06-06-2013, 16:51 | #62 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Hungary
Member: 829361 Status: Offline Thanks Meter: 107 | Every pac file contains it. 1. Flash the new pac file with all of its contents 2. Load another pac file with compatible modem image 3. On the Main settings page uncheck all items but the modem (FDLs always remain checked) 4. Start flashing You have to repeat steps 2-4 with different pac files until you find the appropriate modem image. If your phone can't boot up after this procedure, than you have to process the longer way is written below. 1. Load another pac file in RD 2. Check the file path of the extracted image files (it's windows version dependent) on the Main settings page 3. Copy and paste somewhere the modem image file 4. Load the new pac file in RD 5. In the Main settings page replace the original modem image with the earlier copied one. 6. Flash the pac file with all of its components |
The Following 3 Users Say Thank You to bencebacsi For This Useful Post: |
06-10-2013, 12:39 | #64 (permalink) | |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
06-11-2013, 17:42 | #67 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algérie Age: 43
Member: 570252 Status: Offline Thanks Meter: 207 | PLZ PAC file for this one PLZ PAC file for this one after format i got black screen Code: >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM91 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:000098BC Flash Size:20000000->512M Flash Name:NAND_TOSHIBATYBC0A111236KC10 CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Success. Format_Cache...Success. Format_Misc...Success. Format_UserData...Success. All Done... |
06-14-2013, 11:48 | #70 (permalink) |
Freak Poster Join Date: Jun 2009 Location: usb
Member: 1053684 Status: Offline Thanks Meter: 16 | i933 china spd dead after format with gpg info >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM35 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 CPU Name:6820/8810 All Done... format >>> USB Pinfind No need Hold Mobile Power key... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM35 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:000098BC Flash Size:20000000->512M Flash Name:NAND_TOSHIBATYBC0A111236KC10 CPU Name:6820/8810 >>> Auto Formatting ... Format_RuntimeNV...Success. Format_Cache...Success. Format_Misc...Success. Format_UserData...Success. All Done... |
06-14-2013, 15:40 | #72 (permalink) |
Member: 829361 Status: Offline Thanks Meter: 107 | Nobody can help you if you don't provide any useful information about your phone. There're a lot uf such Chinese phones on the market with the same design and model name. You should provide the build version and date here. If you had bricked your phone before you got down these datas, that's your fault. |
The Following User Says Thank You to bencebacsi For This Useful Post: |
