not take with any tool 3% only flash process and hang like this don't worry now u can recover here 1st u need proper virsion flash file next u need sptool latest virsion for 6572 i use this SP_Flash_Tool_exe_v3.1344.0.212 open sptool select proper flash file now press ctr+alt+v on key board u see advnce mode in sptool now u see in option tick on physically format/readback option now click on formate option here u see 1 formate whole flash chip tick on forcedly Erase (bad block mark is erased then ok now insert usb without battery without press any key format start after formate remove usb and click on start button and insert usb again now ur flashing start some time set after flash hang on logo no worry its take 4-5 minuts 1st start if after 4-5 minuts set still hang then use firmware -upgrade button and start again flash 100% set ok this solution for MT6572 NAND chip for 6571 Nand chip next time i post plz dont ask for EMMC chip this solution not work with it if u want copy this solution to ur group i dont mind |
The Following 19 Users Say Thank You to sneha For This Useful Post: |
09-22-2015, 12:31 | #4 (permalink) |
No Life Poster Join Date: Sep 2006 Location: some where in india
Member: 350232 Status: Offline Thanks Meter: 207 | if set not onnect after format whole flash then open set and find gold point just as kclo and short it to ground . |
The Following User Says Thank You to shailccna For This Useful Post: |
09-22-2015, 20:49 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | Hello I could solve, I had this phone for over a year broken. Thank you for your good tutorial. A note, did not have the Flash toll suggested by you and use SP_Flash_Tool_Windows_v5.1504.00 Thank you so much mfeliu07 |
The Following User Says Thank You to mfeliu07 For This Useful Post: |
11-27-2015, 09:53 | #8 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | for MT6571 use this tool SP_Flash_Tool_exe_Windows_v5.1516.00 rest all process same like post 1 |
The Following User Says Thank You to sneha For This Useful Post: |
12-10-2015, 15:24 | #10 (permalink) |
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | |
The Following 4 Users Say Thank You to sneha For This Useful Post: |
01-04-2016, 19:18 | #12 (permalink) |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | I have y220 u10 nand dead I try latest spflashtool SP_Flash_Tool_exe_Windows_v5.1516.00 . And old one But cant be format without battery And with battery But battery is 20% Shoud be full? |
